Fan setup for FD Meshify C - Page 2 - Overclock.net - An Overclocking Community
post #11 of 34 (permalink) Old 05-11-2020, 03:44 AM
Rep: 13 (Unique: 12)
Quote: Originally Posted by Paradox42 View Post
Many thanx to all! I am very grateful to all of you!
Many thanx my friend! When I buy a case I will definitely try this option. I have a very similar GPU cooling system from yours. Very interesting setup! Its full positive pressure. You do not have exhaust fans? Does hot air passively pass through the rear hole, the holes near the GPU and the top?
Full one side intake, with barely any restrictions, make exhausts useless. You move so much air, that you replace the air in the whole case very fast. New air pushes old air out, the case has very low restriction at the back aswell.
It's basically a duct at this point.
When exhausts impact temperature, it means you don't have enough air intake. So they move some of the air is pushed in the case by the intakes and also suck air into the case through other sides of the case. So you end up moving air in, via unfiltered channels.
Shenhua is offline
post #12 of 34 (permalink) Old 05-11-2020, 03:57 AM
Back at it again.
Avacado's Avatar
Rep: 100 (Unique: 75)
Have you removed the fans from your GPU and the P12's are the only things cooling your GPU?
22643 Time Spy https://www.3dmark.com/3dm/46344026?
https://folding.extremeoverclocking....e.php?u=207393
White Lightning
(12 items)
i7 9700k @ 5.1GHz 1.385v
ASUS Prime Z390-A
Evga 2080 Ti Black Gamer
32GB GSkill TridentZ DDR4 3600
2 x 1 TB Samsung EVO 970 Raid 0
EVGA 1000w
Corsair H150i Pro
CORSAIR Crystal 570X White Mid Tower
Operating System
Windows 10 Home
Alienware 1900R 34.1" @ 120Hz
Keyboard
Loigitech G910
Mouse
Logitech G700s
Avacado is offline
post #13 of 34 (permalink) Old 05-11-2020, 04:12 AM - Thread Starter
Rep: 0
of course. I just replaced the standard palit fans with p12. The temperature at the open bench at 100% load of the GPU is 58-62, at a house temperature of ~ 22-25
Paradox42 is offline
post #14 of 34 (permalink) Old 05-11-2020, 04:41 AM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
Quote: Originally Posted by Shenhua View Post
Just replicate this and you will get the most put of it.....
Nope! That’s not how to get the most out of it. Looks good tho! 😄
X5690 E.S. @ 4200MHz 1.35v/Thermalright Le Grand Macho RT/TF8/TY-143
Asus Rampage III Formula @ 200/3600/3600 Bios 0702/Intel 545S 256GB x2
16GB G.Skill + Super Talent Mix @ 800MHz 9-9-9-24 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1490/1900|Asus Xonar Essence ST/KEF M500
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x3/ZM-MFC2
Owterspace is offline
post #15 of 34 (permalink) Old 05-11-2020, 05:27 AM - Thread Starter
Rep: 0
Supplement: I found more popular fans with high static pressure. Phanteks PH-F140MP and 120 model for the rear. How do you like that?
post #16 of 34 (permalink) Old 05-11-2020, 07:05 AM
Quote: Originally Posted by Owterspace View Post
Nope! That’s not how to get the most out of it. Looks good tho! ????
I meant temps/performance/noise, but.....Fair enough!
Shenhua is offline
post #17 of 34 (permalink) Old 05-11-2020, 07:46 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Quote: Originally Posted by ciarlatano View Post
So....now brand of fan makes a difference on static pressure needs? Yeah....going to have to disagree with you there.
@doyll - do you have that handy resistance chart of dust filters and mesh you could post? Our young friend is terribly misguided and I can't seem to find it.
Sorry for slow reply. Didn't get any notification.
Below link in post with lots of info and data of grill mesh open area vs no grill, filters, etc.
https://www.overclock.net/forum/22657923-post15.html
Phanteks PH-F140MP or PH-F120MP are quite good and some of my favorite case fans. Some places on Earth their 2-pack and 3-pack prices make them even better deals.
doyll is offline
post #18 of 34 (permalink) Old 05-11-2020, 08:04 AM - Thread Starter
Rep: 0
Hello! I read a lot of your posts! Thanks for the information you give! May I know your opinion regarding my first post on this topic? Which fan set do you think is the best for this case? Which fans do you recommend? With more static pressure?
post #19 of 34 (permalink) Old 05-11-2020, 08:07 AM
Owterspace's Avatar
Rep: 7 (Unique: 4)
Nope! That”s not how to get the most out of it. Looks good tho!
Indeed, I was just kidding around.. it does look good though!
post #20 of 34 (permalink) Old 05-11-2020, 08:48 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
I agree with @doyll on the Phanteks MP series. I run two 140mm and three 120mm in a build right now. Tried replacing the 140mm with the Arctic P14 to see what all the fuss was about, and changed them back to the MP immediately for better sound signature and performance in my setup. That said....I have unique circumstances in the way the fans are controlled. If I were to change that to a setup similar to yours, I would use the SW3 over the MP Series if price were not a concern. If I needed to save a few dollars, I would go with the MP.
ciarlatano is offline
