What kind of heatpipes are usually used in air coolers? - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 01-30-2020, 01:47 PM - Thread Starter
Rep: 13 (Unique: 12)
Sintered, grooved, meshed??
Shenhua is offline
post #2 of 26 (permalink) Old 05-06-2020, 10:06 AM
carmack
Rep: 3 (Unique: 1)
Sintered.
carmack is offline
post #3 of 26 (permalink) Old 05-06-2020, 06:17 PM
- Insanity Beckons -
Elrick's Avatar
Rep: 178 (Unique: 93)
Quote: Originally Posted by carmack View Post
Sintered.
My GAWD, is that a Thermalright carcass we are viewing here .
Elrick is online now
post #4 of 26 (permalink) Old 05-07-2020, 05:01 AM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
Sintered.
My GAWD, is that a Thermalright carcass we are viewing here [IMG class=inlineimg]/forum/images/smilies/poke.gif[/IMG] .
RIP
X5690 E.S. @ 4200MHz 1.35v/Thermalright Le Grand Macho RT/TF8/TY-143
Asus Rampage III Formula @ 200/3600/3600 Bios 0702/Intel 545S 256GB x2
16GB G.Skill + Super Talent Mix @ 800MHz 9-9-9-24 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1490/1900|Asus Xonar Essence ST/KEF M500
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x3/ZM-MFC2
Owterspace is offline
post #5 of 26 (permalink) Old 05-07-2020, 06:25 AM
carmack
Rep: 3 (Unique: 1)
It can still cool. I deliberately done this to determine how much heat can it remove with only one heatpipe.
carmack is offline
post #6 of 26 (permalink) Old 05-07-2020, 05:09 PM
Owterspace's Avatar
Rep: 7 (Unique: 4)
What were your results?
post #7 of 26 (permalink) Old 05-08-2020, 12:16 AM
ltpdttcdft's Avatar
Rep: 37 (Unique: 31)
That's not a TRUE anymore.
Now it's a FALSE
ltpdttcdft is offline
post #8 of 26 (permalink) Old 05-08-2020, 01:41 AM
carmack
Rep: 3 (Unique: 1)
The amount of heat a heatpipe can transfer depends on diameter, length, position and die size. In tower cooler heatpipes go from both sides of the base; it s basically double. These are the resaults on RX 580 (232 mm2) in vertical position; it can cool close to 100 W. If i raise power just a little bit, it couldn t stabilize the temperature no more. I tried it on i5 4590 and the resaults were similar; it managed about 100 W in vertical position (i dont have pictures).
Then, there is scythe ashura on rx vega 64. In vertical position it cools close to 400 W. Upside down, however, it couldn t stabilize the temperature (I aborted the test).
Name:	Ashura upside down.jpg
carmack is offline
post #9 of 26 (permalink) Old 05-08-2020, 05:04 AM
deepor's Avatar
Rep: 483 (Unique: 328)
This is the first time I hear about this upside-down problem. Does it happen with all heatpipes?
I had the idea to get an Noctua NH-D9L to try to mount it on a graphics card. The NH-D9L is a very small dual-tower cooler that's just 110mm high so it when it's mounted upside-down on a graphics card it would fit in any ATX case.
This upside-down problem means that my plan is bad and can't work. Did I understand this right?
deepor is offline
post #10 of 26 (permalink) Old 05-08-2020, 05:45 AM
carmack
Rep: 3 (Unique: 1)
The problem is that it must cool 400 W upside down. It will cool 200 W upside down no problem. Noctua NH-D9L has only 4x6 heatpipes, but they are shorter ( in comparison to Scythe Ashura). Shorter heatpipes can transfer more heat, so they are around the same (NH-D9L and scythe ashura) in heat transfer capability.
I also tried small scythe byakko (horizontal) on Rx Vega 64 and it managed to cool 350 W. Bykko has only 3x6 but they are short.
To cool very high TDPs on GPUs tower cooler has to be in horizontal or vertical position (best position). The same is true for CPU s but they generly have low TDP s (100-200 W), so it will cool about the same in all positions..
Name:	Scythe_byakko_rx vega 64.jpg
Name:	scythe_byakko on RX Vega 64.jpg
Name:	Scythe byakko_1800_2200_350 W.png
carmack is offline
