PWN fan hub for max control of 7 fans? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 56 (permalink) Old 04-20-2020, 05:27 AM
Rep: 13 (Unique: 12)
Considering the board, you can perfectly use splitters, with 2-3 fans per splitter. You have enough ports, and splitters add versatility. You don't have to run all of them at the same speed, or start them at the same temp. And 3-4 splitters will cost you next to nothing.
Shenhua is offline
post #12 of 56 (permalink) Old 04-20-2020, 06:09 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Quote: Originally Posted by ciarlatano View Post
Any of the units @doyll suggested would do the job excepting the ModDIY piece, which draws all power from the MB header.
I just looked at the specs on these lights "fans". More Corsair comedy gold - "Flow Type: Static Pressure".
Good catch! I should have looked closer.
They used to sell them.
Quote: Originally Posted by 8564dan View Post
Thanks. There's nothing available here in the UK atm. I can only seem to get the Thermaltake or Commander Pro. I would grab the Silverstone but can't find it anywhere.
I'm tempted to just give the Thermaltake a go as it's the only one I can get... or I'll just use splitters.
Are 3 fans for one pwm header generally ok? I've seen 1amp is generally what a header can handle. These fans are 0.3amps each so in theory it should work. I may just do 2 fans per header for safety.
Here is one
https://www.amazon.co.uk/LeHang-Chas...xpY2s9dHJ1ZQ==
https://www.amazon.co.uk/ILS-Control...387562&sr=8-13
ciarlatano please check these to make sure I don't mess up again.
a couple of these Gelid PSU powered PWM splitter would work.
https://www.quietpc.com/gel-pwm-1-4-...SABEgLiFPD_BwE
https://www.novatech.co.uk/products/...025780460.html
I thought I might have one here, but I can't seem to find it. I use PSU powered PWM splitters/hubs so often I usually have a couple on hand, but I seem to be out.
doyll is offline
post #13 of 56 (permalink) Old 04-20-2020, 06:19 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
@ciarlatano See above ^
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #14 of 56 (permalink) Old 04-20-2020, 09:44 AM
Back at it again.
Avacado's Avatar
Check this out. From sidewinder OOB sale. https://sidewindercomputers.com/coll...ower-connector
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #15 of 56 (permalink) Old 04-20-2020, 09:50 AM
jarble's Avatar
Rep: 147 (Unique: 108)
Was just about to post a link to that swiftech splitter. I have used one for years and had no trouble with it.
Nokoribi
(27 items)
3970x
Gigabyte Aorus Xtreme trx40
GTX 1080ti
GTX 1080ti
Gskill Trident
Samsung 960 pro
EVGA
Black Ice 480
Black Ice 480
Black Ice 480
Black Ice 480
Heatkiller cpu block
Bitspower gpu block
Bitspower gpu block
All the fittings
Dual D5's
Noctua fans
Bequiet fans
Aquaero 6
Corsair 1000d
Operating System
Windows 10 pro
LG 42
Asus
Keyboard
Razer
Mouse
Razer Naga Hex
Mousepad
Razer Firefly
Audio
Assorted
jarble is offline
post #16 of 56 (permalink) Old 04-20-2020, 10:04 AM
Food Editor
skupples's Avatar
Rep: 719 (Unique: 378)
splitty9
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #17 of 56 (permalink) Old 04-20-2020, 10:23 AM
doyll's Avatar
Would be a great deal if it was in UK where e8564dan is. I'm in same boat. You guy get some great deal on your side of pond.
Quote: Originally Posted by skupples View Post
splitty9
Isn't Splitty9 just a splitter with no PSU 12v power lead? I think e8564dan needs the kind that use 12v PSU power on SATA or Molex connector to power the fans and splits PWM signal to control fan speed.
doyll is offline
post #18 of 56 (permalink) Old 04-20-2020, 10:46 AM
Invalid Media
J7SC's Avatar
Rep: 73 (Unique: 31)
Hey all,
I have 7 PWM fans I would like to connect to a single hub so they are all controlled by one fan header on the mobo.
I have ordered the Thermaltake FP -10 Commander which looks like it will do what I want.
I've seen some reviews saying the fans aren't all controlled properly but majority I've seen say it's great.
I'm using 6 QL120 Corsair fans and 1 noctua fan. I know the commander pro is there but it's a lot more expensive than the Thermaltake.
Anyone have experience with the Thermaltake or any suggestions?
Thanks.
Hi - I've been using that ThermalTake (TT) hub pwm hub (w/8 of 10 slots populated) for well over a year now, with 'zero' problems...the input signal is connected to one of the mobo pwm headers. I bought it here in W.Canada for the equivalent of US$ 17, along with a TT Core P5 (open box) for US$64, PCI extender cable included
While some TT products have had a less than stellar reputation, on these two TT products, I am impressed with the quality, and especially the underlying value proposition
J7SC is offline
post #19 of 56 (permalink) Old 04-20-2020, 11:25 AM - Thread Starter
8564dan's Avatar
Rep: 22 (Unique: 21)
Thanks for this. Have you got it connected to the CPU header or another PWM fan header on your mobo?
Literally, the only options I've really found are this and the Commander Pro in the UK.
This one here that was linked earlier also looks decent.
Think I'll stick with the Thermaltake for now. It seems to be user error issues I've seen, otherwise I've read it's decent. Although, the commander pro is definitely tempting considering I'm using those fans.
Thanks again!
My Rig
(14 items)
Intel Xeon 5670 @ 4.2GHz
Asus P6tD Deluxe
GTX 1080 TI
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Coolermaster HAF 932
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #20 of 56 (permalink) Old 04-20-2020, 11:34 AM
skline00's Avatar
Rep: 16 (Unique: 14)
I am using the Commander Pro to control 5 EK Vardar 120mm Vicious (75--3000rpm) PWM fans that are used to cool my 360mm and 240mm radiators in my 3900k/Radeon VII rig.
The Commander Pro is limited to 6 PWM fans so you might need a splitter for the 7th fan or run it off the mb header. I also use the MSI X570 Unify mb (simplistic but beefy) and I am very pleased.
9900k-5.0-Kraken X72|Asrock Z390 Taichi|32g-DDR4-3200 FlareX|EVGA GTX 2080TI XC | Corsair MP500-480g|EVGA 1000W|Thermaltake V51|Acer ET430k|Win10-64 home
3900x stock Custom WC Optimus WB 360 +240 rads EK D5|MSI X570 Unify|32g-DDR4-3600 TridentZ Neo|Asrock Radeon VII-EK block |Sbrent Rocket 1tb NVME4|Corsair RX850|Phantek Ethoo Pro|BenQ EX3501R+Oculus Rift
skline00 is offline
