Fan and cooler recommandation - Page 2 - Overclock.net - An Overclocking Community
post #11 of 23 (permalink) Old 05-14-2020, 10:49 PM
TeslaHUN's Avatar
Rep: 23 (Unique: 21)
I had Define S a few years ago, not the best for airflow but its not the worst either . What I found best after experimenting with different configurations : 4x 140mm intake and 1x exhaust win .
I would recommend as others before me : buy an arctic P14pst 5pack and fill up the case with them. 3x 14cm front , 1x14cm bottom (intake ) 1x 14cm exhaust on back. Top panel fully closed.
TeslaHUN is offline
post #12 of 23 (permalink) Old 05-15-2020, 07:52 AM - Thread Starter
dindon's Avatar
Rep: 0
Ok I have ordered what I need based on your recommandations: jumper cable, few fans (mostly to replace the one that's broken), didn't need any splitters since I have 4+1 fan connectors which should be enough.
I may delid my CPU, hopefully I'll break nothing.
I also did some cable management to remove anything in the way of air flow, maybe... At least it's prettier.
My main issue still remains the noise my GPU is making after a few hours of gaming, but I may be out of luck since it's been a few month since the 3 years warranty is expired.
dindon is offline
post #13 of 23 (permalink) Old 05-15-2020, 08:29 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Are your 4 + 1 fan connectors PWM with PSU power? If they are not you are taking a chance of burning out the fan header you plug them into. Reason is fan amp ratings are almost always running amps, not maximum draw, like when starting up or if impeller is stopped by something. Then the draw 3-5 times more power. This is why almost every fan header failure happens at system start-up.
doyll is offline
post #14 of 23 (permalink) Old 05-15-2020, 09:01 AM
Gamer
dlewbell's Avatar
Rep: 57 (Unique: 50)
I read this as the motherboard offers 4 + 1 fan connectors (probably CPU, CPU-OPT, & SYS1-SYS3). May just be a miscommunication. If not, I agree, 5 fans powered from 1 header is asking for trouble.
TV Gaming PC
Alienware 17R5
(5 items)
i7-8700K
MSI Z370 Gaming Pro Carbon
EVGA GeForce GTX 1070 FTW
GSkill Ripjaws V 16GB (2x8GB) DDR4-3200
Samsung 950 Pro 512GB M.2 2280
Seagate Barracuda 2TB 3.5" 7200RPM
Optical Drive
LG WH14NS40 Blu-Ray Writer
EVGA SuperNOVA 750 G2
Phanteks PH-TC14PE_BL
Enthoo Luxe
Operating System
Windows 10 Pro
Visio E601i-A3
Keyboard
Logitech K400
i7-8750H
GeForce GTX 1070
Samsung 860 EVO 1TB
Operating System
Windows 10
1920x1080 G-Sync
dlewbell is offline
post #15 of 23 (permalink) Old 05-15-2020, 09:41 AM
Linux Lobbyist
Rep: 6 (Unique: 6)
if your GPU is out of warranty you should remove the plastic surround and the fans, leave just the base aluminum heatsink, and strap on 2-3 92mm or 120mm fans on the card depending on how big the card and the heatsink are.
Same Arctic P12 PWM work for this for 120mm, and Arctic F9 work for 92mm, if it's a small card you could also go with Arctic P8 (80mm fans, the p version of 92 is not out yet unfortunately).
Dogzilla07 is offline
post #16 of 23 (permalink) Old 05-15-2020, 09:46 AM - Thread Starter
dindon's Avatar
Rep: 0
I'm afraid I'm not knowledgeable enough to understand you.
My motherboard (MSI Z270 SLI PLUS) provides:
- 1 x 4-pin CPU fan connector (used)
- 4 x 4-pin system fan connectors (2/4 used)
- 1 x 4-pin water pump fan connector (unused)
How can I check if my fan connectors are PWM with PSU ?
EDIT: I've quickly read https://www.ekwb.com/blog/what-is-pw...-does-it-work/ so I understand a bit what PWM is, since my connectors have 4-pins I'd say I'm ok ?
dindon is offline
post #17 of 23 (permalink) Old 05-15-2020, 10:03 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1390 (Unique: 720)
if it's a 4 pin fan header it's PWM.
motherboard manual will tell you what each header is rated for, if it doesn't say then just assume it's 1 amp. marginally exceeding it isn't going to cause issues but you should try to avoid it.
they make powered PWM splitters (any fan splitter with am additional SATA or molex) and then it's a non-issue, but they usually make cable management a mess.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #18 of 23 (permalink) Old 05-15-2020, 10:37 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
You would still need the splitter I suggested if you want to test fans because it is powered, if you no longer need to test them, never mind. Since you will be jumping the MOBO, the mainboard 4 pin connector will not have any power.
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #19 of 23 (permalink) Old 05-15-2020, 11:03 AM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
I've updated the post with my location, thanks.
Thank you, I was just wondering how I could test my fans and you seem to have answered my question.
You can power fans with any voltage source under 12V DC, such as one of the gazillion 12V DC powersupplies you have at home probably for your router, external harddrive, and about every other possible gadget. All you need is two wires with two bare ends. Or you can make yourself a cable with connectors, both things work.
Some PSUs already come with a testing plug to short the two pins necessary for PSU to turn on, or use a paper clip etc. no need to buy an expensive plug cable and switch.
No idea how cool a 7700K stock let alone OCed is supposed to run, but in my experience bad CPU cooling on these Intel quads is summarized like this:
  • too much silicone under IHS
  • bad TIM
  • not enough TIM under cooler
  • not enough cooler pressure
  • bad IHS and cooler plate surface flatness
Cracked cooler fin is fine. Cracked fan blade not so much.
JackCY is offline
post #20 of 23 (permalink) Old 05-15-2020, 11:06 AM
doyll's Avatar
Okay, I missunderstood your 4-1. My bad.
4-pin headers are not always PWM. Some are only variable voltage. Some can be set in bios to be variable voltage or PWM.
Check in your owner's manual. It should have an image of motherboard showing what control is on what header. If fan headers can be set PWm or variable voltage that will also be explained in manual.
Not all 4-pin fan headers are PWM. Sometimes they are 4-pin headers using only 3-pins for variable voltage control. Sometimes in Bios they can be set to function 3-pin variable voltage or 4-pin PWM.
If a PWM fan is plugged into a variable voltage fan header it will be speed controlled with variable voltage.
If a 3-pin variable voltagge fan is plugged into a PWM fan header it will run at full speed all the time because PWM controlled fan header has 12v constant power to pin-2.
Because variable voltage control fan header has variable voltage to pin-2 both 3-pin and 4-pin fans will be speed controlled.
doyll is offline
