Fan setup for FD Meshify C - Page 4 - Overclock.net - An Overclocking Community
post #31 of 34 (permalink) Old 05-12-2020, 04:31 AM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
I took that foam out.
X5690 E.S. @ 4200MHz 1.35v/Thermalright Le Grand Macho RT/TF8/TY-143
Asus Rampage III Formula @ 200/3600/3600 Bios 0702/Intel 545S 256GB x2
16GB G.Skill + Super Talent Mix @ 800MHz 9-9-9-24 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1490/1900|Asus Xonar Essence ST/KEF M500
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x3/ZM-MFC2
Owterspace is offline
post #32 of 34 (permalink) Old 05-12-2020, 06:15 AM - Thread Starter
Rep: 0
@Owterspace
I can also remove the foam. need to install another filter instead? the only mesh on the front panel won't give a lot of dust?
@ciarlatano - many thanks!
friends I made a choice. my problem is solved! thank you everybody! thanks who helped!
Paradox42 is offline
post #33 of 34 (permalink) Old 05-12-2020, 08:06 AM
Owterspace's Avatar
Rep: 7 (Unique: 4)
In that case don't listen to me, I have a datavac so dust isn’t a concern for me.
post #34 of 34 (permalink) Old 05-12-2020, 09:42 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
Quote: Originally Posted by Paradox42 View Post
I can buy either TY-147b for $ 16, SW3 140 for $ 40, PH-F140MP for $ 16. The price is approximately the same in Russia.
The Phanteks warranty is 5 years, the bequiet is 6 years, and the Thermalwright is 2 years.
The price does not affect, but honestly, I do not really like the black and expensive SW3.
Please tell me, are PH-F140MP and 120 version in case cooling provided?
I have the opportunity to buy only those of all Phanteks models. Is this a normal purchase?
3 * 140 + 1 * 120.
For installation on pull and push in case. Meshify C has a thick foam filter in front, I think you need high static pressure.
But I look at bloggers and YouTube, many people put the PH-F120 (140) SP or XP - why?
Please bless me for a purchase ) Thank you!
Quote: Originally Posted by ciarlatano View Post
@Paradox42 - Given those options and pricing, I would recommend the Phanteks MP setup (two 140mm + one 120mm). They will be a cleaner mount than the Thermalrights for your usage. As for the YT guys....really just a case of the SP/XP being around longer, so you will see them in more videos. The MP are the better performing fans, and have a nicer sound profile.
What Ciarlatano said.
PH-F140MP and PH-F120MP are better fans than SP and XP.
MP have much bigger impeller so they make much more pressure at lower speeds than SP & XP do. And it's these lower speeds we are normally running our fans at.
doyll is offline
