Case fans setup question - Overclock.net - An Overclocking Community
post #1 of 28 (permalink) Old 05-21-2020, 01:57 PM - Thread Starter
sonic2911's Avatar
Rep: 4 (Unique: 4)
Hi, I want to setup fans for my case again. My case is Phanteks Evolv TG, I modded front panel for better airflow, now replacing fans is my next step.
I'm using Noctua D15 with 2 TY-147B, 2 front intake fans I use the stock fans of the D15's, 1 rear exhaust fan I use TY-147ASQ.
Now I want to replace 2 front intake fans, i'm not sure 3x12 better than 2x14 or not? And I don't want to use rear fan anymore.
So what fans can I buy in US? TY-143 is impossible to buy here.
sonic2911 is offline
post #2 of 28 (permalink) Old 05-21-2020, 02:52 PM
Rep: 1 (Unique: 1)
I would vote 3x120 (360) > 2x140 (280). Logic being more surface area. I would definitely keep the rear exhaust fan. If you lose it, how will you evacuate air from the case?
Mxj1 is offline
post #3 of 28 (permalink) Old 05-21-2020, 03:06 PM - Thread Starter
sonic2911's Avatar
Rep: 4 (Unique: 4)
It will flow out natively, I guess
post #4 of 28 (permalink) Old 05-21-2020, 03:34 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 438 (Unique: 291)
I've tested numerous 2x140 and 3x120 combos in the Evolv. The 2x140 is the way to go. Look at the design of the case, using 120mm has one blowing almost entirely under the PSU shroud making it useless. So yo are almost comparing 2x140 against 2x120. No brainier there.
ciarlatano is offline
post #5 of 28 (permalink) Old 05-21-2020, 04:38 PM - Thread Starter
sonic2911's Avatar
Rep: 4 (Unique: 4)
That's what I think too. What fans are you using now?
Sent from my SM-N975U1 using Tapatalk
post #6 of 28 (permalink) Old 05-21-2020, 05:18 PM
ciarlatano's Avatar
My setup is a little odd in that I'm running a single fan curve for the 2 140mm intakes and 3 120mm rad fans exhausting on top. So, a lot of what I am using has to do with the balance between them rather than them being the best fans I have. The be quiet SW3 are the best fans I've tested, but the 140 and 120 don't scale right together in my setup. After trying the usual suspects (Noctua, Corsair, NB, EK, Arctic...There were more....), I preferred the Phanteks MP series for the application. If I were running air cooling or wanted to change the fan control setup, it would be SW3s all around.
post #7 of 28 (permalink) Old 05-21-2020, 05:37 PM - Thread Starter
sonic2911's Avatar
Rep: 4 (Unique: 4)
The MP's is good for rad AFAIK, so maybe I will get the sw3 because I don't have plan to go AIO or CLC now. There are 3 models of sw3, 140 140 pmw 140 pmw highspeed..which one?
post #8 of 28 (permalink) Old 05-21-2020, 06:53 PM
D-EJ915's Avatar
Rep: 15 (Unique: 14)
The difference is if you are going to use PWM (4-pin) or voltage control (3-pin) as they both have 1000 and 1600 RPM models.
Kanna
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #9 of 28 (permalink) Old 05-21-2020, 06:54 PM - Thread Starter
sonic2911's Avatar
Rep: 4 (Unique: 4)
There are 2 pmw models too
post #10 of 28 (permalink) Old 05-21-2020, 06:56 PM
D-EJ915's Avatar
Yes both 3-pin and 4-pin (PWM) have 1000 and 1600 RPM models. So get the model you want the fan speed for with the connector you want.
Kanna
Mitty
(11 items)
Intel i7-7820X
Asus Strix 1080 Ti
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
Intel i7-3930k
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
