3950x + Noctua 15 + Fraktal R6 (no OC). How do I set up the case fans? - Overclock.net - An Overclocking Community
post #1 of 55 (permalink) Old 02-10-2020, 04:40 PM - Thread Starter
Rep: 0
I want a new computer and I like this setup. I like the dampening features of R6 because I hate noise, I got the R4 and its really silent.
However, with the 3950x I was consdering if it's worth it that I replace the stock fans. If so, which fans should I buy, and how do I place them?
Also should I use 2 fans at the front of 140mm, or 3 of 120mm? I was told with 3 its better airflow.
I will not do any OC. I will be making music, editing video and gaming. I dont consider Aira64 and Prime95 as realistic real life use cases so I dont consider the high temps achieved by those benchmarks as a problem in terms of not having AIO with the 3950x so I went the Noctua 15 route. I just want to improve the case airflow because I was told the Define R6 is a solid case but the stock fans are rather crap.
WMOman is offline
post #2 of 55 (permalink) Old 02-10-2020, 05:08 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1324 (Unique: 703)
tooling on the R6 is the same as the S2, no? if so you can run 3 140mm even though the spec page says 2.
you don't need an AIO even if you were OCing, the temp differences on a D15 and a 280/360 AIO aren't that significant anyway.
fans on the bottom are useless, don't bother with those. 2-3 front and one rear is enough, maybe add a second rear exhaust in the top back but you don't need to.
if you want cheap, buy Arctic P14s (they come in a 5 back for $25) and fill 3 in the front as intake and two in the back as exhaust and job done. Set them all on the fan controller and set a curve that sounds nice and call it a day.
the Phanteks MP/XP are worth a look too, they fairly often go on sale for ~$10 and they're a steal at that price. Just avoid the SP, they're not PWM.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #3 of 55 (permalink) Old 02-10-2020, 07:12 PM - Thread Starter
Rep: 0
Do you mean the front? on the pic you can see you can run x3 120mm but only x2 140mm.. im not sure x3 140mm would fit by looking at the pics
maybe there is a way to sacrifice the 5.25 bay but I would like to have a blueray reader there, sometimes it can be handy to be able to read cds.
Would x3 120mm make a difference from x3 140mm ?
Any other alternatives u wanna mention? I dont mind spending money on this, I gotta keep the 3950x cold even if im not doing OC, just for sanity. My current build is an old ass 12 year old quadcore, i plan to extend this cpu for a good 10 years again, so with decent cooling and no OC I hope I can do it.
WMOman is offline
post #4 of 55 (permalink) Old 02-10-2020, 11:18 PM
poah's Avatar
Rep: 7 (Unique: 6)
better the cooling the slower the fans you can run. Nothing to do with OCing. I don't run PBO with my 3900x and its water cooled.
poah is offline
post #5 of 55 (permalink) Old 02-11-2020, 02:12 AM
Rep: 9 (Unique: 9)
Go for phanteks enthoo pro M if you want 5.25 bay.
If you want silence, you want a case that impedes airflow as little as possible, the minimum number of fans and speed to get good airflow and manually tune their rpm curves.
Also, choose a GPU model with a good radiator.
In the case of a ryzen you want to manually tune the frecuency and voltage, and/or tune up the RPM on the cooler fans, one, because of its boost, and 2 because of its thermal density. You don't want the cooler ramp up and down everytime you load a website.
For example, something like this:
Phanteks enthoo pro M
3x120mm sw3 mounted on the front and the case fan mounted in the rear
And then treat the front fans as a group and use same speed on all of them, and the rear fan make it ramp up a bit later.
For example 0-35°C 400 RPM on all fans and cooler, 55°C 700rpm for front fans and cooler, 65°C 1000rpm front fans and cooler, 700rpm rear. Next point should be set up considering your preference and tolerances.
That should keep your PC almost dead at low loads, and very manageable under heavy loads.
For even better results, you can still add another level of configuration/difficulty. Manually tune up the CPU, and after you find the point where "it hits the wall", drop 150mhz, and as much voltage as you can, then set up the fans accordingly. You should be able to drop a ton of voltage, and thus temps/noise. GPU can be modded with case fans attached with zipties like in the picture, and the improvement in noise is awesome.
Shenhua is offline
post #6 of 55 (permalink) Old 02-11-2020, 07:48 AM
doyll's Avatar
Rep: 1682 (Unique: 933)
Below link is to a basic guide to how airflow works and how to optimize case airflow.
https://www.overclock.net/forum/22319249-post5.html
What model fans do you plan to use in this case?
Basically, remove all PCie back slot covers (even vented ones block 50-60% of airflow) to increase rear vent area around GPU, remove HDD cages so they don't block front intake airflow, add 2x good pressure rated 140mm front intakes and maybe a bottom intake if needed. Block any opening in fan mounting panel not covered by intake fans because we don't want the air the fans are pushing into case to leak back in front of them. Do not use the top vents, especially the front 2/3rds!! Using them as exhaust draws cool front intake air up and out of case before it reaches CPU and is replaced by heated air from GPU!! As intake they disrupt front to back airflow mixing heated GPU exhaust with cool intake air. I rarely (almost never) use exhaust fans because using them is like using push/pull on radiator or cooler .. maybe a few degrees cooler at full speed, but at same noise level just intakes cool the same. How many intake fans / how much intake airflow is needed depends on how many and how much air your CPU and GPU coolers use.
doyll is offline
post #7 of 55 (permalink) Old 02-11-2020, 01:38 PM - Thread Starter
Rep: 0
I don't which fans to buy, that is what im asking. Could you give me links of fans to buy for the R6?
Something like this:
https://noctua.at/en/products/fan/nf.../specification x3 at the front
https://noctua.at/en/products/fan/nf.../specification at the back
https://noctua.at/en/products/fan/nf.../specification x2 bottom to push fresh air into the GPU and HDD's??
See here better:
How do you rate this?
Lets also compare the default fans of R6 which if my research is correct then they are the Dynamic X2 GP 14. Specs from their site:
Now the noctuas:
Noctua lists their airflow in m3/h... lets make conversions:
A14:
Airflow
140,2 m³/h
Airflow with L.N.A.
115,5 m³/h
in CFM:
82,51 CFM
67,98 CFM with L.N.A (whatever this is)
S12A:
Airflow
107,5 m³/h
Airflow with L.N.A.
83,2 m³/h
in CFM:
63,27 CFM
48,96 CFM
The fraktal one is 68 CFM.... so I don't see how those would push more air than the default ones. Doing the numbers comparing the Noctua ones with the fraktal one seems dissapointing..??? unless im missing something it doesn't seem to be worth it.
Artic p14 one was recommended here too:
https://www.amazon.com/ARCTIC-P14-Va.../dp/B07HCKWF2X
They say 72.8 CFM.. from 68 isn't that much?
This Phantek one:
http://www.phanteks.com/PH-F140XP.html
Max Airflow
40.9 - 85.19 CFM
The 120 version:
http://www.phanteks.com/PH-F120XP.html
Max Airflow
23.0-61.6 CFM
So im confused. 68 CFM default ones is better than all noctuas? and I dont see big difference in other ones. The Max Airflor in 140 Pantek is 85 CFM, so I see bigger difference from Fraktal, but the 120 ones are less CFM... but I assume since I would put 3 at the front, the sum is better airflow? Then we have the L.N.A thing on the Noctuas which I dont know what that is. Maybe im missing something.
WMOman is offline
post #8 of 55 (permalink) Old 02-11-2020, 02:45 PM
poah's Avatar
Rep: 7 (Unique: 6)
and add up the cost of those fans and compare them to the arctic P12/P14
poah is offline
post #9 of 55 (permalink) Old 02-11-2020, 03:53 PM
doyll's Avatar
See here better:
Now the noctuas:
A14:
Airflow
140,2 m³/h
Airflow with L.N.A.
115,5 m³/h
in CFM:
82,51 CFM
S12A:
Airflow
107,5 m³/h
Airflow with L.N.A.
83,2 m³/h
in CFM:
63,27 CFM
48,96 CFM
This Phantek one:
Max Airflow
40.9 - 85.19 CFM
The 120 version:
Max Airflow
23.0-61.6 CFM
First thing, take anything Poah's posts with lots of salt. Some times his posts are helpful but often they are not.
Second, we don't need you to post the spec of fans you are considering. Some of us know how the fans actually work not based on specs but based on actual use and comparisons with other top tier fans.
As for what fans to get depends on what is available to you and their prices. Can you post some links to online sites you can buy from? That way we can compare prices of serveral know good fans and suggest a couple that are the most cost effective.
doyll is offline
post #10 of 55 (permalink) Old 02-11-2020, 07:24 PM - Thread Starter
Rep: 0
On this shop for instance:
https://www.pccomponentes.com/ventil...suplementarios
Honestly I dont care about the money, I want the best stuff, I only update once every 10 years anyway. However looking at the specs I don't see huge differences in airflow compared to default R6 fans so im confused.
WMOman is offline
Tags
3950x
