Help choosing a cooler - Overclock.net - An Overclocking Community
post #1 of 34 (permalink) Old 06-04-2020, 09:13 AM - Thread Starter
Gamer
Cysquatch's Avatar
Rep: 74 (Unique: 49)
I was talked out of doing any sort of water cooling in my last thread. I'm going to upgrade my air cooler to a top tier air cooler. My first choice of cooler seems to be out of stock everywhere (NH-D15) So i need some help picking a cooler with similar performance. This is for the PC in my sig. Thanks!
Gaming Rig
(12 items)
Ryzen 5 3600
MSI B450 Tomahawk Max
Sapphire Nitro+ RX 5700 XT 8G GDDR6
Crucial Ballistix 16GB (2 x 8GB) DDR4 3600
Silicon Power 1TB P34A80
Seasonic FOCUS Plus SSR-650FX
Noctua NH U12S
Fractal Design Meshify C
Operating System
Windows 10 Pro
Dell S2419HGF
Keyboard
Razer Blackwidow Elite
Mouse
UtechSmart Venus
Cysquatch is offline
post #2 of 34 (permalink) Old 06-04-2020, 09:21 AM
doyll's Avatar
Rep: 1696 (Unique: 938)
Is this your sig rig? Where on Earth are you? Can you give us a few sites to look at what is available there so we can suggest coolers you can get?
doyll is offline
post #3 of 34 (permalink) Old 06-04-2020, 09:26 AM - Thread Starter
Gamer
Cysquatch's Avatar
I'm in the US, yes it is my sig rig. Thanks!
Gaming Rig
(12 items)
Ryzen 5 3600
Noctua NH U12S
Operating System
Windows 10 Pro
Dell S2419HGF
Keyboard
Mouse
UtechSmart Venus
post #4 of 34 (permalink) Old 06-04-2020, 09:44 AM
Avid Memer
chessmyantidrug's Avatar
Rep: 245 (Unique: 181)
For an R5 3600, you can use pretty much any decent air cooler. It doesn't produce much heat. If you already have the NH-U12S, there's no need to change coolers. If you want better performance, you can grab one or two NF-A12x25 fans to replace the what you have on there currently.
ITX gaming system
(17 items)
i9-9900KF
ASRock Z390 Phantom Gaming ITX/AC
EVGA RTX 2070 Super Black Gaming
Crucial Ballistix
Samsung 970 Evo
Samsung 850 Pro
Samsung 850 Pro
Seagate FireCuda
Seasonic FOCUS SGX
Scythe Big Shuriken 3
SilverStone FTZ01-E
Operating System
Windows 10 Home
BenQ XL2420Z
BenQ RL2455HM
Keyboard
Deck Legend Fire
Mouse
SteelSeries Rival 500
Mousepad
HyperX Fury S Cloud9 Edition
chessmyantidrug is offline
post #5 of 34 (permalink) Old 06-04-2020, 09:51 AM
doyll's Avatar
MSi B450 Tomahawk Max has about 50mm center CPU to near side of RAM socket and 90 center CPU to near side of PCIe x16.
I think your RAM is only about 30mm tall so should be fine there
Meshify C has 170mm CPU clearance so even the tallest coolers should fit, and if RAM is 30mm tall (33mm surface of motherboard to top of RAM) 140mm fan will fit over RAM.
2x rated 140mm or 3x 120mm in front and 1x 120mm high pressure rated intake fans with all openings not covered by them blocked off so air they push into case has to move through case to get out not leak out by fans and go in circles and a good CPU cooler.
Looks like NH-D15S is available on Amazon. I'm off to work so will check back later.
doyll is offline
post #6 of 34 (permalink) Old 06-04-2020, 10:26 AM - Thread Starter
Gamer
Cysquatch's Avatar
I understand I don't need to, but I'm going to push my overclocks, and could use a little more headroom.
I forgot about this model, thanks!
Gaming Rig
(12 items)
Ryzen 5 3600
Noctua NH U12S
Operating System
Windows 10 Pro
Dell S2419HGF
Keyboard
Mouse
UtechSmart Venus
post #7 of 34 (permalink) Old 06-04-2020, 11:34 AM
doyll's Avatar
It's within a degree as good as D15 with 2 fans but is offset for better PCIe clearance. There are other coolers as good and lower cost, but I can't find any in your market area at this time.
doyll is offline
post #8 of 34 (permalink) Old 06-04-2020, 11:37 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
The D15S is a great choice if you were looking for a D15. I have both and prefer the 15S since it gives a little more room for the GPU. With the same fans the D15 and D15S will produce identical performance. Even with only one fan on the D15S, there is a minimal difference (~2-3C) in performance. Amazon also has the Thermalright LGMRT (https://www.amazon.com/Grand-Macho-R...dp/B01BCLXO7Q/) in stock, and it is comparable with the D15/D15S.
That said, NewEgg has the PH-TC14PE in stock (bit of a price gouge, though), as well as the Dark Rock Pro 4, Raijintek TISIS, and a few others worth considering.
ciarlatano is offline
post #9 of 34 (permalink) Old 06-04-2020, 12:09 PM
doyll's Avatar
I missed it.
Thermalright Le Grand Macho RT is actually 3-4c better cooler than NH-D15S, some tests show is a degree better and a couple dB quieter than than NH-D15, but that is too close to call a significant 'better'. But if we take into account Le Grand Macho RT TY-147B rated 73.6cfm fan is 200rpm slower and 9.1cfm less airflow than D15 with 2x A15 fans rated 82.5cfm, 3-4dB quieter and still cools as well or slightly better to me makes it the better cooler.
doyll is offline
post #10 of 34 (permalink) Old 06-04-2020, 12:10 PM
gtz
Old to Overclock.net
gtz's Avatar
Rep: 67 (Unique: 58)
I just purchased the Thermalright LGMRT and am very impressed with its performance. Doing a great job keeping a 3950x in check.
It is currently available at Amazon.
Ultra Instinct
(14 items)
AMD RYZEN 9 3900X
ASUS CROSSHAIR VII HERO
NVIDIA RTX2080TI
GSKILL 32GB (2X16GB) DDR4 3700 CL16
HP EX900 500GB NVME (OS)
HP EX900 500GB NVME (STORAGE)
SANDISK 960GB SATA III SSD (BACK UP)
EVGA SFX 650GM
GELID PHANTOM BLACK
JONSBO UMX4
Operating System
WINDOWS 10 PRO
ALIENWARE 34IN IPS ULTRAWIDE 120HZ 3440X1440P
Keyboard
AZIO MECHANICAL BROWN
Mouse
AZIO
gtz is offline
