Modding an old Cooler (it's worth?) - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 07-13-2020, 06:10 PM - Thread Starter
Rep: 0
Hi, I'm planing on replacing my very old PC with a new Ryzen 3900x setup and I was wondering if it's worth modding an old CPU cooler. I have a CNC machine, so I can easily create an adapter for AM4 for almost free, but I wanna know how the performance would be against modern solutions.
According to this old review of the bad boy I wanna mod(https://www.legitreviews.com/cooler-...ler-review_609), it have a thermal resistance of around 0.17C/W. Googling, I find that most top tier modern solution have around half of this.
The thing is, I'm not planning on overclocking the new pc (nowadays solutions has way more power that what I need), but I would like to have a very quiet PC, so the more efficient, the lower the fan speed I can put and the less noise I would get. I just wanna know if this will be able to handle a Ryzen 3900x at full load with all the fans at the lower possible setting or I should just buy a newer solution.
ViXoZuDo is offline
post #2 of 5 (permalink) Old 07-13-2020, 06:37 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1449 (Unique: 731)
I used to run one of those! ran it on a Q6600 for a bit and then moved it to a 960T
if you don't need to spend any money to make it work then go for it, worse case scenario it's not good enough and you need to buy something. I wouldn't put any significant money into making it work though.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #3 of 5 (permalink) Old 07-13-2020, 06:41 PM
Fix it till its broke
Owterspace's Avatar
Rep: 9 (Unique: 5)
Nice!
I would do it.
3770K @ 4700MHz 1.35v/Thermalright True Spirit 140 Power TY-143 Push/Pull
ASRock Z77 OC Formula|8GB G.Skill Mix @ 1100MHz 9-11-9-28-2T 1.68v
EVGA GTX 980 Classified 3988 @ 1497/2001|Intel 545S 256 Striped
CM Silent Pro M2 850|Fractal Define R4/5x 120x38 1x 92x38|ZM-MFC2
Owterspace is offline
post #4 of 5 (permalink) Old 07-14-2020, 07:35 AM
doyll's Avatar
Rep: 1702 (Unique: 941)
As you can do it for almost nothing I would give it a try. The worst case is you decide to buy a cooler.
doyll is offline
post #5 of 5 (permalink) Old 07-14-2020, 07:54 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
Eh....it's a cool use of time if you enjoy doing things like this. Personally, I wouldn't put in the effort on a GeminII. Before you do, make sure there is enough contact plate to cover what you need to on a Ryzen, and that you can place it properly to do so.
ciarlatano is online now
