What's the best price/performance CPU Cooler with the best RAM Clearance? - Overclock.net - An Overclocking Community
post #1 of 38 (permalink) Old 05-12-2020, 12:06 PM - Thread Starter
New to OCN?
PontiacGTX's Avatar
Rep: 1545 (Unique: 927)
I have been away from the market for a while recently my AIO's pump decided to stop working... so I wonder what are the best budget options for a cpu cooler? is still the best option the Mugen 5?
My Case is a Rosewill Throne. the Height clearance for the CPU cooler shouldn't be an issue
I can accept suggestion for old/ancient cooler like HE01 but preferably would like something with good noise-performance ratio
The best I could find locally was a BeQuiet Dark Rock 3 for $40 but it's too far from me. and Someone was selling a TR Venomous (1156) for $35
Coolers that I could buy on my price range:
FSP Group Windale 6
Thermalright Macho Direct
Scythe Mugen 5 Rev. B
Thermalright TRUE Spirit 140 Direct
PontiacGTX is offline
post #2 of 38 (permalink) Old 05-12-2020, 12:14 PM
Wonnebju's Avatar
Rep: 3 (Unique: 3)
Remove the oversized passive cooler => low profile ram. This should give you enough clearence for any Cooler.
The most budget air cooler is the boxed one ofc. But it is up to you if you can live with the noise and what type of usage/strain you put your cpu under.
2018
(18 items)
8700k
Asus ROG Strix X370-F Gaming
Gainward GTX 1080ti Golden Sample
Corsair Vengeance LPX
Samsung SSD 970
Seasonic Prime Gold 850W
Noctua - NH D15
Be Quiet - Silent Wings 3
Dark Base 900
Operating System
Windows 10 Education
Asus VG248HE
Monitor Asus VS248
Keyboard
Gigabyte Aivia Osmium (Red)
Mouse
Logitech G403
Mousepad
Glorious 3XL
Audio
Creative Soundblaster Z
Audio
Sennheiser PC360 G4me
Audio
Logitech Z2300
Wonnebju is offline
post #3 of 38 (permalink) Old 05-12-2020, 12:36 PM
Fix it till its broke
Owterspace's Avatar
Rep: 7 (Unique: 4)
I’d grab the venomous. I own lgmrt and ts140p and between those two lgmrt has the best clearance. I can’t speak for the others on your list..
X5690 E.S. @ 4200MHz 1.35v/Thermalright Le Grand Macho RT/TF8/TY-143
Asus Rampage III Formula @ 200/3600/3600 Bios 0702/Intel 545S 256GB x2
16GB G.Skill + Super Talent Mix @ 800MHz 9-9-9-24 2T 1.6v
EVGA GTX 980 Classified 3988 @ 1490/1900|Asus Xonar Essence ST/KEF M500
CM Silent Pro M2 850|Fractal Design Meshify C/Panaflo NMB x3/ZM-MFC2
Owterspace is offline
post #4 of 38 (permalink) Old 05-12-2020, 12:57 PM - Thread Starter
New to OCN?
PontiacGTX's Avatar
"lgmrt" le grand macho rt? I dont know how it compares to the Macho Direct also the Le Grand Macho (RT)(Direct) seem to have more Width than the True Spirit 140Direct
also review show the TR TS14D has great performance
though the Mugen 5 seem to be better in some benchmarks
Macho Direct:
102mm
Mugen 5:
85mm
True Spirit 140 Direct:
42mm
Winsdale 6:
110mm
post #5 of 38 (permalink) Old 05-12-2020, 07:57 PM
Owterspace's Avatar
Rep: 7 (Unique: 4)
The 140P blocks the closest dimm on my X58, and rubs on Z77 but still works pretty damn good for fifty bucks. As good as my Le Grand Macho. I could have sworn they quit making it but just checked amazon and they are loaded. I skipped the D as I had the room, and hot CPU’s.
post #6 of 38 (permalink) Old 05-12-2020, 08:24 PM - Thread Starter
New to OCN?
PontiacGTX's Avatar
Well they have iterations of it
True Spirit 140 (had green+blue colors)
True Spirit 140 Power (TY-14X fan design with black and white) redesign
True Spirit 140 Direct (TY-14X fan design with black) and HDT heatpipes, keeps similar design as Power but it has been shrunk
I think to avoid any clearance issues I am between the Mugen 5 and the ID-Cooling SE-234-ARGB
edit:
http://thermalright.com/product/true-spirit-140-power/
the 140 power is wider also taller that explains why it performs so bad compared to the ID-Cooling... perhaps I would still consider the two aboves
post #7 of 38 (permalink) Old 05-13-2020, 04:20 AM
Owterspace's Avatar
Rep: 7 (Unique: 4)
The 140P blocks the closest dimm on my X58, and rubs on Z77 but still works pretty damn good for fifty bucks. As good as my Le Grand Macho. I could have sworn they quit making it but just checked amazon and they are loaded. I skipped the D as I had the room, and hot CPU’️s.
edit:
Scythe makes good coolers. I don’t follow when you say the 140P performs so bad? Do you mean the 140D performs bad? It’s not a cooler I would buy personally just because I like to overclock.
post #8 of 38 (permalink) Old 05-13-2020, 04:53 AM
Retired Staff
Farih's Avatar
Rep: 108 (Unique: 89)
Scythe Fuma 2, Ninja and Mugen.
Thermalright Le Grand Macho, True Spirit.
Edit:
Most silent cooler I never heard is the Mugen PCGH btw.
It also has great RAM clearance.
1st PC >>> Ryzen 3700x @ PBO OC - 16GB 3800mhz CL16 - 1070ti @ 2123mhz
2nd PC >>> Intel I5-4790K @ 4,7ghz - 16GB 2133mhz - RX570
3rd PC >>> FX-6300 @ 4,5ghz - 8GB 1866mhz - GTX960
4th PC >>> Dual Core E5700 - 2GB 800mhz - HD6670
Main PC
(23 items)
AMD Ryzen 3700X
Asus Gaming TUF X570
Asus 1070ti Strix Advanced Binning @ 2123mhz
G.skill Ripjaws 16GB 3800mhz 16-16-16-36
Samsung 256GB NVME
Samsung 860 EVO 500GB
Seagate 3TB 7200rpm
Seagate 3TB 7200rpm
Corsair RMI 1000W
Scythe Fuma Triple Fan
Corsair AIR540
Iiyama 1440p
Keyboard
Logitech G413 Silver
Mouse
Logitech G403 Wired
Mouse
Razer Naga Trinity
Mousepad
A big one
Audio
Oppo Sonica DAC (modified)
Audio
Lehmann Linear headphone amp
Audio
AKG K812
Audio
Sennheiser HD650
Audio
Audioqeust Nighthawk
Audio
Beyerdynamic DT770
Audio
Focal Elear
I5-4790K @ 4,7ghz
Asus Z97 Pro Gaming
Sapphire RX570
16GB G.E.I.L Black Dragon 2400mhz
Samsung 860 EVO 256GB
Seasonic 500W
Scythe Fuma 2
Farih is offline
post #9 of 38 (permalink) Old 05-13-2020, 06:24 AM - Thread Starter
New to OCN?
PontiacGTX's Avatar
Yeah the 140D has smaller dimensions hence worse performance I thought that the 140D was the 140P with HDT
post #10 of 38 (permalink) Old 05-13-2020, 06:27 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
TRUE Spirit 140 Power only similarity to other TRUE cooler is it's a single tower. It's bigger, taller & wider and has 8mm heatpipes while all others have 6mm heatpipes.
Techpowerup uses a Thermaltake Core P3 case which isn't as closed in a most, but still not at test station. And they use room air temp not, but don't say when it is recorded .. and they really need to use cooler intake air temp recorded same time CPU temp is recorded.
So I don't trust their results
Tweaktown uses an INWIN D-Frame and again no idea when or where air temp is recorded except for saying it's "ambient room temperature" So again, no way of knowing if results are really accurate or not.
Might be able to better figure what coolers will fit once I scale center CPU to RAM and PCIe sockets.
doyll is offline
