3900x / 3950x. Want to improve cooling. Help? - Overclock.net - An Overclocking Community
post #1 of 51 (permalink) Old 03-27-2020, 12:16 AM - Thread Starter
GoldCartGamer's Avatar
Rep: 0
Long time lurker, recently signed up on the site. I have spent A LOT of time reading through doyll's posts and threads among other places on the internet. Very insightful, but I still had some questions for my particular config / environment.
I currently have the following configuration: https://pcpartpicker.com/user/goldca...r/saved/HnsxGX with a soon to be 3950x that is staring at me as I type this, lol.
I did have to remove a panel to make room for the USB 3.0 cable on the mobo. I have attached a stock photo with a red circle around that panel.
I am looking at case fans and proper air flow on this case. I know the stock case fans are junk. Based on what I have read, it seems it is a good idea to remove the PCIe slots, no exhaust fan, and having 2 to 3 strong intake fans will be plenty.
I was thinking I would have 3 to 4 intake fans and 2 exhaust fans, but my research seems to show that is not necessarily the best route.
I have been down so many rabbit holes tonight on case fans I am a bit cross eyed. Budget and sound are not a concern. I am concerned about performance only. I started out looking at Noctua NF-A14 PWM then read about the Noctua NF-A12x25 PWM. I believe the front of this case blocks part of the air flow of a 140mm fan as well.
I have been happy with my CPU cooler choice, but now worried I picked wrong based on threads on here.
I am just now getting to worry about temps because outside temps will soon go up in my area. It gets pretty hot and humid in my summers. We keep the thermostat set to 68F (20C) during the summer.
I hope I didn't miss anything to get this conversation started. I hope to learn more and perhaps provide a place for others to learn as well.
3950x, Gigabyte X570 Xtreme, Team Dark Pro 16GB (2x8GB), MSI RTX 2080 Ti Gaming X Trio, Arctic Liquid Freezer II 360.
Build list
GoldCartGamer is offline
post #2 of 51 (permalink) Old 03-27-2020, 12:20 AM
Jayrock's Avatar
Rep: 37 (Unique: 35)
Why no exhaust fan????
And the nh-d15 is not a bad choice at all. People just say there are cheaper options that perform in a similar fashion.
I use 2 140mm noctua in the front of my case, and 1 120 in the back. I have the define c, though, which doesn't have all that space towards the front. I get more direct airflow at lower rpm over my components.
I see that you have an EATX, so you'll just need some good cfm from those fronts.
AMD Build
(11 items)
3600x 4.2ghz All-Core 1.3v
MSI x570 MEG ACE
EVGA 2060 Super XC
G-Skill Flare X @ 3600 14-14-14-28
Samsung 970 Evo Plus
Seasonic Prime Platinum 750W
Noctua NH-D15S
Fractal Define C
Keyboard
HHKB Pro 2
Mouse
Logitech G305
Jayrock is offline
post #3 of 51 (permalink) Old 03-27-2020, 07:31 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
I did have to remove the a panel to make room for the USB 3.0 cable on the mobo. I have attached a stock photo with a red circle around that panel.
I have been down so many rabbit holes tonight on case fans I am a bit cross eyed. Budget and sound are not a concern. I am concerned about performance only. I started out looking at Noctua NF-A14 PWM then read about the Noctua NF-A12x25 PWM. I believe the front of thise case blocks part of the air flow of a 140mm fan as well.
No idea what JayRock going on about no case exhaust fans. Haven't used case exhust fans in years. ̶P̶u̶t̶ ̶a̶l̶l̶ ̶o̶f̶ ̶t̶h̶e̶ ̶s̶t̶o̶c̶k̶ ̶f̶a̶n̶s̶ Replace stock fans with 3x 140mm high pressure rated fans, run all 3 in front as intakes and block any openings in fan mounting panel not covered by fans so air they push into case has to flow through case and out the back, not leak thru mounting panel in front and end up going in circles. Also block bottom venting in front of PSU for same reason, so air being pushed in front has to move thorugh case and out back, not leak out bottom. That should be all the case fans you need.
NH-D15 is good cooler, Assuming it fits and doesn't block PCIe sockets because of it's width and centered base. NH-D15S is better because of it's offset base. Other compaint I have is price. There are other coolers just as good for much less money.
Link below is about how airflow works and how to optimize case airflow.
https://www.overclock.net/forum/22319249-post5.html
Ideally monitor airflow temp entering coolers. Above links show how to make a very low cost monitoring thermometer. Air temp into coolers should be no more than 4-5c warmer than air around case intakes. Almost all my builds are 2-3c at most warmer into coolers. That is with both CPU and GPU at full load.
Edit:
doyll is offline
post #4 of 51 (permalink) Old 03-27-2020, 07:55 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
You dont need a 1200 watt PSU for that build its more than double then the machine will ever draw
Or did you buy it already
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #5 of 51 (permalink) Old 03-27-2020, 08:21 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1390 (Unique: 720)
if you are okay with more frequently cleaning your rig and/or don't live in a dusty environment you can remove the top and rear dust filter super easily on the Meshify S2 (and if you're using the top as exhaust then can take it out regardless of your de-dusting laziness ).
the included GP-14 fans aren't really that terrible (going by included-for-free case fan standards), you can use them as exhaust and save a few bucks.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #6 of 51 (permalink) Old 03-27-2020, 08:31 AM
Jayrock's Avatar
Quote: Originally Posted by doyll View Post
No idea what JayRock going on about no case exhaust fans. Haven't used case exhust fans in years. Put all 3 of the stock fans in front and block any openings in fan mounting panel not covered by fans so air they push into case has to flow through case and out the back, not leak thru mounting panel in front and end up going in circles. Also block bottom venting for same reason, so air being pushed in front has to move thorugh case and out back, not leak out bottom. That should be all the case fans you need.
He edited. He said no exhaust. I should have quoted.
AMD Build
(11 items)
MSI x570 MEG ACE
EVGA 2060 Super XC
Noctua NH-D15S
Fractal Define C
Keyboard
HHKB Pro 2
Mouse
Logitech G305
Jayrock is offline
post #7 of 51 (permalink) Old 03-27-2020, 08:42 AM
Stock is too casual~
Veii's Avatar
Rep: 78 (Unique: 46)
As everything is bought already, the only advice i could give for cooling is to actually flatten out the new buying cooler and the Ryzen
Also as i check the setup and you're focused on Mogami XLR cables + the expensive Mic stand = clearly going for quality over quantity
You might want to check out der8auers AM4 mounting bracket - with compatible bracket mounting coolers
That should give you 5-6c more - oh if the paste is not bought, you could try writing OCUK or Caseking
(well or roman directly via business mail) if you can buy a sample of the new Kryonaut Extreme
Except for lapping, the bracket, fixing airflow and a good paste - there's nothing to do
Your last option would be, learning how ryzen 3rd gen behaves and that way lowering predefined voltages for 50-60W less usage
Looking forward to your build
SiSandra Inter-Core Bandwith 14nm Ryzen global #1 | Twitter
Personal Records
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #8 of 51 (permalink) Old 03-27-2020, 09:23 AM
doyll's Avatar
His post reads:
"Why no exhaust fan????"
Like building a system without exhaust fans is going against physics. Reality is what flows into a case must also flow out, and with same or little more exhaust venting and no exhaust fans a case will flow just as well and run just as cool as a case with exhaust fans, and often do it with less noise.
I was wrong saying to use the stock fans. I looked at Dynamic X2 GP-14 PWM with specs of 1.95mmH2O or 105.9cfm @ 1600rpm, high enough pressure rating to overcome filter and grill resistance. Normal Dynamic X2 GP-14 fans are a wimpy 0.71mmH2O or 68.4cfm @ 1000rpm, not even close to high enough pressure rating to overcome grill and filter resistance.
I posted assuming GoldCartGamer already has components listed. If not, shilka is correct, that power supply has way more power than will ever need needed.
doyll is offline
post #9 of 51 (permalink) Old 03-27-2020, 12:25 PM - Thread Starter
Rep: 0
I was saying based on my research an exhaust fan appears to be not needed.
Price is not an issue to me when it comes to building a PC so that's good to hear. I always prefer quality and top performing parts over price and looks.
Hmm yea the space is a bit different in my case versus the C series from Factal. Thanks for the feedback though. What are your idle temps, load temps, and ambient temps?
Why do you say that? For the VRM? My VRM temps stay really cool due to the design of the board. Or at least what I think is cool for VRM's on a motherboard.
Edit:
I saw your recommandation of no exhaust fans and did a bunch of research on that last night. I then remembered some CAD stations I built at a prior employer. We never used exhaust fans and they always had great cooling. I think I even started experimenting with different fans and sizes as well as removal of PCIe slots. I ended up changing employers not too long after I started those tests. Kind of wish I had stated sooner. Heck my AMD EPYC servers have only intake performance fans and stay really cool. It makes more sense as I thought about it last night.
Yea the stock case fans are absolute garbage. They are the 3 pin, not the PWM ones. I have even cranked them up to 100% and they barely move any air. Would the 3rd 140mm fan not suffer due to positioning on the case? It flows partly into the PSU shroud area. I have to remove the small panel from the shroud at the front of the case to fit a 3rd fan so perhaps that would allow some air to flow. I also believe the Meshify S2 design on the intake mounting points block part of the 140mm fans. I will look into blocking the bottom. I currently have my PSU oriented facing downwards and it sits on my desk instead of the carpeted floor.
It fits and doesn't block the PCIe slot. It does slightly block the first m.2 socket, but so does my GPU. The drive doesn't appear to get hot under load though. I am guessing due to the heatsink for that socket. I use the heatsink that came with board in that socket. I was not aware of that about the NH-D15S. Good to know for future builds. Thank you for that info.
Thank you for the link. I will look over it again and ask you if I have any questions from that page.
It was already bought and installed last year. Based on the efficiency curve I am right where I want to be in comparison to smaller PSU's.
I live in an environment with 4 pets so I don't want to remove those filters if possible. There is a rear filter? Last I checked there is only front, top, and bottom. Currently the case fans are stock with stock config. They aren't cutting it.
The included fans are junk based on the specs and what little air they actually move. True they aren't terrible for "free" case fans.
Yes I go for quality and top performing. Price and looks come last. But I prefer no RGB if possible. I turned off the RGB on my motherboard and GPU first day. I also bought my case because I wanted a panel that wasn't see through. It is so hard to find a case nowadays that has a solid panel.
I saw those brackets. I am very interested in them. He doesn't make a bracket for Noctua yet, but said it is something he is looking into after so many requests. I am not a water cooled fan at all and his brackets almost got me to buy an EVGA 360 CLC or something similiar.
I bought more of the paste already for my 3950x. I wasn't aware of Kryonaut Extreme. I may reach out to them and see what they say.
Right now I am hoping by fixing the airflow in the case that will help some. I have OC'd the CPU very lightly and OC'd the GPU. RAM is also OC'd. I am still learning how the CPU works so I can better OC it and dial it in. I didn't dig too deep into 3900x since I would have to start over with 3950x. Also, never know the quality of silicon. I think I got lucky with 3900x, but hoping the same for my 3950x.
Thank you. So far it has been a blast. I came from a 10 year old laptop and a cheap i5-7400 desktop.
His post reads:
Yep. Too bad it didn't come with the PWM fan version.
Correct. This build is already assembled and running as of end of July / beginning of August of 2019.
Build list
post #10 of 51 (permalink) Old 03-27-2020, 12:49 PM
Veii's Avatar
I understand you, i dislike CLCs which are not full copper everywhere
Sadly the market still awaits some because of the global lockdown - In Win & Asus's ROG full copper one still is in undefined ETA (likely 2 months more)
Your current best options for full copper CLCs where Alphacool their and Swiftech H X3 series
The Kryo Extreme is sometimes featured in their videos as pink paste
KINGPIN has one which is very stiff and works good enough (the kryonaut good enough range)
But the Kryo Extreme has to be requested personally - it exists since 2017 and continues to be developed further
He does give it to some OCers, but so far only under personal request - because it's not under global production status
This might turn into offtopic, but can you tell me what you OC'd at which voltages
You have to know your voltage range because every sillicon has an unique allcore voltage
Only the maximum voltage of 1.48v does stay as known limit - while new Agesa & new SMU can push it to 1.5
This is some post to read about how to find out unique sillicon voltage, do not use online values for OCing
The cpu is far more capable to OC themself than most OCers tries
Unless you've worken on finding out FIT voltage for your sillicon - i strongly advice against running anything over 1.3v on it and using per CCX OC
On some, hardlimit might even be 1.28x - soo know your FIT voltage before you attempt to beat the FIT module and AMDs research
Personal Records
Veii is offline
Tags
3900x , 3950x , Air Cooling , meshify s2
