Thermalright Frost Spirit - Page 2 - Overclock.net - An Overclocking Community
post #11 of 117 (permalink) Old 12-09-2019, 11:03 AM
Rep: 13 (Unique: 12)
Quote: Originally Posted by Aenra View Post
Yes.. worse still, most are either unable to acknowledge this, on a technical field for crying out loud, or simply don't care i guess?
Extra tragedy cookies given that the above stands today. The 'Era of Information'. Free information at that, is it not?
To the user before the beloved Charlatan, criticising the heat pipes, heat pipes aren't everything. Proven time and time again; they are a significant contributing factor, but far from a sole indicator. Patience
Heatpipes are a conditioning factor. Look at the 212 clones. Better or worst, they're all on the same level.
This cooler's performance, is gonna be on the level of a macho rev.b, Mugen 5 (with fast fan).
Shenhua is offline
post #12 of 117 (permalink) Old 12-09-2019, 11:15 AM - Thread Starter
Tetrapyloctomist
Aenra's Avatar
Rep: 45 (Unique: 27)
Edited my former post to mention you by name, but was too slow apparently. Oldfart reflexes, am so fast you can't see me
Again, agreed on their being 'a' factor. But taking the 212 as the basis for a definitive argument is stretching it. Either way, we'll have some idea soon enough. Am happy it's coming out either way, the more the merrier
Pride, honour and purity.
Aenra is offline
post #13 of 117 (permalink) Old 12-09-2019, 11:41 AM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
Extra tragedy cookies omg I’m dieing. I’m home with my kid today and he is wondering what was so funny daddy.
X5690 E.S. @ 4200MHz 1.35v/Thermalright Le Grand Macho RT/TF8/TY-143
Asus Rampage III Formula @ 200/3600/3600 Bios 0702/Intel 545S 256GB x2
16GB G.Skill + Super Talent Mix @ 800MHz 9-9-9-24 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1490/1900|Asus Xonar Essence ST/KEF M500
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x3/ZM-MFC2
Owterspace is offline
post #14 of 117 (permalink) Old 12-09-2019, 11:45 AM
deepor's Avatar
Rep: 483 (Unique: 328)
That chiphell post says this here according to Google Translate:
"[...] four thick ♂ heat pipe, the last gay purple RGB Town House."
deepor is offline
post #15 of 117 (permalink) Old 12-09-2019, 11:45 AM
Owterspace's Avatar
Rep: 7 (Unique: 4)
I know this is a midrange cooler, but I bet it will do well. Fat pipes, with not a lot of bend to them. And look at that cold plate. Mint. Not bad for the price.
post #16 of 117 (permalink) Old 12-09-2019, 11:59 AM
What does you not liking the 212 have to do with it being used as an example? Or argument for that matter. It's the cooler with most clones out there. It's the perfect example.
Or you just can't go past your own bias?
Shenhua is offline
post #17 of 117 (permalink) Old 12-09-2019, 12:11 PM
Smanci's Avatar
Rep: 75 (Unique: 64)
This was released as IFX-14 in 2007 and as Silver Arrow in 2011. A bit above D14 level of performance at half the price, give or take. The usual.
Smanci is offline
post #18 of 117 (permalink) Old 12-09-2019, 12:21 PM - Thread Starter
Tetrapyloctomist
Aenra's Avatar
I didn't state i have one, nor did i allude to it by anything, at all, that i've posted. Which tells me you need to let go of the gear shift for a bit. Your preconceptions are yours; not mine.
Now in rare moments of patience, i do explain things i shouldn't be explaining, to people not worthy of having it all served to them, given their previous comments.
This is admittedly not such a moment.
Aenra is offline
post #19 of 117 (permalink) Old 12-09-2019, 12:35 PM
Owterspace's Avatar
Rep: 7 (Unique: 4)
A tweaked IFX with a nicer cold plate, and better mount. Its a nice evolution. I cant say I care for RGB, but I would buy this cooler.
post #20 of 117 (permalink) Old 12-10-2019, 04:40 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Seems Thermalright is going back in time with this one.
They used 4x 8mm heatpipes in one of the first if not first twin tower CPU coolers way back in 2007, the IFX-14 (L146.2xW124xH161mm/790g with IFX-10 backside heatsink).
Then released Cogage Arrow (L147xW123xH163mm/825g)) (slightly modified IFX-14) in 2009.
Then original Silver Arrow (L127.8xW147xH163mm)(slightly modified Cogage Arrow) in 2010 (L147xW123xH163mm/825g) in 2010.
Cogage Arrow and Silver Arrow cooled a couple degrees better than NH-D14. I never tested IFX-14 against them, but suspect similar temps, maybe a little better because of IFX-10 backside cooler.
A few reviewers have tested NH-D14 against NH-D15 and found with same fans NH-D14 is a little better than D15.
I see no reason to think Frost Spirit performance will different from Thermalright's other 4x 8mm heatpipe cooleers .. meaning Frost Spirit performance will be one of the best air coolers on the market.
doyll is offline
