Only rear exhaust, what kind of fan is best? - Overclock.net - An Overclocking Community
post #1 of 51 (permalink) Old 01-22-2020, 10:30 AM - Thread Starter
What's a computer?
Rainmaker91's Avatar
Rep: 97 (Unique: 73)
I recently bought myself a used raid station/case to use for my external drives (http://www.sharkoon.com/product//12916), and it comes with a single rear exhaust fan (upper rear like in most ATX cases). The specific fan that came in it is a Noctua NF-S12 ULN, which is a really good fan for what it is, but I am somewhat curious if as different kind of fan might be a better choice to keep all that spinning rust cool.
So let's pose a question: If you had a simple computer case with the entire front covered in a massive harddrive cage and no option to mount any fans anywhere other than at the upper rear of the case. Which fan would you personally choose for such a task? Static pressure? Air flow focused? thick vs slim? A more balanced approach?
Feel free to make whatever choices you want within the posed requirements (only 1 fan and 120mm size as anything larger won’t physically fit). Personally I would want to keep it under 1000rpm, but feel free to argue anything you want.
Edit: Had to rephrase the question somewhat. I'll also upload internal pictures ones I'm done copying some files on one of the internal drives to show what I have to work with.
Rainmaker91 is online now
post #2 of 51 (permalink) Old 01-22-2020, 10:44 AM
Shawnb99's Avatar
Rep: 48 (Unique: 31)
Could always cut out the fan grill on the back and stick with the NF-S12A. The NF-A12x25 will likely be more expensive and it''ll be louder to push as much air as the NF-S12A
I have both types in my case. The NF-A12x25 is noticeably louder.
If you do want to control the fan, find a fan controller that can do voltage control and control the speeds that way
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 51 (permalink) Old 01-22-2020, 10:59 AM - Thread Starter
What's a computer?
I have no issues with modifying it, I'm just curious as to if a static pressure fan would yeild any real benefit over the current setup. As for fan control... there is no need at the moment as the PSU in this thing is so lound that I'm contemplating putting in a 25mm 80mm fan mounted on the outside of the PSU jsut to get it a bit more quiet (it's an SFX supply though so I am also just contemplating swapping it out rather than throwing money on it, as I'm expecting to have to swap out the caps as well).
Still though, what sort of fan is most suited for a case with only a rear fan mount? I'm genuinely curious, because if it only had front mounts I would have slapped in some radiator optimized fans for sure (Eloops, Gentle Typhoons, NF-F12, NF-A12, ML120... and so on).
post #4 of 51 (permalink) Old 01-22-2020, 11:37 AM
Fix it till its broke
Owterspace's Avatar
Rep: 6 (Unique: 4)
I would get a strong 120x38 and leave those Noctuas alone
Owterspace is offline
post #5 of 51 (permalink) Old 01-22-2020, 11:41 AM
Overclocker in training
ThrashZone's Avatar
Rep: 128 (Unique: 84)
Hi,
None
The entire back of a case is open
If anything remove all pci-e slot covers = boom done.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #6 of 51 (permalink) Old 01-22-2020, 12:03 PM
waifu for lifu
keikei's Avatar
Rep: 326 (Unique: 245)
The rear vents leave little to be desired. Are you able to take temps of the case?
PCMR
(18 items)
AMD RYZEN 7 1700
ASROCK TAICHI X370
EVGA RTX 2080 Ti XC2 ULTRA
G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200
WD Red 4TB NAS HDD (x2)
8TB Seagate Barracuda HDD (x2)
SAMSUNG 860 EVO SSD 1TB
WD Blue SSD 2TB
EVGA SuperNova 1300 G2
Noctua NH-U14S (CPU COOLER)
Cooler Master JetFlo 120mm Blue LED Fan (X6)
LIAN LI PC-V760B
Operating System
WINDOWS 10 64
Dell UltraSharp UP2718Q - LED monitor - 4K - 27"
Keyboard
LEOPOLD FC980M / MAXKEY SA CHOCOLATE KEYSET
Mouse
LOGITECH G305 WIRELESS GAMING MOUSE
Audio
Sennheiser HD 598 Cs Headphones
Other
Real Arcade Pro. 4 Kai Joystick modded
keikei is online now
post #7 of 51 (permalink) Old 01-22-2020, 12:18 PM - Thread Starter
What's a computer?
I could try, but do remember that this is ony for cooling harddrive of which I currently have 4 mounted, but the case can take a total of 8 3.5" drives.
Now there is some actual air flow even if it's only a single S12a (actually think it's a s12a ULN) so it's doing something, but I'm still really curious if there would be any benefit to utilizing a high static pressure fan instead of a regular case fan optimised for non obstructive air flow like the S12a. I have some Eloops 1900rpm fans, some ML120s and an old Papst 38mm thick fan laying around (some for future projects, some are just spares). So I can do experimenting, but I'm honestly curious on the communitys take on such a specific use case.
I'll update the original post to be more clear as to what I'm actually asking.
post #8 of 51 (permalink) Old 01-22-2020, 12:25 PM
ThrashZone's Avatar
Hi,
Hard drive cages
Only difference would be to add fans directly too each side of the hdd cage
Otherwise fans other places won't do anything.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 51 (permalink) Old 01-22-2020, 12:38 PM
doyll's Avatar
Rep: 1678 (Unique: 932)
Single high pressure rated rear fan will move enough air to cool HDD and basic system running them. Keep keep in mind this Sharkoon case is not designed to do anything but being a RAID station.
doyll is offline
post #10 of 51 (permalink) Old 01-22-2020, 12:40 PM
waifu for lifu
keikei's Avatar
If you're bored, cut out the rear and mesh it out with no fan. It wont be pretty, but you'd get better airflow.
PCMR
(18 items)
AMD RYZEN 7 1700
ASROCK TAICHI X370
WD Blue SSD 2TB
LIAN LI PC-V760B
Operating System
WINDOWS 10 64
Keyboard
Mouse
Audio
Other
