HTPC cooler - Overclock.net - An Overclocking Community
HTPC cooler
post #1 of 13 (permalink) Old 05-03-2020, 10:33 AM - Thread Starter
dixson01974's Avatar
Rep: 529 (Unique: 432)
HTPC cooler
What would be a good low profile cpu cooler for Fx-8350 125w? I have a max of 50mm for a cpu cooler. My AMD wraith cooler is too big.
i
dixson01974 is offline
post #2 of 13 (permalink) Old 05-03-2020, 02:06 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
i
What case are you using?
ciarlatano is offline
post #3 of 13 (permalink) Old 05-03-2020, 02:19 PM
doyll's Avatar
Rep: 1689 (Unique: 935)
What ciarlatano said.
Helps us be able to suggest coolers that will fit.
doyll is offline
post #4 of 13 (permalink) Old 05-04-2020, 06:31 AM - Thread Starter
post #5 of 13 (permalink) Old 05-04-2020, 06:48 AM
Intel in 2020 LOL
Rep: 37 (Unique: 19)
Air coolers are out of the question. None are both small enough and also able to cool a 125W FX 8350. You MIGHT get away with an NH-L9a and heavy undervolting but at that point you'd be better off with a 95W FX 8300 but even that is probably too much for a tiny air cooler. 65W seems to be the limit of the NH-L9a.
The case can only fit 92mm fans => you'd need either a 92mm AIO (and that wouldn't really be able to cool the CPU either) or to mod the case.
https://www.asetek.com/gamingenthusi...tor-cpu-cooler
AMD Bliss
(16 items)
AMD Ryzen 7 3700X
MSI X470 Gaming Pro - 1.0.0.4B
Sapphire RX 5700 XT Pulse
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
Sapphire RX 580 Nitro+ 8GB
2x8GB Kingston HyperX Fury @1600 CL10
Samsung 860 EVO 500GB
WD Blue 1TB
Super Flower Golden King Pro SF-500P14PE 500W 80+ Platinum
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Asus VG245HE TN 1080p 75hz
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Intel Core 2 Quad Q6600
Gigabyte P43-ES3G
Asus R9 270X Top 2GB
2x2048MB Kingston DDR2 800mhz
Samsung 840 EVO 120GB
WD Blue 1TB
Sirtec High-Power 80+ 400W
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Several LG/BenQ 17" 1280x1024 75hz
Keyboard
Logitech G710+ MX Brown
Mouse
Mouse
Razer DeathAdder 2013
Mousepad
Mousepad
Razer Goliathus Speed WoT Edition
rares495 is offline
post #6 of 13 (permalink) Old 05-04-2020, 07:13 AM
Rep: 11 (Unique: 9)
You could potentially replace the NH-L9a 14 mm fan with a noctua 25mm NF-A9 and it "might" still fit in the case. However there ar reports it may perform worse:
https://www.reddit.com/r/sffpc/comme...ests_extended/
( one potential issue is even if the fatter fan fits you would be reducing the clearance above the fan to pull air in)
clannagh is offline
post #7 of 13 (permalink) Old 05-04-2020, 08:48 AM
ciarlatano's Avatar
Air cooling an 8350 in that case is going to be tough, it has essentially no airflow. I am really hesitant to recommend anything, I just don't see it going well.
post #8 of 13 (permalink) Old 05-04-2020, 09:35 AM
doyll's Avatar
While I agree with rares495 about your case solection extremely limiting your options, I wouldn't waste time and money on a CLC (most AIOs are really CLCs). VSK200 U3 only has 65mm CPU clearance and cooler needs at least 15mm clearance for air to flow into cooler fan which means cooler has to be les than 50mm tall. NH-L9A will not cool it as it only has 2x heatpipes. Even coolers that will are being severly limited by your choice of cases with only 1x 92mm of case airflow. Coolers that might work if case flow enough air at room temp to them are Cryorig C7 (97x97x47mm w/ 4x 6mm heatpipes TDP 100w), Alpenfohn Black Ridge (120x120x47mm (fan under finpack) w/ 6x 6mm heatpipes.
But honestly, if you could return that case and get one that has better airflow you will be much better off.
doyll is offline
post #9 of 13 (permalink) Old 05-04-2020, 10:05 AM
Intel in 2020 LOL
Thanks doyll. I was aware that there might be a few better alternatives to the Noctua but my knowledge of "exotic" or smaller brands is very limited. Thanks again for the two tiny coolers that I will definitely add to my list.
AMD Bliss
(16 items)
AMD Ryzen 7 3700X
Phanteks P350X
Asus VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Mousepad
Audio
Asus Cerberus
Intel Core i5 4460
Gigabyte B85M-D3H-A
WD Blue 1TB
Intel Stock Cooler
Zalman Z11+
Operating System
Windows 10 x64
Keyboard
Logitech G710+
Mouse
Mousepad
Logitech G440
Audio
Logitech X-540 5.1
Gigabyte P43-ES3G
WD Blue 1TB
Some 92mm cooler
Zalman Z11+
Operating System
Win 7 Ultimate x64
Keyboard
Mouse
Mouse
Mousepad
Mousepad
rares495 is offline
post #10 of 13 (permalink) Old 05-04-2020, 10:08 AM
ciarlatano's Avatar
While I agree with rares495Even coolers that will are being severly limited by your choice of cases with only 1x 92mm of case airflow.
To add insult to injury, that one 92mm fan appears to have obstructions to overcome as well. The C7 will cool an 8350 as you say.....but not without airflow. I can't see more than a Celeron or Ryzen 3 possibly working in there. But, that case was intended for office use, which typically has a low wattage CPU.
