Silent fans for in-office rack - Page 3 - Overclock.net - An Overclocking Community
post #21 of 24 (permalink) Old 04-30-2020, 08:03 AM - Thread Starter
bMind's Avatar
Rep: 0
Quote: Originally Posted by doyll View Post
Soulds like a win/win.
I've often used small rubber grommets as vibration dampeners. Link below shows how I use them.
https://www.overclock.net/forum/246-...an-data-5.html
I think it is I said it before but I am surprised, in a good way. Can't wait for the controller to come in, I have ABS case with clear top cover to view the 3 digit screen, mounting plate for it and all the fun things
Anyway, I hope I'll have time to strip the rack this weekend to drill mounting holes for the 140mm to get the fans in. Then some testing with this setup and on-channel controller and we'll see if I'll be adding 4 more (that will require drilling four 140mm holes, but well)
AMD Ryzen 2700X [stock] | Crosshair VII Hero [Bios 2901] | 32GB G.Skill TridentZ RGB (F4-3200C14-16GTZR) [stock] | be quiet! Dark Rock 4 Pro | Samsung 970 EVO Plus 1TB NVMe M2 | EVGA GeForce GTX 1080 Ti FTW3 Hybrid Gaming | EVGA SuperNOVA P2 1200W | Thermaltake Core X71
bMind is offline
post #22 of 24 (permalink) Old 04-30-2020, 08:06 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Would love to see some pics of it .. and I'm probably not the only one.
doyll is offline
post #23 of 24 (permalink) Old 04-30-2020, 08:35 AM - Thread Starter
bMind's Avatar
Rep: 0
For the mounting I might use something like this if I won't find grommets like you suggested.
Oh, no problem, I'll definitely make some I already have been documenting it a bit. Looks better than in real life Also only the 2U server is up and running, R210 II is off because I need to silence the rack first to run it 24/7 in my office, 3U is..empty because I'm missing CPU
bMind is offline
post #24 of 24 (permalink) Old 05-15-2020, 12:55 PM - Thread Starter
bMind's Avatar
Rep: 0
Well..I promised some pics There is my 2 channel controller I got from our Chinese friends this week.
I used an universal case, mounting plate, added those thingies for motherboard but with screw holes on both ends Also some cable extenders so I don't have to open the case to disconnect the fans. In the end? I'm happy with the result. It was the fastest (even with shipping) way to close another part of my project. Eventually I'll probably go for some kind of Arduino controlled solution but I didn't want to waste time researching that.
I drilled mounting holes for 140mm fan and used the silicone mounting pins do fix the fans to the rack case.
bMind is offline
