PWN fan hub for max control of 7 fans? - Overclock.net - An Overclocking Community
post #1 of 56 (permalink) Old 04-20-2020, 01:53 AM - Thread Starter
8564dan's Avatar
Rep: 22 (Unique: 21)
Hey all,
I have 7 PWM fans I would like to connect to a single hub so they are all controlled by one fan header on the mobo.
I have ordered the Thermaltake FP -10 Commander which looks like it will do what I want.
I've seen some reviews saying the fans aren't all controlled properly but majority I've seen say it's great.
I'm using 6 QL120 Corsair fans and 1 noctua fan. I know the commander pro is there but it's a lot more expensive than the Thermaltake.
Anyone have experience with the Thermaltake or any suggestions?
Thanks.
EDIT
This is for a new build.
Mobo will be MSI x570 Unify.
My Rig
(14 items)
Intel Xeon 5670 @ 4.2GHz
Asus P6tD Deluxe
GTX 1080 TI
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Coolermaster HAF 932
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #2 of 56 (permalink) Old 04-20-2020, 02:18 AM
Shawnb99's Avatar
Rep: 55 (Unique: 36)
Thermaltake is crap. Get something like a Splitty9 and Quadro from Aquacomputer.
1000 times better.
Thermaltake is a rip-off company and should never be given any money
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 56 (permalink) Old 04-20-2020, 02:37 AM
MSC7's Avatar
Rep: 0
if you want to control each fan individually then there is no way around the commander pro, only reason why i got that one for 60 bucks... if one input rpm is all thats needed then go with what is the cheapest with reasonably good reviews.
MSC7 is offline
post #4 of 56 (permalink) Old 04-20-2020, 02:39 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
Quote: Originally Posted by 8564dan View Post
Hey all,
Thanks.
That is just a fan hub, I think what you are looking for is a fan controller, all of which cost money. Honestly, I would buy 3x 4 pin fan splitters, run it to your mobo and use AI suite to control it if you are on a budget. 10$ and I use 3 of them. https://www.amazon.com/Splitter-Comp...7375582&sr=8-4
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #5 of 56 (permalink) Old 04-20-2020, 02:46 AM
Back at it again.
Avacado's Avatar
NVM, looked at your mobo, you only have 1 4 pin fan header on your board. Maybe a 4 pin to 3 pin splitter. I don't think there is any way around a fan controller if you want PWM.
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #6 of 56 (permalink) Old 04-20-2020, 03:56 AM - Thread Starter
8564dan's Avatar
1000 times better.
Those splitters you suggested have the headers all on top meaning the cables will need more space for clearance. If they were on the side, I'd consider them.
Yeah, the commander pro is tempting, although I don't know if I can warrant spending that money purely for more control of the fans. Maybe a future purchase for me.
I'm not using them in my current build. The motherboard I will be using would is the MSI x570 Unify.
I could use splitters. Definitely an option.
Thanks again.
My Rig
(14 items)
Asus P6tD Deluxe
GTX 1080 TI
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
Noctua u12p
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #7 of 56 (permalink) Old 04-20-2020, 03:59 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
I agree with what Shawnb99 said about Thermalfake.
If it's okay to control all on same temp to rpm curve a PWM splitter hub is easiest and cheapest way to do it. PWM splitter hubs use 12v power from PSU and PWM signal from motherboard PWM fan header. Plug PWM splitter hub into CPU fan header because it's our only PWM fan header. All PWM fans plugged into splitter hub will use that PWM signal so all run on same temp to speed curve. Your 6x Corsair 1500rpm fans will all cycle at same speed while NF-P12 on NH-U12P 1300rpm will be running a little slower because it's 200rpm slower top speed (assuming Corsair and Noctua have similar % PWM signal to rpm curves, and they probably do). Below links are to just a few of the PWM splitter hubs out there.
http://www.xs-pc.com/discontinued-2/...b-sata-powered
https://www.silverstonetek.com/produ...id=526&area=en
https://www.newegg.com/black-riitop-...1W7-00AZ-00004
Deleted as not PSU powered.
doyll is offline
post #8 of 56 (permalink) Old 04-20-2020, 04:40 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
Any of the units @doyll suggested would do the job excepting the ModDIY piece, which draws all power from the MB header.
I just looked at the specs on these lights "fans". More Corsair comedy gold - "Flow Type: Static Pressure".
ciarlatano is offline
post #9 of 56 (permalink) Old 04-20-2020, 05:17 AM - Thread Starter
8564dan's Avatar
https://www.moddiy.com/products/Inte...-Splitter.html
Thanks. There's nothing available here in the UK atm. I can only seem to get the Thermaltake or Commander Pro. I would grab the Silverstone but can't find it anywhere.
haha, yeah, just couldn't resist.
I'm tempted to just give the Thermaltake a go as it's the only one I can get... or I'll just use splitters.
Are 3 fans for one pwm header generally ok? I've seen 1amp is generally what a header can handle. These fans are 0.3amps each so in theory it should work. I may just do 2 fans per header for safety.
My Rig
(14 items)
Asus P6tD Deluxe
GTX 1080 TI
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
Noctua u12p
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #10 of 56 (permalink) Old 04-20-2020, 05:20 AM
Back at it again.
Avacado's Avatar
Yes, 3 per header is fine. And if you do decide to Commander Pro, it's great, it's not Aquasuite, but it's good. Be aware that without their products, it's does usually won't work (Iv'e tried without an AIO)
White Lightning
(12 items)
ASUS Prime Z390-A
EVGA 1000w
Corsair H150i Pro
Operating System
Windows 10 Home
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
