Why doesn't the Scythe Ninja 5 get more love here? - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 04-30-2020, 07:04 PM - Thread Starter
SlvrDragon50's Avatar
Rep: 58 (Unique: 43)
Been looking for an air cooler for my server build. Honestly, I could get by with my Hyper 212, but I like to waste money. Anyways, in my search the Scythe Ninja 5 popped up, and it seems to be absolutely killing in terms of noiseerformance. It does seem not perform as well in overclock situations, but that seems to be due to the low fan speed as they aren't being performed with reference fans.
I see LGMRT is extremely popular, and it definitely tested well, but the Scythe Ninja 5 is cheaper and quieter than all of the other towers. Is the Ninja's worse OC performance the main reason it doesn't get recommended as much as the LGMRT?
SlvrDragon50 is offline
post #2 of 26 (permalink) Old 04-30-2020, 07:27 PM
D-EJ915's Avatar
Rep: 15 (Unique: 14)
The only reason to get the Ninja IMO is if you like its aesthetic since the Fuma 2 is the same price and performs better even when both run the same fans.
Kanna
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #3 of 26 (permalink) Old 04-30-2020, 07:45 PM - Thread Starter
Huh weird, last time I looked the Ninja 5 outperformed the Fuma 2 in terms of noise. Ponchato on YT has the Ninja 5 edging out the Fuma 2 though by 2.5 degrees. Tweaktown shows them to be quite close and probably not actually distinguishable to the human ear. Anyways, still wondering why the Scythe fans don't get the same love. They perform quite well and are relatively cheap. The $20 between the LGMRT and Ninja/Fuma isn't much, but it's still $20 that could be put towards better RAM or a GPU.
post #4 of 26 (permalink) Old 04-30-2020, 07:54 PM
Food Editor
skupples's Avatar
Rep: 719 (Unique: 378)
because we're still salty over the gentle typhoon fall out.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #5 of 26 (permalink) Old 04-30-2020, 08:37 PM - Thread Starter
Hahahah. That is a very acceptable answer.
post #6 of 26 (permalink) Old 04-30-2020, 11:05 PM
Rep: 13 (Unique: 12)
Because it's inconvenient and it's not better than fuma 2. Even some of the biggest air coolers are more convenient when it comes to clearence and working with them.
Shenhua is offline
post #7 of 26 (permalink) Old 05-01-2020, 09:10 AM
cssorkinman's Avatar
Rep: 499 (Unique: 279)
I just swapped my 1800X's cooling from a 480mm custom loop to the Scythe Ninja 5.
It's quiet but worlds away from the loop in cooling ability.
I'm a little disappointed, was hoping to be able to run 4.1 ghz all core , which is why I did the test on the loop at that speed for comparison's sake. I was running 4175 mhz at 1.525+V on the loop for a daily.
The custom loop hadn't been cleaned in 8 years of operation - fluid was fine, but the rad was completely plugged...lol. I'll post a pic later if i get time.
cssorkinman is online now
post #8 of 26 (permalink) Old 05-01-2020, 10:03 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
What is air temp entering cooler compared to room ambient? Often the reason for high CPU (& GPU) temps is air entering cooler is 5-10c even 15-20c higher than room .. and that translates to that CPU (or GPU) being similar 5-20c hotter. Every degree warmer air enter cooler is same number of degrees hotter component is at same load and fan speed .. it's almost exactly a 1:1 ratio.
doyll is offline
post #9 of 26 (permalink) Old 05-01-2020, 10:12 AM
H₂O Aficionado
Slaughtahouse's Avatar
Rep: 118 (Unique: 95)
I know this is OCN but is it really worth it 4.4% increase in performance for 20% more wattage? Even if your loop is better at removing the heat from your system. The electricity is still being consumed and heat is still outputted from your workstation.
The chip will likely last longer running at the lower voltage, right?
Also, how much did it cost to build / install that loop vs the air cooler? I'm all for loops but just putting it into perspective
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC EX 360 Radiator
XSPC Raystorm CPU Block
XSPC Titan/780 GPU Block
EK-XRES 100 Revo D5 - Acetal
XSPC D5 Pump
Fractal Design Meshify C
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Razer Death Adder 2013
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
Bose Companion III's
i7 3930K
Asus Sabertooth X79
Geforce GTX 780 EVGA SC 3GB + XSPC Waterblock
Patriot Viper 3 16GB (4 x 4GB) DDR3 2133
SAMSUNG 840 Series 250GB
Corsair AX850
XIGMATEK Dark Knight II Night Hawk Edition
XSPC 360mm radiator, Raystorm CPU block, D5 pump
Corsair Vengeance Series C70 Military Green (Custom paint)
Operating System
Windows 10
QNIX QX2710 27" 100hz
Samsung 2233RZ 22" 120hz
Keyboard
Logitech g710+
Mouse
Razer DeathAdder 3.5G
Mouse
Mouse Rug
Audio
Bose Companion III's Speakers
Audio
Sennheiser HD 558 Headphones
Audio
Sennheiser HD 6XX Headphones
Slaughtahouse is offline
post #10 of 26 (permalink) Old 05-01-2020, 11:43 AM
"Case" is a thermaltake P5 - sans the tempered glass intake to radiator and heatsink is pretty much ambient. Room temp would be within a degree or two F depending on Hvac cycling for both setups.
I'm flushing the loop, getting new tubing, some new fittings and going mount everything to the p-5 . Just needed a cooler to get by with while I'm working on the liquid setup.
