What's the best price/performance CPU Cooler with the best RAM Clearance? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 38 (permalink) Old 05-13-2020, 12:42 PM - Thread Starter
New to OCN?
PontiacGTX's Avatar
Rep: 1545 (Unique: 927)
Quote: Originally Posted by doyll View Post
TRUE Spirit 140 Power only similarity to other TRUE cooler is it's a single tower. It's bigger, taller & wider and has 8mm heatpipes while all others have 6mm heatpipes.
Techpowerup uses a Thermaltake Core P3 case which isn't as closed in a most, but still not at test station. And they use room air temp not, but don't say when it is recorded .. and they really need to use cooler intake air temp recorded same time CPU temp is recorded.
So I don't trust their results
Tweaktown uses an INWIN D-Frame and again no idea when or where air temp is recorded except for saying it's "ambient room temperature" So again, no way of knowing if results are really accurate or not.
Might be able to better figure what coolers will fit once I scale center CPU to RAM and PCIe sockets.
I assumed the Power was pretty mucht he same as the Direct cooler but apparently Thermalright is delivering worse products, I dont know why they would downgrade the cooler and keeping the same name at least they should do like Noctua or CM and re-name it
The motherboard I would use it on might be the Z68 FTW temporarily then Z170 OCF but I mean doesnt the Scythe mugen 5 sounds like the best choice?
some reviews put it on the level of the FUMA and the Ninja 5(or slighly hotter than the Ninja 5) but that is impressive considering the dimensions of the cooler,or maybe I am imaging the Scythe Mugen 5 is smaller than it is?
also what about the ID-Cooling SE-234-ARGB it has some impressive results for what it is it seem to be slighly smaller than a Mugen 5 but it has a pric eof $35 I reading some review where it matched the mugen 5 with 1 fan
PontiacGTX is offline
post #12 of 38 (permalink) Old 05-13-2020, 01:11 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1390 (Unique: 720)
Thermalright Le Grand Macho RT! I've got one set aside for when my pump inevitably dies, but I haven't tried it on my 9900K yet. Did really well on my 6700, though.
Seems prices have went up on it though, used to be able to find it for $69 and now it's up to $79 on Amazon.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Gigabyte GA-H55N ITX
EVGA GTX 950 2GB
G.Skill DDR3-2133 8GB
Dierya 120GB SSD
Seagate Momentus 2.5" 500GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is offline
post #13 of 38 (permalink) Old 05-13-2020, 01:30 PM
doyll's Avatar
Rep: 1689 (Unique: 935)
Thermalright like other cooler companies has many different designs, sizes and shapes of coolers. Obviously bigger coolers with more or bigger heatpipes cool better than smaller ones with less heatpipes, as well as some designs work better than others. While I haven't tested any in over a year now, people I know who have say new ones are as well made as older ones. Most if not all issues with convex base are the result of more CPUs having bigger chips and flatter sometimes even convex bases .. end result is more mating / setting issues. And it's not just Thermalright coolers that have these issues.
I think the best way to solve this mating problem is check print and lap cooler base and maybe even IHS flat. This is nothing new. We've been doing this for many, many years.
I'm not home for next 14 hours. When I get home I will try and figure out your motherboard clearances and let you know. I assume the motherboards are EVGA Z68 FTW and AsRock Z170 OCF?
When looking at cooler reviews if the testing procedure does not clearly say air temp entering cooler is monitored and recorded at same time CPU temp is recorded the results are not going to be accurate. Most reviews do not do this so are worthless.
doyll is offline
post #14 of 38 (permalink) Old 05-13-2020, 01:57 PM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
+1 for LGMRT. It’s a beast. Bought mine about 2 years ago for 79..
X5690 E.S. @ 4200MHz 1.35v/Thermalright Le Grand Macho RT/TF8/TY-143
Asus Rampage III Formula @ 200/3600/3600 Bios 0702/Intel 545S 256GB x2
16GB G.Skill + Super Talent Mix @ 800MHz 9-9-9-24 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1490/1900|Asus Xonar Essence ST/KEF M500
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x3/ZM-MFC2
Owterspace is offline
post #15 of 38 (permalink) Old 05-14-2020, 01:24 AM
Linux Lobbyist
Rep: 6 (Unique: 6)
Don't forget to check if you can buy Thermalright Macho Rev. C, in case LGMRT is out of stock.
Dogzilla07 is offline
post #16 of 38 (permalink) Old 05-14-2020, 01:30 AM
Vandelay Industries
maltamonk's Avatar
Rep: 80 (Unique: 60)
Remember +/- 2C is margin of error +/- $5 is not
maltamonk is offline
post #17 of 38 (permalink) Old 05-14-2020, 04:55 AM
doyll's Avatar
On both motherboards 16x PCIe are more than far enough away for even the widest coolers to fit.
EVGA Z68 FTW has about 56-57mm center CPU toward RAM and about 122mm to near side 16x PCIe, but there is a x4 socket 20.3mm closer (101.7mm from center CPU).
AsRock Z170 OC center CPU to near side of RAM socket is about 49mm and about 77mm to near side of 16x PCIe. Cryorig R1 Universal will just fit with it's thin front fan.
With no RAM behind CPU on either of these mobos and plenty of room toward PCIe sockets there are many top tier coolers that will fit.
Some links to places you can buy from would be helpful. Then we can pick best of what is available to you.
doyll is offline
post #18 of 38 (permalink) Old 05-14-2020, 05:28 AM
OG AMD
Redwoodz's Avatar
Rep: 600 (Unique: 465)
Zalman CNPS17X- $69.
https://www.amazon.com/Zalman-CNPS17..._t1_B084ZWZXKX
https://www.kitguru.net/components/l...ua-look-out/2/
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #19 of 38 (permalink) Old 05-14-2020, 06:29 AM
doyll's Avatar
KitGuru testing is maginial at best. They say "ambient temperature was very stable at 18-19 degrees throughout our testing" but say nothing at all about where temperature is taken or when it is taken. If air temp entering cooler is not monitored and recorded at same time as CPU temp is recorded then results can be off by a large margin, like +/-5c or more. Air temp around cooler and test station is constantly changing because of constant changing heat sources .. heat sources lke lighting, PSU, CPU, GPU, even people involved in testng. All radiate heat into air making the air temp entering cooler much differnt than elsewhere in room.
CNPS17x specs look okay, but not much info to be found. No reviews with accurate testing.
doyll is offline
post #20 of 38 (permalink) Old 05-14-2020, 09:51 PM
OG AMD
Redwoodz's Avatar
Yes more testing needed but it should be a viable option judging them by their air cooler history. The fan makes me squirm a little but I can see the benefits.
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
TeamGroup Excalibur
AMD FX Vishera 8350
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
Optical Drive
Samsung BD
Zalman 9900MAX
Fractal Design R3
Operating System
AOC 22" LED
Keyboard
Logitech
Other
Redwoodz is offline
