Are there any 'go-to' fan curves for 3950x on MSI Unify? Constant fluctuation. - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 04-24-2020, 11:46 AM - Thread Starter
8564dan's Avatar
Rep: 22 (Unique: 21)
Hey all,
I have built the new system with the 3950X and MSI Unify.
Got Windows installed etc...
I went into BIOS and enabled PWM mode and Smart Fan Mode.
The thing is, it is quiet but at idle, the temperature fluctuates so much that the fans are always ramping up and down with it.
Is there recommended curve?
At idle, just on Chrome, it's literally min 36 and max 63 degreesC.
Is it ok to set a custom curve to literally be on a extremely low RPM and then ramp up after 70?
Maybe I have them all set to go with the CPU temp atm and should change that to.
Any suggestions would be great.
Thanks!
EDIT
In the BIOS, I’ve fiddled with the curves and it’s dead quiet. I can actually hear a slight electrical sound coming from the motherboard now. Put my ear up to the IO of the motherboard and it’s coming from there. Is this generally normal?
EDIT EDIT
Seems to be the Arctic Freezer II pump noise I can hear.
My Rig
(14 items)
Intel Xeon 5670 @ 4.2GHz
Asus P6tD Deluxe
GTX 1080 TI
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Coolermaster HAF 932
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #2 of 4 (permalink) Old 04-24-2020, 12:18 PM
Rep: 13 (Unique: 12)
Quote: Originally Posted by 8564dan View Post
Hey all,
Thanks!
EDIT
There's no predefined curve that will fit your build perfectly. The fan curve it's dependent on the case, fans, cooler and their configuration, aswell as the hardware, CPU and GPU.
Just make a curve and test. There's no good or bad, it all depends on your builds, the temps and noise level you are comfortable with.
That being said, on ryzen because of the thermal density and the consequential temp. spikes, it's recommended to use a custom curve with with a very mild RPM change between 30 and 60°C.
Try to use set something like this and check temps 0-40°C 500rpm, 60°C 800rpm, 65°C 1000rpm, 70°C 1200rpm and 75°C max RPM (or 1500).
If your CPU consistently spike with cooler and case fans above 70°C with the curve i gave you, you either endure the noise, or improve cooling.
Shenhua is offline
post #3 of 4 (permalink) Old 04-26-2020, 06:30 AM
Rep: 0
Set a flat spot in the curve. Say 32-55 at a set RPM and for the most part with a decent cooler the CPU hopefully stays there. Then ramp up from there with it maxing out at 70C and set the ramp delays up a hair so it steps up and down and does not bounce around. And for the 3950x this is most likely why AMD recommends water cooling so you do not hear this little issue since they like to bounce temps up/down in 10C swings when doing very little.
MSI MEG X570 Ace
AMD Ryzen 9 3900x
Corsair H115i Platinum, Corsair Crystal 570x RGB Case
32GB Corsair Vengence RGB Pro 3600 @3800
MSI Geforce RTX 2080 Super Ventus SX OC w/ Acer Predator X34P
jamie1073 is offline
post #4 of 4 (permalink) Old 04-26-2020, 07:20 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Hey all,
Thanks!
EDIT
EDIT EDIT
I assume you changed the curve so fans stayed at idle speed to higher temp before ramping to higher speed? Motherboard (unless they have internal fans) make no noise.
CLC pump noise is very common. Part of the reason I will never use CLCs. Even AIOs like Swiftech Drive X3, be quiet! Silent Loop and Aqua Cool Aisbaer usually make a little more noise at idle than air cooling. All have water pumps that can often be heard by good ears sometimes even a meter away in very quiet room.
doyll is offline
