Best CPU Cooler under 135mm. - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 02-24-2020, 07:47 AM - Thread Starter
gtz
gtz's Avatar
Rep: 65 (Unique: 58)
Like the title states, what is the best CPU cooler under 135mm. This will be cooling a stock 3900X (with XFR enabled).
Thanks in advance.
Edit:
I am leaning towards the Raijintek Pallas. Seems like a good price for the performance.
Ultra Instinct
(14 items)
AMD RYZEN 9 3900X
GIGABYTE X570 GAMING X
ZOTAC AMP NVIDIA RTX2080TI
32GB (4X8GB) CORSAIR LPX @ 3466 CL16
WESTERN DIGITAL BLACK 500GB NVME (OS)
SANDISK PLUS 960GB SSD SATA III (STORAGE)
CRUCIAL MX500 750GB SSD SATA III (IMPORTANT BACK UP)
EVGA SUPERNOVA G2 850W
ABATAP 6 PIPE COOLER
RAIJINTEK ASTERION EATX CASE
Operating System
WINDOWS 10 PRO
SCEPTRE 4K 27"
Keyboard
AZIO MECHANICAL BROWN
Mouse
AZIO
gtz is online now
post #2 of 23 (permalink) Old 02-24-2020, 10:36 AM
doyll's Avatar
Rep: 1683 (Unique: 934)
First thing is to find out what case you are using for this build. Only way flat coolers work is if is case has a vent directly over CPU for either supplying cooler with cool air or exhausting cooler heated air. If this is your sig rig, case has 180mm CPU clearance and is designed for front to back airflow, not side to motherboard. This means a small tower cooler will likely receive cooler air into cooler becaues it's pushing air through cooler toward rear exhaust venting. Flat cooler with fan pushing air down into cooler air hits motherboard turning out, hit's RAM, GPU, etc turning up along side of cooler and fan where it is then drawn back into cooler fan. End result is 8-12c higher temp air .. which translates into same 8-10c higher CPU temps. Turning flat cooler fan over so it's pulling from motherboard through cooler helps, but there is still not separation of cooler's heated exhaut and case's cool intake airflow.
doyll is offline
post #3 of 23 (permalink) Old 02-25-2020, 06:38 AM
Linux Lobbyist
Rep: 2 (Unique: 2)
like @doyll said, case type is a piece of necessary information.
From Tower coolers your choices are these 4 (in descending order of performanse, though the first 3 should be near one another)
Thermalright Silver Arrow 130 (if u can find it)
Raijintek Delos RBW Rainbow RGB (136mm height, but I'm pretty sure it will still fit)
Thermalright Macho 90
SilentiumPC Spartan 3 Pro
Dogzilla07 is offline
post #4 of 23 (permalink) Old 02-25-2020, 08:03 AM - Thread Starter
gtz
gtz's Avatar
Case is Golden Field M3S. 2 120mm fans mounted on the bottom for intake. Top mounted 120mm as exhaust and rear mounted 92mm as exhaust.
Thank you for the post, I did not even know the Silver Arrow 130 existed.
Ultra Instinct
(14 items)
AMD RYZEN 9 3900X
Operating System
WINDOWS 10 PRO
SCEPTRE 4K 27"
Keyboard
Mouse
AZIO
gtz is online now
post #5 of 23 (permalink) Old 02-25-2020, 08:29 AM
PC Enthusiast
Ashura's Avatar
Rep: 48 (Unique: 36)
Imo, overall the best low profile cooler would be the Noctua C14S.
Good cooling perf., Fan Noise & ease of installation.
For price to perf. the Raijintek Pallas looks pretty great, but cooling a 3900x with XFR enabled might a uphill task.
PolaRyz
(15 items)
Venomous FX
(14 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 3000Mhz 32gb
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mouse
Steelseries Qck Mass
AMD FX 8350
MSI 990FXA Gaming
XFX R9 290 DD
G.Skill RipjawsX 16GB [4x4GB] 1600MHz CL9 @1.5v
Seagate ST1000DM003
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
Dell ST2420L
AOC e2243Fwk 21.5"
Mouse
Razer Deathadder Chroma
Mouse
SteelSeries QcK Mass
Ashura is offline
post #6 of 23 (permalink) Old 02-25-2020, 12:09 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 428 (Unique: 285)
While that may be, it's too tall for this build. It is 140mm with the fan.
ciarlatano is offline
post #7 of 23 (permalink) Old 02-26-2020, 02:40 AM
doyll's Avatar
Golden Field M3S has very poor airflow. Front venting is only on right side and like you said, 90mm rear and 120mm top exhaust venting. Combine extremely poor aiflow with only 130mm CPU clearance and it's not a case I would even consider, even if it was free.
doyll is offline
post #8 of 23 (permalink) Old 02-26-2020, 02:54 AM
PC Enthusiast
Ashura's Avatar
It can be used with the fan mounted under the fins.
Not sure if its efficacy is reduced or not, especially with the rear exhaust fan involved.
PolaRyz
(15 items)
Venomous FX
(14 items)
AMD Ryzen R7 1700x
Asus GTX 1060 6Gb
Seagate ST1000DM003
Toshiba DC01ACA300
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Mouse
AMD FX 8350
MSI 990FXA Gaming
XFX R9 290 DD
Seagate ST1000DM003
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
Dell ST2420L
AOC e2243Fwk 21.5"
Mouse
Mouse
Ashura is offline
post #9 of 23 (permalink) Old 02-26-2020, 04:40 AM
ciarlatano's Avatar
Yes, I was incorrect. My recollection on that failed me.
post #10 of 23 (permalink) Old 02-26-2020, 04:54 AM
OG AMD
Redwoodz's Avatar
Rep: 599 (Unique: 465)
My goodness. Why in all things sane would you cram a 3900X in that little cereal-box for a case?
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is online now
