** Thermalright Black Eagle ** - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 03-22-2020, 09:22 AM - Thread Starter
doyll's Avatar
Rep: 1689 (Unique: 935)
Thermalright says:
The strongest single tower gaming cooler with unique high-quality new focus fan blade Black Eagle is a member of the TUF Gaming Alliance. It has stylish RGB lighting and optimized cooling performance and provides a new air cooling for gamers Experience. Not just cooling. It is THERMALRIGHT’s high-quality CPU cooling device, which can achieve the best cooling effect while meeting your needs for spectacular RGB gaming devices.
Maybe something is being lost in translation, but as capable as Black Eagle looks like it might be, it is definitively not "strongest single tower" out there. Thermalright itself has several single tower coolers with more cooling.
More to come as I gather info and dimensional drawing.
Product Description
Heatsink Specifications:
Dimensions:L120 mm x W42 mm x H158 mm
Weight:470g
Heat pipes: 6mm heatpipe x 5 units
Fin: T = 0.4 mm;Gap=2 mm
Fin pcs: 45pcs
RGB Connector: 3 PIN 5V
Copper Base: C1100 Pure copper nickel plated
Thermal design power:200watt
TY-128 BP FAN Spec
Dimension: L120 mm x W120 mm x H25.4 mm
Weight: 140g
Rated Speed: 600~1500 RPM
Noise Level: 19~23 dBA
Air Flow: 21.76~65.25 CFM
Connector: 4 Pin (PWM Fan connector)
Bearing Type : FDB Bearing
Name:	Black Eagle wip.png
doyll is offline
post #2 of 8 (permalink) Old 04-29-2020, 09:24 AM - Thread Starter
doyll's Avatar
Found a couple images of Black Eagle so thought I would post them.
Really like the looks of base with it's 5x 6mm heatpipes. Should cool well.
Name:	Black Eagle base, top & side.png
doyll is offline
post #3 of 8 (permalink) Old 04-29-2020, 01:53 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
And a video -
ciarlatano is offline
post #4 of 8 (permalink) Old 04-29-2020, 02:28 PM
Never Finished
airisom2's Avatar
Rep: 274 (Unique: 211)
Yet another TUF Gaming alliance product. Maybe this is the Asus version of GPP. You release a product with our branding, and we'll give you some perks or something. Think about it, Asus is their competitor, but they're putting Asus' brand on it.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #5 of 8 (permalink) Old 04-29-2020, 02:46 PM
ciarlatano's Avatar
ASUS isn't really a direct competitor since they don't make air coolers. This is really more a way to get Asus branding on complimentary products and get Asus exposure for said complimentary product.
post #6 of 8 (permalink) Old 04-29-2020, 03:12 PM
Never Finished
airisom2's Avatar
Well maybe not thermalright, but other companies in the loop definitely. I wonder what the fine print is on this so-called alliance?
airisom2 is offline
post #7 of 8 (permalink) Old 04-30-2020, 03:00 AM - Thread Starter
doyll's Avatar
Seems like a way for a bunch of distributors to get their name out. Asus offical TUF Gaming / TUF Gaming Alliance website has 52 brands listed, strangely Thermalright is not on the list, but there are 6 cooler companies with 11 air coolers iisted. 3 are fo them are CLCs. Attached is image of air coolers including Black Eagle even though it's not on Asus TUF list.
Name:	Asus TUF Gaming Alliance coolers.png
doyll is offline
post #8 of 8 (permalink) Old 05-19-2020, 09:36 AM - Thread Starter
doyll's Avatar
I see Black Eagle is releasing in Japan with a price of
7800 (Japanexe yen). At current exchange that is $72.30 and
66.13 (euro). Seems quite expensive when I can buy TRUE Spirit 140 Power for £54.55 delivered to my door.
doyll is offline
