3900x nh d15. Extreme temperatures. - Overclock.net - An Overclocking Community
post #1 of 27 (permalink) Old 07-06-2020, 04:35 AM - Thread Starter
Rep: 14 (Unique: 12)
System:
Define S, 3 x nf a14 front intake, 1 stock fan rear exhaust. Front panel and filter removed.
Cooler nh d15
Mobo crosshair 6 hero (bios 7803)
3900x
In prime95 at 4,3ghz, 1,275v, 160w (core+soc power) hits 93-94ºC at max fan speed and 25ºC ambient temperature, which would make about 70ºC delta. Is that normal? Isnt that too much? Ik ryzen 3000 thermal density is high, but im seeing GN temps with 198w on 3950x (same exact internal layout like 3900x) sitting at 55ºC delta on a test bench, which is probably worst compared to the "wind tunnel" i have here.
Shenhua is offline
post #2 of 27 (permalink) Old 07-06-2020, 04:46 AM
Fix it till its broke
Owterspace's Avatar
Rep: 9 (Unique: 5)
That’s a big case.. are you moving enough air inside?
3770K @ 4700MHz 1.35v/Thermalright True Spirit 140 Power TY-143 Push/Pull
ASRock Z77 OC Formula|8GB G.Skill Mix @ 1100MHz 9-11-9-28-2T 1.68v
EVGA GTX 980 Classified 3988 @ 1497/2001|Intel 545S 256 Striped
CM Silent Pro M2 850|Fractal Define R4/5x 120x38 1x 92x38|ZM-MFC2
Owterspace is offline
post #3 of 27 (permalink) Old 07-06-2020, 04:49 AM - Thread Starter
it´s all in the comment, read all. Everything is at max speed, front panel and filter removed, and 3xnf a14 as intake. Im pretty sure the test enclosure it´s not the problem, as it reaches max temp in 2-3min, and has been used in the past for other system giving excelent results as a setup.
Shenhua is offline
post #4 of 27 (permalink) Old 07-06-2020, 05:00 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
Check the mount of the cooler. Likely needs to be remounted
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #5 of 27 (permalink) Old 07-06-2020, 05:18 AM
doyll's Avatar
Rep: 1702 (Unique: 941)
What Shawnb99 said.
First thing is check mount. I know it's probably not the problem but are you sure you removed clear tape on cooler base? Many of us have done that a time or two. If you don't find anything wrong and have enought TIM, remove, clean, re-apply TIM and remount.
Another possiblity is your 3900x motherboard combo needs some setting changes.
Many new builds with 3900x have experience high temps. Maybe try posting on AMD forum if remounting doesn't solve problem.
https://www.overclock.net/forum/10-amd-cpus/
doyll is offline
post #6 of 27 (permalink) Old 07-06-2020, 05:31 AM
skline00's Avatar
Rep: 16 (Unique: 14)
Shenua, is your 3900x manually OC'd? If so, reset BIOS to stock and rerun Prime95.
In addition, I agree completely with Shawnb99.
You also may want to improve the exhaust fan. I purchased a Noctua Exhaust fan for my 3900x rig and it really does help.
Think about it. Per your specs you have THREE (emphasis added) intake fans and ONE stock exhaust fan.
Just for fun switch one of the intake fans with your exhaust fan and run 2 intake to 1 GOOD exhaust.
9900k-5.0-Krak X72|Asrck Z390 Taichi|32g-DDR4-3200 FlrX|EVGA GTX 2080TI XC | Crsr MP500-480g+ 2-1tb ssds|EVGA 1000W|Thmtake V51|Acer ET430k|Win10-64 home + Oculus Rift
3900x stock Custom WC Optimus WB; 480+360 rads EK D5|MSI X570 Unify|32g-DDR4-3600 TriZ Neo|Asrck Rad VII-EK blk |Sbrent Rocket 1tb NVME4|Crsr RX850|Fractal Design 7XL|BenQ EX3501R
skline00 is offline
post #7 of 27 (permalink) Old 07-06-2020, 05:45 AM
The last VRM burner
Rep: 48 (Unique: 28)
Move a bottom front fan to the top of your chassis just above the D15 and see if there are changes in temperature.
PC for all
(23 items)
i7 5775c @4.2GHz/3.8GHz
MSI Z97 MPower
Iris Pro 6200 1300MHz
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Front Arctic P14 PWM PST x2
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mouse
Tiger Gaming Arc teflon mouse feet
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #8 of 27 (permalink) Old 07-06-2020, 06:04 AM
Slurpee Addict
JennyBeans's Avatar
Rep: 39 (Unique: 3)
yeah you shouldn't be getting those temps with that cooler
The Penguin Build
(20 items)
AMD Ryzen 5 2600x
ASUS x470-F
EVGA 2070 Super FTW3
G.Skill Trident Z RGB
Samsung EVO
Seagate
EVGA G2
Noctura NH-D15 SE
Fractal Design R6
Operating System
Windows 10
Insignia NS-PMG248
LG 24MK400H-B
LG 24MK400H-B
Keyboard
Corsair K68
Mouse
Logitech G502
Mousepad
Steeleries QCK Edge
Audio
Logitect X230
Other
Neweer Condeser Mic NW 120
Other
GtRacing Chair
Other
Logitech 4000 Webcam
JennyBeans is offline
post #9 of 27 (permalink) Old 07-06-2020, 06:21 AM
Yuke's Avatar
Rep: 1 (Unique: 1)
Does GN also run an all core OC? 4.3 on twelve cores while doing P95 is gonna run hot for sure...my 3800x clocks down to 4050-4100 to be able to maintain 85°C with an NHD15 in Darkbase Pro Case (Three Intakes, three exhauts)
PewPew Rig
(12 items)
Ryzen 7 3800x
Gigabyte x570 Aorus Master
RTX™ 2080 Ti GAMING OC 11G
G.SKill Trident Z Neo
ADATA XPG SX8200 Pro
be quite! Straight Power 11
Noctua NH-D15S
Dark Base Pro 900
ViewSonic ELITE XG270QG
Mouse
Roccat Kone Pure Ultra
Mousepad
ZOWIE G-SR- SE Deep Blue
Audio
Creative Soundblaster AE5
Yuke is offline
post #10 of 27 (permalink) Old 07-06-2020, 06:36 AM
The last VRM burner
Yeah, just DBP900 is an oven so your issue comes from a closed up case, not workload nor CPU.
PC for all
(23 items)
MSI Z97 MPower
Corsair MP510
Samsung Evo 860
Top Arctic P14 x2
Back Arctic P12
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
