Is Top tier cooling market "stagnant"? - Overclock.net - An Overclocking Community
post #1 of 32 (permalink) Old 11-16-2019, 07:13 AM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
I can't see any better cooler than d15,dark rock pro... etc... all of these perform basically the same +/- 2c... or am i wrong? Maybe the culprit are asetek aios, high end air coolers don't need to improve if they are better than most AIOs
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #2 of 32 (permalink) Old 11-16-2019, 07:17 AM
cssorkinman's Avatar
Rep: 475 (Unique: 270)
Suppose it's happening due to the need for such things declining? TDP's lowering, overclocking limited , stock performance greater than software can leverage? Just spitballing here.
cssorkinman is offline
post #3 of 32 (permalink) Old 11-16-2019, 07:22 AM
The last VRM burner
Rep: 33 (Unique: 18)
You've got stuff like Alphacool Eisbaer or fresh Arctic Liquid Freezer II. Recently got my hands on LF II 360mm, lowered temperatures by 5-6C on each core, compared to lapped Raijintek Tisis (which has pretty much the same performance as Noctua D15).
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 32 (permalink) Old 11-16-2019, 08:34 AM - Thread Starter
Synoxia's Avatar
Rep: 7 (Unique: 5)
AMD processors scale till -56c.
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #5 of 32 (permalink) Old 11-16-2019, 09:31 AM
Never Finished
airisom2's Avatar
Rep: 270 (Unique: 208)
GN's 3950X LN2 video showed clock scaling down to -91C, possibly further.
The plateau is due to quite a few factors:
Form factor (Heatpipe count, single or dual tower, height, width, offset, etc.)
Weight (Can't make it too heavy)
Cost (Has to be competitive)
High-volume capable (has to be able to be manufactured effectively with low tolerances)
Fans (How do you want your cooler to be presented to the press?)
Installation (can't be too complicated, and has to be idiot-proof and sturdy to keep RMAs under control)
Etc.
Today's coolers are basically the result of all of the above factors, and the result is what you see in the market today. In order to break that plateau, someone has to go back to the drawing board and completely reinvent the air cooler. I remember reading an article a week or two ago about a thermal transfer medium NASA created that's many times more effective than what we're using now, and that does bring promise. There are also experimental materials like graphene that have really good thermal conductivity. However, these things are still in the prototype stage in development. Trying to mass produce these things at a cost isn't possible right now.
Your "good" CLCs may perform better than flagship air coolers, but it's usually due to having faster fans. The actually good CLCs, which are more like AIOs, can offer better performance than flagship air coolers at similar fan speeds, but the difference usually isn't that drastic, like 5-6C on average. A temperature difference that small won't usually make any difference in overclock stability or headroom unless your overclock is on the fringe already in which case I'd recommend lowering clocks and voltage to something more manageable.
Despite liquid cooling being more complicated, expensive, and less reliable, it does offer more cooling potential because you have more flexibility with surface area. Though, it is dependent on the case you have. And that right there is another very compelling reason why air cooling has stagnated. If you want lower temperatures, then get wet.
Then, you have thermal density, which is the great equalizer for these coolers. If you can't effectively pull the heat away from the processor (Heatpipes, coldplates, fin design), it doesn't matter how much radiator surface area you have, it's not going to scale very well. We can see this with MO-RA3 1260s with overclocked 9900Ks still reaching high temperatures. Trying to pull 230W+ off of something the size of a nickel is the challenge right now, and it's only going to get worse from here as transistors get smaller.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #6 of 32 (permalink) Old 11-16-2019, 10:04 AM
Overclocker
JackCY's Avatar
Rep: 344 (Unique: 243)
Since about the invention of a heat pipe.
They won't magically be able to make some aluminium2 or copper2, meaning unless you want to mount some gigantic heavy cooler you're not going to get better cooling performance as there are no better affordable existing materials to use for coolers.
Sure they could do more function over form on some coolers, use more heat pipes but in the end the difference probably isn't big at all and they do want to keep selling "cool" looking products not industrial one even though there are people who would rather buy a great industrial cooler instead of some of these consumer trash.
Plus modern silicon chips are not limited as much by cooler capacity to dissipate heat, more by their own heatspreader and getting heat away from the chip fast enough. More heat pipes can help if you can fit them.
AIO/CLC... is a meh product overall, made to serve those who want to fiddle with radiator install rather than learn to install an aircooler and find the AIO/CLC cooling plate somehow easier to install. Have fun with leaks and warranties on those. Plus they tend to need to be replaced = more money to sellers as air coolers will likely outlive you, buy one, use for life.
JackCY is offline
post #7 of 32 (permalink) Old 11-16-2019, 11:50 AM
Yes, but scaling within the range of what is possible with the coolers we are discussing here is very , very limited with Ryzen. The difference between a $20 air cooler and a $300 , 480 mm custom loop was probably less than 100 mhz as an all core OC on my 1800X . It's just that close to it's voltage wall - example 4.0ghz stable was 1.356 volts 4.1ghz 1.425 4175mhz ( not fully stable) 1.52v+ With most of my FX cpu's it was about 800 mhz gained.
post #8 of 32 (permalink) Old 11-16-2019, 12:09 PM
8051's Avatar
Rep: 25 (Unique: 19)
As transistors get smaller won't the required operating voltages go down?
8051 is online now
post #9 of 32 (permalink) Old 11-16-2019, 12:29 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 160 (Unique: 125)
Etc.
Which one is the actually good CLC then?
LF2, is that an Asetek unit? Just the rad is slightly thicker?
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #10 of 32 (permalink) Old 11-16-2019, 12:39 PM
The last VRM burner
According to Arctic, it's their own project, nothing comes from Asetek.
PC for all
(21 items)
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
