Best top down CPU coolers today? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 07-13-2020, 08:29 PM - Thread Starter
8051's Avatar
Rep: 30 (Unique: 21)
What are the best Ryzen 9 and 10th gen Intel CPU top down coolers available today? Can any top down coolers match the performance of dual tower coolers?
8051 is offline
post #2 of 11 (permalink) Old 07-14-2020, 01:00 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 45 (Unique: 27)
Six years of membership and 30 rep points later, you should by now know that there is no "best"..
Regardless and starting backwards, no, none can match them, but the single degree delta difference range is for most negligible.
Far as the former goes? https://noctua.at/en/products/cpu-co.../specification
Quiet enough at stock and if one's after numbers, better 140 fans do exist; no other "top down" i'd recommend in general. In general because again, there is no "best".
As always, my take is not only on performance (though in this case we're spon on on that one), but also on "pay now and regret not later", ease of use and reliability/quality assurance. You can't beat Noctua there.
Pride, honour and purity.
Aenra is offline
post #3 of 11 (permalink) Old 07-14-2020, 01:22 AM
Avid Memer
chessmyantidrug's Avatar
Rep: 246 (Unique: 182)
If you have the space for a tower cooler, there's no reason to get a downdraft cooler. The only reason to get a downdraft cooler is if you're height restricted, then the restriction determines which is most suitable. In my instance, it was the Scythe Big Shuriken 3 with an NF-A12x25. Not exactly the most cost-effective solution at ~$80 total, but I needed as much cooling as I could get for an i9-9900KF.
ITX gaming system
(17 items)
i9-9900KF
ASRock Z390 Phantom Gaming ITX/AC
EVGA RTX 2070 Super Black Gaming
Crucial Ballistix
Samsung 970 Evo
Samsung 850 Pro
Samsung 850 Pro
Seagate FireCuda
Seasonic FOCUS SGX
SilverStone FTZ01-E
Operating System
Windows 10 Home
BenQ XL2420Z
BenQ RL2455HM
Keyboard
Deck Legend Fire
Mouse
SteelSeries Rival 500
Mousepad
HyperX Fury S Cloud9 Edition
chessmyantidrug is offline
post #4 of 11 (permalink) Old 07-14-2020, 02:02 AM
Meep
Gilles3000's Avatar
Rep: 333 (Unique: 235)
Yep, only get a downdraft if you have a case that requires it, for size or airflow direction reasons.
But anyway, if we're talking big downdraft coolers, there are only 2 worth considering. The be quiet! Dark Rock TF and Noctua NH-C14S.
And maybe the Phanteks PH-TC14CS, if you can still find them. But they seem to be on their way out.
Gilles3000 is offline
post #5 of 11 (permalink) Old 07-14-2020, 02:14 AM
Edgy & on the edge
Rep: 54 (Unique: 27)
AMD Bliss
(16 items)
AMD Ryzen 5 3600 - 2019PGT
MSI X470 Gaming Plus Max - 1.0.0.6
ASUS GTX 1060 Strix 6GB
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
ASUS VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
rares495 is online now
post #6 of 11 (permalink) Old 07-14-2020, 03:45 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
As mentioned, the Dark Rock TF and NH-C14S. Either will come within a few degrees of a D15 or the like.
@Gilles3000 - I tested three samples of the TC14CS, tried different fans, orientations, etc, and they couldn't keep up with the bq and Noctua. I was really surprised, and the gap was pretty large.
ciarlatano is online now
post #7 of 11 (permalink) Old 07-14-2020, 07:32 AM
doyll's Avatar
Rep: 1702 (Unique: 941)
At high heat load probably not. They have fewer heatpipes and if using with fan pushing air toward motherboard tend to end up re-using their own heated exhaust air as hits mobo turning out, hits RAM, GPU etc turning up along side of cooler & fan where it's drawn back into cooler. But as ciarlatano said, they can do a very good job.
What system and case are you planning to use one on?
doyll is offline
post #8 of 11 (permalink) Old 07-14-2020, 12:32 PM - Thread Starter
8051's Avatar
I tried a Phanteks PH-TC14CS with my old 5820k build, even outside of a case and with more powerful fans fitted, it couldn't keep up with the heat load when overclocked. I liked the idea of downdraft coolers because I thought they might help keep the VRM circuitry cooler. I was hoping they had come out with something better since then.
On my old q9550 build I used a downdraft Thermaltake Big Typhoon with a 120x38mm fan and two stacked 120x20mm phobya ducts and had to cut a hole in the sidecover of my case to accommodate the height it seemed to work really well even considering the Big Typhoon wasn't highly regarded.
8051 is offline
post #9 of 11 (permalink) Old 07-14-2020, 12:36 PM
Meep
Gilles3000's Avatar
My bad, assumed it would be decently capable considering their other coolers and the amount of girth.
post #10 of 11 (permalink) Old 07-14-2020, 12:43 PM
ciarlatano's Avatar
You would think, but somehow Phanteks couldn't get a handle on TF coolers. Their other, the TC12LS was ok, but only ok, and not as good as it's size would indicate. But, not every company can do everything well. Phanteks makes great towers, cases and some liquid cooling products (along with some clunkers). Their blocks are beautiful and vastly underappreciated.
