Thermal paste cleaning? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 05-22-2020, 11:36 PM - Thread Starter
Ecopot's Avatar
Rep: 3 (Unique: 3)
Bought a new scythe cooler, but because Corona can’t find isopropyl alcohol. Any alternatives? Got simple green or witch hazel...
Sent from my iPhone using Tapatalk
https://www.overclock.net/forum/1808...ook-shelf.html
AMD 3500
Biostar B450GT3
Radeon RX 560
T-Force Vulcan Z
M.2 XPG SX8200 Pro
Enhance Rage Power
Scythe Choten
Porable Book Shelf
Ecopot is offline
post #2 of 14 (permalink) Old 05-22-2020, 11:41 PM
Stock is too casual~
Veii's Avatar
Rep: 78 (Unique: 46)
People will hate me for this suggestion, but Window Cleaner works wonderfully
But up to location it can have different types of sticky residue and perfumes inside mixed
Just water and a microfibre cloath - actually even toilet paper with water works well enough
If we consider it got somewhere on the board or dare not, inside the socket
WD-40 Contact cleaner ~ the alcohol free and oil free version of it - does a wonderful job
WD-40 Contact cleaner even does polish the copper a bit
Many options out there, even home perfume and then water afterwards work great
~ pick whatever non oily non sticky fluid you want (:
Usually you just dry wipe it first away, then with something non sticky to polish and clean any residues from it
I hope the paste you used (not watery) was non conductive
SiSandra Inter-Core Bandwith 14nm Ryzen global #1 | Twitter
Personal Records
RAM > Viper Steel @ 3466C14 (64.2ns) & Alt | Hynix-MFR 3333CL14 (72.5ns) & Alt
GPU > Gigabyte 970 G1 @ 1595|1900 (Hynix) | RX 580 Red Devil GS @ 1620|2200 (Micron)
CPU > TR 1950X [email protected]1.2v & [email protected]1.365v[105Mhz FSB](3.23Beta)
#Main: 1700X [email protected]1.365v1.73Ghz IMC CL14 (64.2ns)」+ Dark Rock 3 | X370 Taichi 1.0.0.3 ABBA by The Stilt | Viper Steel [PVS416G400C9K]| Gigabyte 970 G1 | Samsung 850 Evo
Veii is offline
post #3 of 14 (permalink) Old 05-23-2020, 12:39 AM
rdr09's Avatar
Rep: 886 (Unique: 640)
I may have to try window cleaner. I use disinfectant wipes for bathrooms (wring first) and follow it up with coffee filter. Thanks for the tip.
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #4 of 14 (permalink) Old 05-23-2020, 03:00 AM
Veii's Avatar
The coffee filter advice is great
For us our window cleaner is pretty much isopropanol and non staining substances with a bit of fresh smell that vaporizes quite fast
the paper does wipe away anything chemical that maaybe with an already low chance, could harm the paste composition
It's a very low chance to begin with, soo window cleaner does a wonderful job
The oil of your skin has a higher risk to decrease paste effectiveness than window cleaner
~ but even that barely does a difference at all
Well it's region dependent what they sell
At worst their thin chemical "protective layer against staining ~ windows" will dissolve away by the heat of the cpu near 70-80c
Soo it shouldn't matter at all, just water works too, tho i think tape water with it's water-lime is less clean than isopropanol mixtures
Personal Records
Veii is offline
post #5 of 14 (permalink) Old 05-23-2020, 06:17 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 440 (Unique: 293)
Wipe all you can off with a dry cloth, tlittle Simple Green sprayed onto a paper towel or cloth should take it right off, depending on the TIM and whether the contact plate is polished. The already mentioned window cleaner used the same way works, as well and is my usual method.
NT-H1/2, MX-4, GC Extreme and many others all come right off with a dry cloth, no cleaners needed.
ciarlatano is offline
post #6 of 14 (permalink) Old 05-23-2020, 06:37 AM - Thread Starter
Ecopot's Avatar
Rep: 3 (Unique: 3)
Thanks, just tried the blue shop towels and a little water. Did the best I could with the stock AMD paste that was stuck on there. Think I applied too much paste in the new install though.. may have to redo it again.
AMD 3500
Biostar B450GT3
Radeon RX 560
T-Force Vulcan Z
M.2 XPG SX8200 Pro
Enhance Rage Power
Scythe Choten
Porable Book Shelf
Ecopot is offline
post #7 of 14 (permalink) Old 05-23-2020, 06:43 AM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
Mineral spirits little smelly though.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #8 of 14 (permalink) Old 05-23-2020, 06:47 AM
Missing the Old days
Cerberus's Avatar
Rep: 258 (Unique: 218)
just wipe it off with a paper towel and a dab of water.
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #9 of 14 (permalink) Old 05-23-2020, 06:54 AM
Weasel Pimp
crappy's Avatar
Rep: 7 (Unique: 7)
There are a fair few cleaners out there. I use either akasa TIM Clean or Arctic Silver Arcticlean, which is a 2 part system. Both do the job really well, I probably prefer the Arctic as it has part 1 which is the TIM cleaner/degreaser similar to the akasa stuff, but then part 2 which I think is mostly alcohol to remove any residues left by the cleaner. The akasa is fine and you can get any residue off just by using a clean dry paper towel, but it's nice to have both.
I use the akasa on loads of other stuff too, it's excellent for removing residue from stickers and glue.
crappy is offline
post #10 of 14 (permalink) Old 05-23-2020, 06:55 AM
Veii's Avatar
Little personal advice
Use nitrile gloves, or any kind of kitchen/toilet thin sillicon gloves for applying paste
Found it to be helping, applying a thin layer of paste - as it doesn't seem to stick on nitrile that much as it does on the spatulas that come with 3rd party pastes
Personal Records
Veii is offline
