Help choose a cooler (FUMA 2 vs Ninja 5) - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 05-02-2020, 06:50 PM - Thread Starter
Rep: 46 (Unique: 34)
Good day! My girlfriend wanted a PC really bad, and as such I've decided to help her build one.
So far I have ordered the following components:
Ryzen 5 3600
MSI x470 Gaming Plus Max
EVGA 2060 XC (found at a very good price)
Geil EVO II AMD Edition 3600
Personally I haven't been into air cooling ever since I've tried out water (custom loops all the way! lots of rads! MOAR RADS!), but since I am doing a "budget build" here, I am trying to figure out which cooler to grab.
I have narrowed down to FUMA 2 and Ninja 5.
My main concern about Ninja 5 - Ninja 5 has 5.5cm clearance for ram (as far as I have been able to find out on the web), while EVO II stands 5.1cm tall. This means that one of the fans for Ninja 5 will have to be mounted higher to get the necessary clearance for ram. No clue how much that will affect Ninja 5's performance. In addition to that it will cover slot 2, and RGBs. Personally I couldn't care less, but my girlfriend likes RGBs.
My main concern about Fuma 2 - loud than Ninja 5, performs slightly worse, from what I have read.
Looking for input (especially if anyone used both coolers).
Kriant is offline
post #2 of 9 (permalink) Old 05-02-2020, 08:45 PM
Linux Gamer
Almost Heathen's Avatar
Rep: 61 (Unique: 43)
Ryzen 5 3600
Have you looked at the Thermalright TRUE Spirit 140 Power? It's a top performer and usually cheap.
I thought most reviews had the Fuma II outperforming the Ninja 5.
I would hesitate to run a cooler with a very convex base like the Fuma/Fuma II on Ryzen. In theory coolers with a highly convex base don't perform as well with the chiplet layout. I haven't seen any thermal benchmarks on Ryzen to back that up, but such data could be worth seeking out.
If you're not overclocking, perhaps the convexity is not a huge concern, but a matter worthy of consideration at least. It may cause the less convex Ninja 5 to outperform the Fuma II. Then there's the matter of how the CPU IHS can deform/dent due to a highly convex base; not much of an issue if you always use the same cooler, but if you were to switch to a flatter cooler later, it would make poor contact and cause thermals to be worse, albeit you could always lap it, if it becomes an issue.
FWIW mounting the fan higher on the heatsink had no noticeable effect with my Ninja 4; IMO it's a non-issue, especially with push/pull.
NAS / HTPC
(19 items)
Intel Xeon W3680 @ 3.9GHz
Dell 0x501h (BIOS A16, not EFI capable)
EVGA GTX 1060 Gaming 6GB 06G-P4-6161-KR @ stock
30GB @ 1066MHz CL7 (3x8GB 2Rx8 1600MHz ECC UDIMMs, 3x2GB 2Rx8 1333MHz non-ECC)
ZFS mirror (media), ZFS JBOD (gaming etc.), ZFS OS
Seasonic SS-850HT
Scythe Ninja 4
Sunbeam Rheostat Extreme Fan Controller rev2
4 x San Ace 140mm, 2 x Delta AFB 120mm (VRM fans)
CaseLabs Bullet BH8 (white)
Operating System
Antergos XFCE (Antergos repos removed)
Panasonic Viera X3 TV
Keyboard
CM Storm Quickfire Pro (Cherry Reds)
Mouse
Logitech M310
Mouse
Itac mouse-trak Industrial Trackball
Mousepad
Cloth
Audio
Creative Sound BlasterX H5 Tournament Edition Headset
Audio
Creative Sound BlasterX G1 USB Sound Card
Audio
Philips HTS3555 5.1 1000w Home Theater
Almost Heathen is offline
post #3 of 9 (permalink) Old 05-02-2020, 08:50 PM
SlvrDragon50's Avatar
Rep: 58 (Unique: 43)
The reviews I saw had the Ninja 5 outperforming the Fuma 2 when you take noise into account. If you're talking outright performance, then I believe the Fuma 2 wins, but that is likely due to having higher RPM fans. I'm not sure if you watched Ponchato's review, but his methodology seemed quite sound.
SlvrDragon50 is offline
post #4 of 9 (permalink) Old 05-03-2020, 03:01 PM - Thread Starter
Never saw that reviewer before. But he did sway me in the direction of FUMA 2, so I went ahead and ordered it.
Thanks for your input guys! =)
Kriant is offline
post #5 of 9 (permalink) Old 05-03-2020, 04:02 PM
Awesome! His reviews really should be getting a lot more views. Videos are straight and to the point.
post #6 of 9 (permalink) Old 05-04-2020, 05:31 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Any review that doesn't have a detailed discription of test station and a detailed test procedure is suspect. The test procedure needs to be written, not told like a story by a talking head.
GamerNexus has a very good detailed explaination of why most cooler testing is flawed:
https://www.gamersnexus.net/guides/3...sts-are-flawed
They also have a good test station and do accurate cooler testing:
https://www.gamersnexus.net/hwreview...-nh-d15-others
Another site with very in-depth reviews is TheLab, It's a Greek site so need to use translater. Their testing includes 3 cooler orientations:
https://www.thelab.gr/reviews/heatsi...oling-reviews/
doyll is offline
post #7 of 9 (permalink) Old 05-11-2020, 04:11 PM - Thread Starter
Thanks for the input!
I've installed FUMA 2. Temps slightly higher than expected, maybe I put too much paste, but overall seems decent. 3600 under prime95 blend, after 14h maximum registered temp was 81.5 (probably during small fft). Hovers at 4.075ghz all cores under load on average.
Kriant is offline
post #8 of 9 (permalink) Old 05-12-2020, 06:18 AM
doyll's Avatar
Have you checked the air temp entering cooler during a long test? It is very possible the air inside of case is warmer than room when system is working hard. Every degree warmer air is make component (CPU same degree hotter. If room is 22c and air into coole ris 35c with 81.5c and case airflow is improved so air into cooler is 25c, then CPU would be 71.5c instead of 81.5c. This is why when a system seems to be running hot one of the first things I check is air temp entering cooler.
doyll is offline
post #9 of 9 (permalink) Old 05-12-2020, 07:14 AM
Not a linux lobbyist
rluker5's Avatar
Rep: 56 (Unique: 42)
You would strip your mounting screws long before you could permanently deform an I.h.s. Also the yield strength of copper is basically unchanged at that temp: http://www-ferp.ucsd.edu/LIB/PROPS/PANOS/cu.html and creep generally doesn't become a concern on the timescale of a lifetime until you get over half of the melting point of a metal. The I.h.s. won't hit a third of its.
But I'm just being nitpicky, I didn't know the Fuma was convex and it does sound worse for broad coverage because of that.
L5
(17 items)
Lea2
(11 items)
L7
(11 items)
5775c
Maximus VII Hero
Aorus 1080ti Waterforce
16 Gb Gskill Trident @ 2400,cas10,1.575v
8 Gb Gskill Trident @ 2400,cas10,1.575v
1Tb Team ssd
seagate barracuda 3T
Optane 900p 480G OS
Optical Drive
Asus BW-16D1HT
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design R4 (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear, Nova 40, 598se, HE4xx, DT990pro w b.boost earpads
Audio
SoundbasterX AE-5, onboard
4770k
Asus Z87 Deluxe
Fury Nitro
8Gb klevv urbane 2133
ROG Raidr 240Gb pcie
1Tb WD blue
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
DIYPC P48-W
Operating System
W10 64 pro
40"tv
4980hq
Asus H81T/CSM
8Gb 1600 samsung
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
24" samsung 1080p
Keyboard
Logitech K400+
Other
Intel wifi ac card and noname antennas
rluker5 is offline
