Budget LGA1150 HSF <£25? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 25 (permalink) Old 05-20-2020, 02:38 PM - Thread Starter
Rep: 28 (Unique: 26)
All these fat arse coolers make me just want to get a Hyper 212 and forget about getting something that just barely fits for a few degrees better temps/lower noise. Wish they'd just standardize the spacings for cases/mobos for medium and XL and divide coolers into the too, too much pain in the bum checking each cooler to see if they fit!
Buttnose is offline
post #22 of 25 (permalink) Old 05-20-2020, 07:14 PM
Skylinestar's Avatar
Rep: 3 (Unique: 3)
ID-Cooling SE-224-XT. Not sure about your local price. I bought it for approx £16.
Main Rig
(19 items)
Intel Core i5 6500 @ 4256MHz
ASRock Fatal1ty Z170 Gaming K6
Palit JetStream GTX1070
Corsair Vengeance LPX 2666 DDR4 2x4GB
Crucial M4 128GB SSD
Kingston UV400 480GB SSD
WD Blue 500GB HDD
Optical Drive
LiteOn DVD-RW
Corsair GS700
Noctua NH-U14S
Phanteks PH-F140SP case fan
Noctua NF-P14s Redux 1200 case fan
Fractal Define R5
Operating System
Win10 Education Edition 64-bit
Dell S2716DG
Keyboard
Microsoft Internet Keyboard
Mouse
SteelSeries Rival 100
Mouse
SteelSeries QcK mini
Audio
HiVi Swan M50W
Skylinestar is offline
post #23 of 25 (permalink) Old 05-20-2020, 07:14 PM
New to OCN?
PontiacGTX's Avatar
Rep: 1545 (Unique: 927)
Mugen 5 for sure fits but it is going to be on the 50gbp range
PontiacGTX is offline
post #24 of 25 (permalink) Old 05-20-2020, 07:32 PM - Thread Starter
The ID-Cooling SE-224-XT doesn't seem to be available in the UK.
Think I'd rather go for one of the cheaper smaller coolers than the Mugen at that price.
Also @doyll I gave the wrong mobo model before, I'm actually using a Maximus Gene VI:
https://www.scan.co.uk/products/asus...x16)-hdmi-matx
Hope that doesn't bugger up which coolers would fit too much
Buttnose is offline
post #25 of 25 (permalink) Old 05-21-2020, 05:48 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
That changes things a lot. There are now more coolers that will fit.
Asus Maximus Gene VI center CPU to near side of PCIe socket is about 72.5mm and to near side of RAM socket is about 52.5mm with RAM only in front of CPU / cooler. Now we can use cooler with back offset to clear RAM.
Because larger coolers with more heatipipes cool better then can cool a lower wattage CPU with much less noise. I always use big coolers because of this. My systems like i7 6700K are inaudible unless working extremely hard like rendering graphics and even then just loud enough to audible. Same goes for i5 8500 65w TDP under Macho and even older i7-920 @ 4.2GHZ under TRUE Spirit 140 Power & i7 980 under PH-TC14PE systems.
Did more looking and seems there is kinda a shortage of 4x 6mm heatpipe 120mm fan coolers in the £20-30 range right now. Same is true of decent 6x 6mm /4x 8mm heatpipe coolers in the £30-40 range are also thin supply at the moment. Some sites are saying they expect some new stock end of the month, but that could be pie in the sky. A used Hyper 212 sold for £24.60 on ebay.
Your case accpets coolers up to 165mm tall.
I think with a little shopping around for a few days, maybe a week and you can find a good cooler for £30-35. That is what I would be looking for if it was me. But if you really want a small 4x 6mm heatpipe 120mm fan cooler it will do the job, just not as quietly as a better cooler will. To me paying morefor a better cooler is an investment for future builds. So instead of spending £30 now and £30 when you build next system I would spend £35-45 now and use it for a couple or more builds.
doyll is offline
