Are All Heat Pipes Created Equal? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 11-19-2019, 12:44 PM - Thread Starter
Rep: 1 (Unique: 1)
For heat pipes in different cooler units, are they likely to have fairly similar performance if they appear to be similar size and configuration? Are there "good" heat pipes and "not as good" heat pipes?
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Sapphire Rx 590 Nitro+ 8Gb SE
Kingston Fury HyperX
Corsair CS750M
Noctua NH-D9L
Lian Li PC-011 Dynamic
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
Logitech G402 Hyperion Fury
bkrownd is offline
post #2 of 16 (permalink) Old 11-19-2019, 01:19 PM
Overclocker
JackCY's Avatar
Rep: 344 (Unique: 243)
No.
But for PC cooling the differences aren't that big and more heatpipes with good contact is better.
JackCY is offline
post #3 of 16 (permalink) Old 11-19-2019, 01:56 PM
High Clocker
bmgjet's Avatar
Rep: 189 (Unique: 163)
Theres vastly different quality of heat pipes.
Firstly comes down to the meterial they use for the pipe. Then the vacume and working liquid inside the pipe. And lastly the wicking design.
Some of the cheaper coolers the heat pipes can purely be for show instead of function, Youll cut one open and its just a hollow pipe with ends crimped.
Where youll open your normal heat pipe up and its got a wick inside it and some fluid.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #4 of 16 (permalink) Old 11-19-2019, 02:52 PM - Thread Starter
Rep: 1 (Unique: 1)
Sounds like there are some potential differences. Would you suspect such differences with companies that focus on cooling products and make/market a lot of coolers, and also for instance between their lowest budget, mid-range and high end models?
I'm also wondering if the quality of soldering between the heat pipes and the cooling fins is likely to differ a lot.
When I'm "cooler shopping" I can look at the layout and components of a cooler, which often look very similar. Fans can be replaced, from my giant stockpile of Noctua fans, so I'm not too concerned about that aspect. Just the basic size, construction and thermal conductivity.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #5 of 16 (permalink) Old 11-19-2019, 02:58 PM
High Clocker
bmgjet's Avatar
Go with something with a good review. If you get the genuine product then it will perform as the review did.
If you get a cooler from the likes of ebay that looks exactly the same design but isnt that brand then youll get a dud with fake heat pipes like I did.
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #6 of 16 (permalink) Old 11-19-2019, 02:58 PM
skupples's Avatar
Rep: 589 (Unique: 329)
why is it that there was no fluid or wick inside my GTX480 vapor chamber and tubes?
skupples is offline
post #7 of 16 (permalink) Old 11-19-2019, 03:02 PM
High Clocker
bmgjet's Avatar
Because thats a vapor chamber lmao.
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #8 of 16 (permalink) Old 11-19-2019, 03:03 PM
skupples's Avatar
just making sure
never knew if the vapor like, condensed, then re-vaporized based on temp, etc.
skupples is offline
post #9 of 16 (permalink) Old 11-19-2019, 03:41 PM - Thread Starter
Rep: 1 (Unique: 1)
Problem is a lot of coolers are a tight fit between case, memory sticks, VRM heat sinks, etc. Sometimes the stuff with the good reviews don't fit, and since the range of coolers is so huge they don't all get reviewed side-by-side. I'm more going by brand name, but even that isn't foolproof.
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
post #10 of 16 (permalink) Old 11-19-2019, 03:49 PM - Thread Starter
Rep: 1 (Unique: 1)
just making sure
I used to test detector systems with cryocoolers that did about 0.25 Kelvin by evaporating condensed helium-3. THAT was a fun job.
one of my old babies: http://www.chasecryogenics.com/Files...FULL/IMG04.jpg
Naval Action 2015
(11 items)
i7-4790K
Asus Z97-A
Corsair CS750M
Noctua NH-D9L
Operating System
Windows 10
Asus PB258Q
Keyboard
Happy Hacking USB
Mouse
bkrownd is offline
