Only rear exhaust, what kind of fan is best? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 52 (permalink) Old 01-22-2020, 11:50 AM - Thread Starter
What's a computer?
Rainmaker91's Avatar
Rep: 105 (Unique: 80)
Quote: Originally Posted by doyll View Post
Single high pressure rated rear fan will move enough air to cool HDD and basic system running them. Keep keep in mind this Sharkoon case is not designed to do anything but being a RAID station.
See that's what I thought. Still though, are you sure a high pressure fan would be better than an air flow focused fan when it's placed so far behind the obstruction itself?
Quote: Originally Posted by keikei View Post
If you're bored, cut out the rear and mesh it out with no fan. It wont be pretty, but you'd get better airflow.
Are you sure about that, if there is no fan there will be no air flow at all no matter how perforated teh case is. A restrictive rear panel might also help with guiding the air to exactly where you want it. So let's say I perforated the rear and mounted a fan there, then I would be far more likely to draw in air from the rear rather than the front and site of the case which is how the harddrives would be cooled to start with. Keep in mind that there are absolutely no front mounted fans in this case. The only fanst in the case are a single rear mounted 120mm fan and a 80mmx15mm fan in the Delta branded PSU.
Rainmaker91 is offline
post #12 of 52 (permalink) Old 01-22-2020, 11:52 AM
Shawnb99's Avatar
Rep: 55 (Unique: 36)
Quote: Originally Posted by ThrashZone View Post
Hi,
None
The entire back of a case is open
If anything remove all pci-e slot covers = boom done.
Isn’t this the back? If so cut out the fan girl part of it and fit in the S12 rather then paying more for the A12, you won’t need the static pressure without the grill, more airflow the better
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #13 of 52 (permalink) Old 01-22-2020, 11:55 AM
Overclocker in training
ThrashZone's Avatar
Rep: 169 (Unique: 102)
Hi,
No idea
Cut holes in back or remove side panels
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #14 of 52 (permalink) Old 01-22-2020, 11:55 AM - Thread Starter
What's a computer?
I see the argument you are making, and I might do that though it wouldn't really increase the flow all that much. Still it's worth considering I guess.
post #15 of 52 (permalink) Old 01-22-2020, 11:57 AM
connectwise's Avatar
Rep: 44 (Unique: 42)
I second doyll, and I recommend NF-P12, which has higher pressure and more air flow than your current.
connectwise is offline
post #16 of 52 (permalink) Old 01-22-2020, 12:03 PM
doyll's Avatar
Rep: 1689 (Unique: 935)
Stock rear vent grill is low airflow resistant so won't make much difference.
Edit:
Cut out stock vent grill at edges of circle for less airflow restriction.
doyll is offline
post #17 of 52 (permalink) Old 01-22-2020, 12:04 PM
ThrashZone's Avatar
Hi,
Just remove the side panel or buy a new case.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
10900k
EVGA 1000P2
Corsair 450D
Operating System
post #18 of 52 (permalink) Old 01-22-2020, 12:08 PM
doyll's Avatar
Removing side panel likely will make little to no difference. In fact HDDs and other components could end up running hotter rather than cooler.
doyll is offline
post #19 of 52 (permalink) Old 01-22-2020, 12:24 PM - Thread Starter
What's a computer?
Precisely the problem.
Anyway here is some pictures that shows the case, all should be fairly self explanatory but there is one that is of the side door which is there to show that the fan pull air from both the front and the side of the case.
post #20 of 52 (permalink) Old 01-22-2020, 12:28 PM
ThrashZone's Avatar
Hi,
Why not just buy a real case.
Sure you could fine one for 50.us somewhere.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
10900k
EVGA 1000P2
Corsair 450D
Operating System
