What would be best possible air setup? - Overclock.net - An Overclocking Community
post #1 of 45 (permalink) Old 01-07-2020, 04:18 PM - Thread Starter
PhotonFanatic's Avatar
Rep: 21 (Unique: 20)
This is just something I've been rolling around in the 'ol noggin. If you were building it all from the ground up, it seems that you'd want to take advantage of the fact that heat rises. So your cpu's heatsink would be facing the top of the case, and the fan attached to it would blow air in that direction. There would also be a fan in the top of the case, just above the cooler. As so many cases have. This would help the warm airto just keep on traveling upwards and out of the case.
Your card would have a squirrel cage fan, and blow air out the back of the case. So the card would contribute to temps inside the case as little as possible. The PSU would not even be in the case, once again so as to contribute no heat. Maybe extension cables could be used for the PSU... some way or another for it to be outside the case. I think the Not From Concentrate boutique builder did something like that once. Rigged up a PSU to be outside of the case.
Lastly, have a single fan on the front, and a single exhaust fan on the back. So we keep ambient temps in the case as low as possible. Along with excellent cable management. I guess the best cooling setup would be to use an open air case, and just dust the thing regularly. But I'm talking about a standard computer case, not a dust magnet. Anyway what are your thoughts on the perfect air cooling setup?
"Executing execution.exe"
Bang for the buck
(12 items)
3570k @ 4.6Ghz @1.35v
Gigabyte Z77x UD3H
evga GTX 970 SSC
16Gb Gskill Ripjaws 2133Mhz @ 9-11-10-28
Samsung Evo 850
Silverstone 900 watt
Thermalright Ultra 120 Extreme
Silverstone Raven (1st edition)
Operating System
Windows 10 Spy Delux
Xstar 27" PLS 1440p
Keyboard
Wireless ergonomic
Mouse
Logisys Wireless trackball
PhotonFanatic is offline
post #2 of 45 (permalink) Old 01-07-2020, 04:28 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1267 (Unique: 689)
best?
step one: lower room temperature to -273.144 C
step two: fin
https://timesofindia.indiatimes.com/...w/44907265.cms
any other idea either isn't the best or it isn't possible
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 45 (permalink) Old 01-07-2020, 04:42 PM
Overclocking since 1998
briank's Avatar
Rep: 47 (Unique: 40)
The Pook is spot on. But if you can't chill your room quite that cool, the actual best case air cooling is achieved by servers. If you look at how a server is designed, the box is completely sealed with only openings in the front and back. Fans pull air in the front and move it at a very high speed across all the components before expelling it out the back. Linear air speed over the components is the most important metric when you are cooling components with air.
Many cases out there have venting all over the place and that ruins any kind of evenly distributed, front to back (or bottom to top) airflow. Even the good ones like a Fractal case still would need to work to really seal it up well.
Ryzen 9 3950X
Gigabyte X570 Aorus Ultra
Powercolor 5700XT Red Devil
TridentZ B-die @ 3733CL16
Samsung 970 Pro
Adata XPG SX8200 Pro
Optical Drive
BD-RE
Seasonic Prime Titanium 750W
Noctua NH-D15
Fractal Define R5
Operating System
Windows 10 Home
LG 27GL83A-B 27" Nano-IPS
Keyboard
Corsair K68 Cherry Reds
Mouse
Razer Deathadder
7700K Delid @5.1GHz @1.4V
Asus Z270F Strix
Asus RX480 Strix @ 1400MHz
Corsair Vengance PC3200 2x8GB
Sandisk Ultra II 960GB
Samsung 970 Pro
2 x 3TB HDD
Optical Drive
LG BD-R
Seasonic Prime 750W Titanium
Noctua NH-D15
Fractal Define R5
Operating System
Windows 10 Home
Dell 27" 1080p
Mouse
Razer DeathAdder
briank is offline
post #4 of 45 (permalink) Old 01-07-2020, 04:47 PM
Fix it till its broke
Owterspace's Avatar
Rep: 6 (Unique: 4)
If heat rises in your case then you aren't moving enough air
3770K @ 4700 1.375v|Le Grand Macho RT/TY-143|Asus P8Z77-V|8GB G.Skill Mix @ 1100 9-11-9-28 2T 1.68v|Intel 545S @ Raid 0|EVGA GTX 980 Classified @ 1500/2001|CM Silent Pro M2 850|FD Meshify C TG
X5690 E.S. @ Stock+Turbo|True Spirit 140 Power/TY147B|Asus Rampage III Formula|10GB G.Skill Mix @ 666 8-8-8-24 1T 1.575v|Intel 520|EVGA GTX 970 FTW ACX 2.0 @ 1404/1753|TT TP650|FD Define R4
Owterspace is online now
post #5 of 45 (permalink) Old 01-08-2020, 07:10 AM
doyll's Avatar
Rep: 1678 (Unique: 932)
'Heat rises' is false belief. What heat does is cause air to expand/become lighter .. so warmer/warmer air is ligher than cooler/heavier air so it moves up, but in our applications with even a very weak fan the fan is many times more powerful at moving the air .. in other works forget all about warmer air rising because fans easily overpower it.
Mounting cooler to flow air up is problematic;
1/ Case airflow has to turn at least once (air coming in front of case) or twice (in bottom, over GPU turning toward mobo, then turning up into cooler.
2/ Turning airflow 90 degrees creates a lot of turbulence and turbulence disrupts airflow lowering volume of airflow reaching cooler.
You would be much better off using a case with good front to back airflow with a couple good front intake fans, removing all PCIe back slot covers to increase rear vent area around GPU thus better front to back airflow, lower air temp into coolers thus lowering component temps.
If you want a bottom to top airflow case, Silverstone has some you might want to look at.
Honestly, a case with good venting front and back with good fans cools very well without needing to use noisy squirrel cage fan GPU.
As PSU draws air in it's van vent and out it's back, why remove it from the case?
doyll is offline
post #6 of 45 (permalink) Old 01-08-2020, 04:26 PM - Thread Starter
Well I guess I should have been more specific lol. I figured it would be obvious from the wording in the op that I meant something most people could achieve at their house, with common ambient temperatures that you'd find in the houses of the world. Of course that will vary, but not by hundreds of degrees.
Anyhoo, as for the PSU, I was thinking that you might get some small measure of heat soak going on. If you could put your hand on it (or under it) anywhere and feel some heat, that would be heat that was radiating out into the case. At least to some small degree.
Bang for the buck
(12 items)
Gigabyte Z77x UD3H
evga GTX 970 SSC
Samsung Evo 850
Operating System
Xstar 27" PLS 1440p
Keyboard
Wireless ergonomic
Mouse
post #7 of 45 (permalink) Old 01-08-2020, 04:59 PM
Never Finished
airisom2's Avatar
Rep: 272 (Unique: 209)
You could get a test bench and put a box fan in front of it. Any major dust would just blow off from the pressure of that fan. If you need a case, something like the carbide air 740 would be a good start. Graphics cards love that bottom intake.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #8 of 45 (permalink) Old 01-08-2020, 05:19 PM
RIP OCN
Rep: 28 (Unique: 21)
You got your answer from a few different people in a few different ways, @The Pook and @doyll have given you the following insight; fans, directed air flow, and lower ambient temperature. The best air setup is a nice cool room and a good fan setup. Orientation does not matter compared to directed air flow and air temperature, as convection in air is weak, and therefor should not be considered in the design.
With the PSU, you should orientate it so the majority of hot air is directed out of the case. If there is still heat radiating, setup fans that will pull air from outside,across the psu, and out the back of the case to remove this heat from the case.
anti-clockwize is offline
post #9 of 45 (permalink) Old 01-08-2020, 05:56 PM
Himo5's Avatar
Rep: 87 (Unique: 57)
The idea of overturning the standard front-to-back air cooling plan and doing away with all that heavy, RGB friendly glass is not so far fetched, to my way of thinking.
The pattern of PC building that concentrates on cooling the GPU and the CPU that has recently been disrupted by the developement of M.2 storage between the PCIE connectors is about to be further disrupted by Renoir and the prospect of a powerful, 8 core 16 thread APU.
So it becomes reasonable to think of isolating the cooling channels in a server/HTPC build from each other by switching from a horizontal to a vertical plan in the older, non water cooling type of case with drive cages behind the front panel.
A twin tower cooler with 140mm fans blowing up through each tower from beneath and a powerful 140mm top case fan would create enough suction to negate the disadvantage of having a 90 degree turn at the foot of the wind tunnel using a side fan above the PSU blowing cool air onto the M.2 storage.
Drive bay cooling could then be designed for blowing cool air from below and from the motherboard side of the case and expelling it above and from the other side of the case using double doors on both sides of the case to hold the fans.
Further cooling could also be attempted on the back of the motherboard, drawing cool air up over the rear of the CPU socket and the VRM arrays with another side fan.
Himo5 is offline
post #10 of 45 (permalink) Old 01-08-2020, 06:05 PM
Owterspace's Avatar
Rep: 6 (Unique: 4)
I have 5x 120x38s on a controller in my case and a TY147A for 4 in 2 out and have no problems with case flow. My glass panel doesn’t get warm at all. Problem is people want silence, and high performance.. not gonna happen. 50cfm fans are laughable in my opinion, no matter how many you have. Dust filters are good for filtering air, but not helpful when it’s air you want to move. I have an open bench and get far better results in my case.
