Decent quiet 140 with normal mounting? - Overclock.net - An Overclocking Community
post #1 of 19 (permalink) Old 11-18-2019, 04:03 PM - Thread Starter
1689 Federalist
lightsout's Avatar
Rep: 248 (Unique: 213)
I have a Thermaltake Core V21 with a reference 5700 in it. The case has decent air flow, but its just the front 200mm which doesn't push a ton of air. I am mounting a fan horizontally as an intake above the GPU to give it more air.
I have two quality 140mm fans, thermalight and phanteks. But both of them have 120 mounting holes and will mount in this case.
Currently this is at the top of my list, looking for something that will move some air and remain quiet. Also curious if it would be recommended to replace the stock 200mm fan in the front of the case?
https://smile.amazon.com/gp/product/...E1MP17HDH1C152
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
Sapphire Reference RX 5700
GSkill 16gb 3200c14 Flare
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
LG 32GK650F-B 1440p 144hz
Mouse
Sensei Raw
Audio
Sony Core Bookshelves
lightsout is offline
post #2 of 19 (permalink) Old 11-19-2019, 11:46 AM - Thread Starter
1689 Federalist
lightsout's Avatar
Thoughts?
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
Mouse
Sensei Raw
Audio
post #3 of 19 (permalink) Old 11-19-2019, 12:18 PM
EE+CS Undergrad
Rep: 188 (Unique: 157)
I don't see what the problem is for the 140mm fans with 120mm fan mounting holes if you can mount them, unless the 120mm mount points aren't far enough apart so that you can't mount two of the 140 w/ 120 mount point fans.
Otherwise, another TY-14# or the Scythe Kaze Flex 140mm PWM (have to get this from Performance PCs in the US) are good choices.
HybridCore is offline
post #4 of 19 (permalink) Old 11-19-2019, 12:56 PM - Thread Starter
1689 Federalist
lightsout's Avatar
Yeah I would use them if I could, they are not square so the holes don't line up. One of the fans that I mentioned is a TY-14#, doesn't work.
I have a scythe fan that looks like that but it is slim, super loud for some reason, not sure about the one you mentioned.
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
Mouse
Sensei Raw
Audio
post #5 of 19 (permalink) Old 11-19-2019, 01:03 PM
EE+CS Undergrad
Hmm the older Slipstreams had really good dBA/CFM curves but you always had to run them at reduced voltage or a lower PWM cycle because they had really high max RPMs.
Newer Kaze Flex's swapped from a DBB to a FDB and seem to be very good. Lower max RPMs too so you can just throw them in without messing with the PWM duty cycle or voltage.
Anyways, outside of that I can only really think of those Noctuas. That one surprisingly isn't $20+ like some of the others.
post #6 of 19 (permalink) Old 11-19-2019, 01:05 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1154 (Unique: 660)
the Phanteks MP/SP/XP occasionally go on sale for ~$10 on Amazon and they're a steal at that price if you can wait for them to go one sale. Even at MSRP they're not a terrible buy and come with a bunch of goodies like fan extension cables and 7v adapters (or at least the PWM MP/XP do, I never bought the SP).
The SP (82 CFM, 1.33mm H2O) are 3-pin and usually the cheapest, the MP (68 CFM, 1.62mm H2O) is PWM and have the highest static pressure and the XP (85 CFM, 1.52mm H2O) is also PWM and have the highest airflow.
I run 4 of the 140 XP in my Meshify S2 as exhaust fans at a fixed 40% and they're dead silent. Even at 100% they're not obnoxious but they are audible.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #7 of 19 (permalink) Old 11-19-2019, 01:07 PM
OG AMD
Redwoodz's Avatar
Rep: 587 (Unique: 461)
I am happy with my Noctua Redux 140mm 1500RPM. You won't hear them under full load. Similar to the TY140's, I would say they are a hair quieter and a hair less powerful than the TY.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #8 of 19 (permalink) Old 11-19-2019, 01:13 PM
Overclocker
JackCY's Avatar
Rep: 344 (Unique: 243)
Arctic P14 PWM. You're not gonna find better value probably.
Those 200mm fans are usually rubbish, replacing them with a pair of 140 or even 120 probably moves more air.
JackCY is offline
post #9 of 19 (permalink) Old 11-19-2019, 02:33 PM - Thread Starter
1689 Federalist
lightsout's Avatar
Thanks everyone, this is what I was thinking too looks like its possible. I found an old Corsair SP120 I had, seems like a fan right above the GPU doesn't help a while lot. Temps didn't really budge. Maybe the card is doing the best it can.
I will probably get some more though just to get some nice air flow. I will say that my CPU dropped a good 10c coming from the NZXT H200. 5700 doing pretty good too for a reference card.
The pook thanks for the reminder about the Phanteks, I have bought those in the past and I believe have some in my server which a Phanteks Enthoo Pro M.
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
Mouse
Sensei Raw
Audio
post #10 of 19 (permalink) Old 11-20-2019, 04:09 AM
doyll's Avatar
Rep: 1667 (Unique: 927)
Lots of good input.
As already said, your 200mm fans are poor at best. If you could mod opening to accept 4x 120mm or maybe 90mm fans (maybe use Arctic F9 or F8. While not as good as others are not at all bad and usually very low priced.
You might find guide in below link to how airflow works and how to optimize case airflow helpful:
https://www.overclock.net/forum/22319249-post5.html
You want case intake fans to be moving about 10+% more air into and through case than components use. Removing all PCIe slot covers increases rear vent area around GPU and almost always improves front to back airflow and thus lower CPU and GPU temps.
doyll is offline
