Noctua NF-A12x25 for open air case fan or something cheaper? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 05-27-2020, 05:34 AM - Thread Starter
MakubeX's Avatar
Rep: 120 (Unique: 113)
Like a lot of us, I'm looking to keep my PC as quiet as possible while maintaining low temperatures, especially now that I'm working from home all the time. I naturally got a couple of NF-A12s for my radiator but, for "open air" low resistance fan locations, such as the rear exhaust of the case, is it worth it?
I've been considering the be quiet silentwings 3 instead but they are almost as expensive as the NF-A12s so I feel I might as well get the Noctua (despite their color scheme not quite matching the rest).
I've also considered the Arctic P12 PWM but they seemed geared more towards higher static pressure situations. They might still be good, though.
Any other fans I should consider? Should I just get more Noctuas?
MakubeX is offline
post #2 of 11 (permalink) Old 05-27-2020, 09:14 AM
poah's Avatar
Rep: 8 (Unique: 7)
I'd get the arctics
poah is offline
post #3 of 11 (permalink) Old 05-27-2020, 09:19 AM
Shawnb99's Avatar
Rep: 60 (Unique: 41)
For open air you want whatever has the highest CFM at the lowest db you can handle. Noctua's likely do have the best CFM/noise ratio but at a very high cost.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #4 of 11 (permalink) Old 05-27-2020, 09:49 AM
doyll's Avatar
Rep: 1696 (Unique: 938)
No.
Silent Wings 3 PWM high speed are best fan I know of. They are definitely better with a more pleasant sound when audible than others, even Noctua.
Fans with high CFM and high mm H2O flow about the same as fans with high CFM and low mm H2O in open use. That means no filters or fancy grills.
I believe be quiet! Silent Wings 3 PWM high speed will have best cfm to noise ratio.
Much depends on where on Earth you are because what I can get is likely not the same as what you can. Some links to where you buy would be helpful.
doyll is online now
post #5 of 11 (permalink) Old 05-27-2020, 10:17 AM
Martin778's Avatar
Rep: 17 (Unique: 17)
Depends, I've had Silent Wings 3's, Corsair ML and various other brands and models and the NF-A12x25 has a unique sound signature, very similar to Gentle Typhoons (also known as Nidec Servo fans) meaning they can run full speed at 2000RPM and still won't produce any noticeable wind rumble like for example the ML's do.
Keep in mind they Noctuals will get very, very costly if you'd want to expand and keep the same model.
Threadripper 3960X @ broken PBO EDC=40 | Aorus TRX40 Xtreme | Enermax Liqtech II 360 TR4 + EK Clear flush + 3x Noctua A12x25 | 4x8GB G.Skill TridentZ Neo 3800C14 @ 3733 CL14-15-15-30 CR1 | EVGA Kingpin 2080Ti @ 2115MHz / 8250MHz + Noctua A12-25 | 4x1TB 970 PRO raid0 | Corsair MP600 2TB | Seasonic Prime Platinum 1300W | In Win D-Frame 2.0 Gold | ASUS PG349Q
Martin778 is offline
post #6 of 11 (permalink) Old 05-27-2020, 10:45 AM - Thread Starter
MakubeX's Avatar
A lot of good points here. Much appreciated. I'll need to think about it some more.
Quote: Originally Posted by doyll View Post
No.
I'm in the US so I'd be buying from Newegg or Amazon.
MakubeX is offline
post #7 of 11 (permalink) Old 05-27-2020, 10:47 AM - Thread Starter
MakubeX's Avatar
Good old Gentle Typhoons. Good to know about the sound signature.
PS. I don't plan on running these at a high RPM. Most likely under 1400, if that makes any difference to anyone's recommendations. I'm very focused on silence.
MakubeX is offline
post #8 of 11 (permalink) Old 05-27-2020, 12:59 PM - Thread Starter
MakubeX's Avatar
I ordered one silentwings 3 PWM high-speed to test out. I don't plan on running it a high RPMs but, it appears there's a big RPM drop-off that occurs with these fans when dropping the PWM from 100% so I decided to go with the high-speed to compensate. I don't know if I'll have that drop-off issue with the Corsair commander pro but, better be safe. I hope the fan has no issues running at low RPMs.
MakubeX is offline
post #9 of 11 (permalink) Old 05-27-2020, 02:18 PM
doyll's Avatar
The PWM control problem is with only a very few controllers, aquaero being the main one.
doyll is online now
post #10 of 11 (permalink) Old 05-28-2020, 12:16 PM
Rep: 14 (Unique: 12)
Considering he is asking for no restrictions case fan, probably, he'll never run them past 1000.
OP
Take a look at schyte kaze flex. The 1200 seems to have good numbers, they sound great and they're not bad quality.
In spain i can get my hands on them for 10 bucks each.
Shenhua is offline
