8700k Temps - Overclock.net - An Overclocking Community
8700k Temps
post #1 of 11 (permalink) Old 05-20-2020, 06:38 PM - Thread Starter
BTK
BTK's Avatar
Rep: 113 (Unique: 93)
8700k Temps
I have an 8700K at 4.7 GHz and in prime with avx it hits 95c but in games it goes to 65c to 75c
1.2v voltage and nh d15 cooler
ambient is around 60 to 75f
i was just wondering if these temps were ok idle is around 28c to 35c
BTK is my initials if you were wondering.
i7 8700K - GTX 1080ti -32 GB RAM - ASUS PG35VQ
i5 8600K - GTX 1080 - 16 GB RAM - ASUS PG27UQ
BTK is offline
post #2 of 11 (permalink) Old 05-20-2020, 08:44 PM
NewUser16's Avatar
Rep: 54 (Unique: 36)
8700k is one of the hottest CPU’s, it’s insanely hot even at stock speeds and prime95 is unrealistic, so your temps are very exceptionall
Caselabs S8S SSI EEB/4x Noctua NF-S12A
Asus x99 E-WS 10G/Asus AX3000 Dual Band PCI-E WiFi 6
i7 6950X/Noctua NH-D15S with dual NF-A15 140mm fans
Aquacomputer Aquaero 6 XT
Seasonic Platinum-1200(SS-1200XP3)
EVGA Titan Black SC
Corsair Vengeance LPX 128GB (8 x 16GB) DDR4, 2666MHz
NewUser16 is offline
post #3 of 11 (permalink) Old 05-21-2020, 03:34 AM
Rep: 13 (Unique: 12)
The 8700k it's hot, but not because of its power consumption or thermal density. It's because of the tooth paste.
Your temps, are what you would expect from a CPU like that.
By the way. If you're giving us temps, give us temps in one unit of measurement not 20. I understand you guys have a problem there, but it's not ours.
Shenhua is offline
post #4 of 11 (permalink) Old 05-21-2020, 06:52 AM
NewUser16's Avatar
Perhaps, you should tone down the attitude, that arrogance of yours won’t get you far neither here or in real life.
Btw. If you can't convert simple F to C and vice-versa and have to make such fuss over that.... you definitely have a problem.
EVGA Titan Black SC
post #5 of 11 (permalink) Old 05-21-2020, 07:34 AM
Call it what you want. You have most monitoring tools using a system that the whole globe is using, you use them too,..... then you're giving values in another system of measurement, cus y.o.l.o.
It's like "im not Spanish, im Catalan (province of Spain), so I'm gonna speak to you in dialect and call it a language only because my ancestors decided they wanted to butcher the main language and I'm so proud of them that I'm gonna speak to you in Catalan, even if we don't understand each other and/or has no practical use in the situation at hand".
It's not arrogance, i just can't stand some things.....and by the way, modesty will keep you stuck in the same place untill you die, it won't get you far either. I'll rather be arrogant, beaten down to my own place, than modest and smell more confident ppl as***s my whole life.
If you are trying to measure something stop overcomplicating things unnecessarily. I'm not saying to use a certain system of measurement over other, I'm saying, choose one and stick with it.
Shenhua is offline
post #6 of 11 (permalink) Old 05-21-2020, 07:43 AM
elucid087's Avatar
Rep: 9 (Unique: 7)
My ambient room temp is higher than average and mine usually hovers between 30-35c. It's perfectly normal even with decent cooling.
4.8GHz @ 1.264v w/ an H115i pro here.
"Atheism never killed anyone" - Bill Maher
elucid087 is offline
post #7 of 11 (permalink) Old 05-21-2020, 07:48 AM
Nvidia Enthusiast
philhalo66's Avatar
Rep: 270 (Unique: 211)
that's pretty par for the course with intel. If you want lower temps you can always delid and use liquid metal, just be sure you insulate any SMD components on the substrate.
gaming rig
(18 items)
Intel Core i9 9900K 5GHz 1.3V
GIGABYTE Z390 AORUS PRO
EVGA RTX 2080 Ti FTW3 Ultra Hybrid
G.SKILL Ripjaws V DDR4 3600MHz 32GB
HGST 2TB
Seagate 2.5 Inch 2TB
Samsung 860 EVO 1TB
Intel 660p NVME 512GB
Optical Drive
LG Blu Ray drive
Corsair RM850i 850W
EVGA CLC 360MM Corsair LL120
Corsair Graphite 780T White
Operating System
windows 10 Pro
MSI OPTIX MAG24C
Acer XFA240 bmjdpr
Keyboard
G.SKILL RIPJAWS KM780 MX
Mouse
Razer Deathadder Elite
Audio
Sound Blaster Z
philhalo66 is offline
post #8 of 11 (permalink) Old 05-21-2020, 08:33 AM
NewUser16's Avatar
You can give me all "your" philosophies and reasons you want, I won’t even bother, you have totally missed the point, but I'm sure in your mind, your theory is right
Good luck with that attitude of yours
EVGA Titan Black SC
post #9 of 11 (permalink) Old 05-21-2020, 11:58 AM
doyll's Avatar
Rep: 1689 (Unique: 935)
ambient is around 65 to 75f
Sounds like your temps are fine.
Prime works CPU harder than 99.9% of users ever do. 28-35c idle and 65-75c gaming is good. What are case and cooler fan speeds when gaming at 60-67c?
doyll is offline
post #10 of 11 (permalink) Old 05-21-2020, 05:56 PM - Thread Starter
BTK
BTK's Avatar
Phanteks enthoo primo with 7 fans and d15 @ 100% fan speed
BTK is offline
