Corsair H60 install - Overclock.net - An Overclocking Community
Corsair H60 install
post #1 of 27 (permalink) Old 02-12-2020, 07:37 PM - Thread Starter
mooch49's Avatar
Rep: 4 (Unique: 3)
Corsair H60 install
I have the latest edition, which I believe is from 2018. I'm stuck on the last step before plugging everything in. I hope somebody might be able to help me. I don't understand when you have to tighten the two screws, the ones where the screwdriver type are at the bottom. I've watched countless and countless of videos. There is no hole for those screws to go through. The pump just keeps on sliding on the compound. I probably am missing the easiest part, but I just can't figure out how to get the pump to stay over the cpu. I think older models you click it to lock it then turn it. But I don't see anything to lock it against.
mooch49 is offline
post #2 of 27 (permalink) Old 02-12-2020, 07:55 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 611 (Unique: 504)
There is a backplate (goes behind the mobo) and 4 screws to mount the waterblock/pump to the threads of the backplate.
See my pic of the Corsair H60 mount in push/pull:
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is online now
post #3 of 27 (permalink) Old 02-12-2020, 08:05 PM - Thread Starter
mooch49's Avatar
Rep: 4 (Unique: 3)
Is it the original backplate?
mooch49 is offline
post #4 of 27 (permalink) Old 02-12-2020, 08:09 PM
I Love this Hobby!
You get a backplate with the Corsair H60, since I recently transitioned the PC from water back to air, I just reused the Swiftech Apogee II backplate.
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
Optical Drive
Noctua NH-D15
Operating System
Win 10 Pro 64bit
Keyboard
Mouse
Logitech G502 Hero
Mousepad
Audio
Other
Optical Drive
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Audio
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
post #5 of 27 (permalink) Old 02-12-2020, 08:13 PM - Thread Starter
mooch49's Avatar
Rep: 4 (Unique: 3)
You think I could use the Cooler Master Hyper 212 Black Edition. The problem I'm seeing is the backplate that Corsair gives is in two separate metal pieces. How do I connect them to go under the motherboard?
mooch49 is offline
post #6 of 27 (permalink) Old 02-12-2020, 08:20 PM
I Love this Hobby!
The manual should have pics and instructions on how to properly mount for your socket.
If you can't figure it out, look at the backplate you're suppose to use but can't figure out how to mount (sounds like it's broken in half) and as long as the screw stands are the same length it should work like the Swiftech backplate worked for me.
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
Optical Drive
Noctua NH-D15
Operating System
Win 10 Pro 64bit
Keyboard
Mouse
Logitech G502 Hero
Mousepad
Audio
Other
Optical Drive
Operating System
Win 7 Pro 64bit
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Audio
Optical Drive
LG DVD R/W
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Mouse
Mousepad
Audio
post #7 of 27 (permalink) Old 02-12-2020, 09:44 PM
OG AMD
Redwoodz's Avatar
Rep: 596 (Unique: 465)
Yeah aftermarket backplates are kinda universal, as long as the screws are the right length and size.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #8 of 27 (permalink) Old 02-12-2020, 10:33 PM
MythTFLfan29's Avatar
Rep: 39 (Unique: 31)
Might be a dumb question but are you using an Intel bracket on AMD CPU socket or vice versa? Looks like the brackets I got with my H60 (2015? version) had both an AM3 and Intel 115x bracket. Which CPU do you have, Intel or AMD? Or better yet how about a parts list of stuff you're working with. Just wondering if this is part of the confusion... The X bracket should go behind on the Intel board with the 4 screws on top, while if you're on an AMD board you don't use the X bracket and just use the 2 hole top bracket with the small handle pin inserts that lock into the standard mounting black clips (if that makes sense). You shouldn't be using both (or all 3) brackets at the same time. I'm not saying this to chide/belittle or assume you don't know what you're doing, I'm just trying to figure out what you have going on with the info you provided. I hope this helps in some way!
MythTFLfan29 is offline
post #9 of 27 (permalink) Old 02-12-2020, 10:47 PM - Thread Starter
mooch49's Avatar
Rep: 4 (Unique: 3)
I have a 3600. The AMD brackets come into 2 metal parts. It's no longer just 1 piece, which makes it difficult to secure the mount. This is the first time using an AMD cpu, it's been a nightmare to say the least. Their stock cooler isnt that bad, I was just looking for cooler temps. Maybe AMD's processor run hotter than I'm used to. I don't know. I get temps in the 80's. So I don't know what's going on. I just ordered my 3rd cooler, the new Noctua low profile for AM4. Hopefully it'll be the charm.
mooch49 is offline
post #10 of 27 (permalink) Old 02-12-2020, 11:07 PM
Temps can get higher on them than they used to under older sockets but performance has also increased greatly too. My 2700 with the stock cooler would sometimes hit 40C and the fan would ramp up a bit, and I didn't care for the noise it made so I too went about a different cooler for quieter/cooler performance. I just saw the 2 piece design (my older H60 still had the single piece one) and that does look like a pain. Do the points on each of the 2 clips groove in under the CPU cooler top plate/pump area to at least keep it mounted down while you wiggle the little square clips under the black motherboard standoff brackets? I'd hope Corsair designed it well enough to hold it down but maybe not with what you're saying....
Edit: Meant 40C under basically idle settings, not load just for clarification
OK just watched a video here
. He seems to get the 2 pieces slid into the pump in what looks like slotted cutouts to hold them in place and then attaches the little -[] piece into the bottom of the screw and hooks it over the corner of the black motherboard standoff/brackets. Then tigtens them afterwards. The screw should only be tightening that funny little piece that looks like a box with a gear shift out of it lol and not actually going into any screw holes.
Pic of it here https://www.corsair.com/us/en/Catego...t/p/CW-8960011
Hope that makes sense.
