PWN fan hub for max control of 7 fans? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 56 (permalink) Old 04-20-2020, 11:37 AM
Invalid Media
J7SC's Avatar
Rep: 73 (Unique: 31)
Quote: Originally Posted by 8564dan View Post
Thanks for this. Have you got it connected to the CPU header or another PWM fan header on your mobo?
Literally, the only options I've really found are this and the Commander Pro in the UK.
This one here that was linked earlier also looks decent.
Think I'll stick with the Thermaltake for now. It seems to be user error issues I've seen, otherwise I've read it's decent. Although, the commander pro is definitely tempting considering I'm using those fans.
Thanks again!
Mobo is MSI X399 Creation...using one of the 'other' (non-CPU header) PWMs on the mobo
J7SC is online now
post #22 of 56 (permalink) Old 04-20-2020, 12:55 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
Thanks again!
The Tt isn't a terrible option. Realistically, under the plastic case it is likely exactly the same as the two Chinese off brands that @doyll listed. A PWM splitter isn't a really high tech piece of equipment, it's one of the simplest components around. Tt is off putting by track record, but it's a PWM splitter. Would be kind of hard to mess that up.
ciarlatano is offline
post #23 of 56 (permalink) Old 04-20-2020, 02:10 PM - Thread Starter
8564dan's Avatar
Rep: 22 (Unique: 21)
Yeah these are my thoughts exactly right now.
My Rig
(14 items)
Intel Xeon 5670 @ 4.2GHz
Asus P6tD Deluxe
GTX 1080 TI
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Coolermaster HAF 932
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #24 of 56 (permalink) Old 04-20-2020, 02:30 PM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
Just get any cheapo PWM fan header splitter with enough connections. The splitty9 to me doesn't even have a power connector so it pulls all 9 fans from one header on mobo? Good luck as lot a of headers are not that powerful. That's why you want a splitter that has PWM IN, TACH OUT and POWER IN via SATA or MOLEX, these can power any number of fans as long as you're fine with global PWM control and the PWM signal is strong enough to get to all fans, there is usually 1 dedicated port that will feed the TACH OUT. You can get small ones with 5 ports or larger ones with 9 etc. These same cheap Asian splitters get even rebranded by ASUS etc. hell if you want to you can buy the ones with ASUS logo or other.
I see no need for individual PWN control, and if you do well use more source ports and get more 5 pin cheap splitters.
JackCY is offline
post #25 of 56 (permalink) Old 04-20-2020, 02:48 PM
Invalid Media
J7SC's Avatar
...check this YouTube vid out. Forget the music and, ahem, 'production value', but it does show the TT in action, including CPU header temp driven...
J7SC is online now
post #26 of 56 (permalink) Old 04-20-2020, 02:54 PM
Food Editor
skupples's Avatar
Rep: 719 (Unique: 378)
Quote: Originally Posted by doyll View Post
Would be a great deal if it was in UK where e8564dan is. I'm in same boat. You guy get some great deal on your side of pond.
Isn't Splitty9 just a splitter with no PSU 12v power lead? I think e8564dan needs the kind that use 12v PSU power on SATA or Molex connector to power the fans and splits PWM signal to control fan speed.
you're probably right...
those sidewinder provided SATA powered splitters are probably already sold out now that we've brought em up.
I get why people prefer the SATA plug over big Molex, but iv'e personally had bad luck with them melting down.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #27 of 56 (permalink) Old 04-20-2020, 03:01 PM
MSC7's Avatar
Rep: 0
just my few cents about the commander pro: best thing about it is the temps you can bind a fancurve to. for example it allows me bind a fan to the gpu temp instead of just the mb or cpu temp. because of this i was able to strap two 120mm fans to my gpu and set them to the gpu temp.
MSC7 is offline
post #28 of 56 (permalink) Old 04-20-2020, 03:09 PM - Thread Starter
8564dan's Avatar
Yeah this is one reason why I would like the Commander Pro. The control is there but I'm trying to decide if it's worth spending an extra £50.
https://www.youtube.com/watch?v=qD24L33t0cE
I've seen this. It's the only video I could find lol
My Rig
(14 items)
Asus P6tD Deluxe
GTX 1080 TI
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
Noctua u12p
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #29 of 56 (permalink) Old 04-20-2020, 03:41 PM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
It is.
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #30 of 56 (permalink) Old 04-20-2020, 04:22 PM
ciarlatano's Avatar
Quote: Originally Posted by Avacado View Post
It is.
I'm going to disagree. Spending 50 for a notoriously flakey piece of equipment in order to accomplish what a free (SpeedFan) or $7 (Argus Monitor, much easier to use than SpeedFan) piece of software can do.....Yeah, I just don't see it.
