280x crystal + 10900k - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 06-30-2020, 01:45 AM - Thread Starter
Amph's Avatar
Rep: 1 (Unique: 1)
what the best air cooling for this setup? NHd15 can do it?
Amph is offline
post #2 of 13 (permalink) Old 06-30-2020, 01:59 AM
MrTOOSHORT's Avatar
Rep: 1528 (Unique: 1055)
10900K  •  M12A  •  4000CL19 2x16  •  KPE 2080TI HC  • 34GK950F-B • 905P AIC • 1600T2  •  800D
MrTOOSHORT is offline
post #3 of 13 (permalink) Old 06-30-2020, 02:25 AM
Rep: 2 (Unique: 2)
You won't be able to fit a Nh-D15 in that case without removing the side panel. I have one of these and your only "good" option is watercooling, be it a custom loop or a 240/280mm aio, the best air cooler that will fit is maybe the Nh-L12 or something similar.
i9 9900kf
Maximus XI Gene
Msi Gtx 1080 Ti Gaming X
TXKD416G4500HC18EDC01
Corsair Hx Platinum
Corsair H100i Rgb Platinum (with Noctua Chromax nf-f12's)
Corsair Crystal 280x
Acer VG271U 27" 1440p
Keyboard
Ducky One 2 TKL
Mouse
Razer Viper Ultimate
Mousepad
HyperX Fury S
Audio
Beyerdynamic Dt 770 Pro 80ohm
Other
4x Chromax Nf-A14's / 2x Chromax Nf-F12's
Roidsy is offline
post #4 of 13 (permalink) Old 06-30-2020, 02:44 AM - Thread Starter
Amph's Avatar
Rep: 1 (Unique: 1)
i want to stick with air cooling, so the best is nd-L12s?
Amph is offline
post #5 of 13 (permalink) Old 06-30-2020, 04:16 AM
Linux Lobbyist
Rep: 8 (Unique: 7)
Best cooling for that case would be Arctic 280mm Liquid Freezer II, water cooler.
For Air best would be Thermalright Silver Arrow ITX-R > Old Scythe Fuma (Rev. B) (SCFM-1100) > be quiet! Dark Rock TF > Noctua NH-C14S.
In this descending order (with the last noctua being equal to be quiet if u add a second fan, but still worse than the Fuma and Silver Arrow).
Dogzilla07 is offline
post #6 of 13 (permalink) Old 06-30-2020, 05:58 AM - Thread Starter
Amph's Avatar
Rep: 1 (Unique: 1)
none will fit in the 280x
Amph is offline
post #7 of 13 (permalink) Old 06-30-2020, 06:05 AM
yanks8981's Avatar
Rep: 301 (Unique: 249)
I know its not technically air, but the H100i is what I got when I switched to this case. Its as easy to install as an air cooler without any of the clearance issues.
yanks8981 is offline
post #8 of 13 (permalink) Old 06-30-2020, 03:03 PM
Linux Lobbyist
Rep: 8 (Unique: 7)
Quote: Originally Posted by Amph View Post
none will fit in the 20x
How so, If I'm not mistaken we're talking about the 280x, which has 150mm cooler clearance, and all 4 air coolers I mentioned are < 150mm ?
post #9 of 13 (permalink) Old 06-30-2020, 04:28 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
No. @Dogzilla07 just gave you four better options.
My concern would be getting airflow. That case looks seriously choked.
ciarlatano is offline
post #10 of 13 (permalink) Old 06-30-2020, 10:05 PM - Thread Starter
Amph's Avatar
Rep: 1 (Unique: 1)
you are right the arrow is 147, dunno why i searched and i found a different one, so the arrow based on your opinion should to the job? even if i oc?
Amph is offline
