3700x hitting 90 and above - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 07-16-2020, 01:35 AM - Thread Starter
Rep: 0
I just changed out my 3600 for a 3700x. With the 3600 I would idle around 35 to 40 and max load was usually 67 degrees.
Using the same cooler im hitting 85 in cinebench and going up to 92 degrees using y-cruncher. Idle is around 40 to 50. At first i was sure I didn't install enough paste, or put the cooler on wrong so I did it again and nothing changed. Is this normal? I assumed temps would be up a bit but definitely not that much. Nothing else has changed. It's behaving much like the 3600 did before i installed the noctua cooler. Bios and chipset drivers are all up to date, as well as a fresh windows install after I saw the temps.
I'm using:
Asus x570 tuf gaming plus
Noctua nh-u12s cooler
2 noctua top case fans along with 1 240mm intake and a 140mm exhaust.
Guizan33 is offline
post #2 of 17 (permalink) Old 07-16-2020, 01:37 AM
Edgy & on the edge
Rep: 54 (Unique: 27)
Check the CPU Core Voltage in HWInfo64 during Cinebench.
AMD Bliss
(16 items)
AMD Ryzen 5 3600 - 2019PGT
MSI X470 Gaming Plus Max - 1.0.0.6
ASUS GTX 1060 Strix 6GB
2x8GB G.Skill Trident Z 3600C15 @3800 14-15-12-28-40 1T 1.52V
Samsung 970 Evo Plus 250GB
2x Samsung 860 Evo 500GB
2x Crucial MX500 1TB
Super Flower Leadex II Gold 650W
be quiet! Dark Rock 4
Phanteks P350X
ASUS VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Logitech G502 Proteus Core
Mousepad
Logitech G440 hardmat
Audio
Asus Cerberus
rares495 is online now
post #3 of 17 (permalink) Old 07-16-2020, 02:00 AM
rdr09's Avatar
Rep: 894 (Unique: 644)
If you are using the original fan, you might want to replace it with two faster but equally quiet fans. I use two Cougar fans on mine. The original fan is quiet buy very slow. Make sure the paste spreads evenly and covers the ihs real well.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #4 of 17 (permalink) Old 07-16-2020, 02:05 AM
jonny27's Avatar
Rep: 4 (Unique: 4)
That's odd. I'm running a Scythe Mugen 5 on my 3700x (pbo off), which should perform about on par with the U12S, and it tops out at ~75C.
You said you did reinstall Windows already. What happens if you default the bios as well? Also try the Wraith Prism that comes with the 3700x to get a baseline. With it my 3700x topped at high 70's C with its fan running at around 2500rpm (account for different fan curves so expect a slight difference).
jonny27 is offline
post #5 of 17 (permalink) Old 07-16-2020, 02:27 AM - Thread Starter
Rep: 0
So I just removed the cooler and reinstalled with the noctua paste that came with the cooler instead of the arctic mx-4 I used previously. I checked the mount to make sure everything is solid.
Now its idling around 38 to 46 and hitting a high of 73 in cinebench. Y cruncher seems to push it a lot harder, so im running that now.
Would paste really make that much of a difference?
Guizan33 is offline
post #6 of 17 (permalink) Old 07-16-2020, 02:28 AM - Thread Starter
Rep: 0
Its topping out at 84 in y cruncher as opposed to 92 or so previously. The cinebench temp of 73 I find to be acceptable. What do you guys think?
Guizan33 is offline
post #7 of 17 (permalink) Old 07-16-2020, 02:29 AM - Thread Starter
Rep: 0
Core voltage is around 1.328 at max load. I have pbo enabled.
Guizan33 is offline
post #8 of 17 (permalink) Old 07-16-2020, 02:34 AM
Edgy & on the edge
There's your issue.
A weak cooler like the U12 won't be able to handle 1.3V on the 3700X. You should disable PBO and then the load voltage will drop to about 1.15-ish.
AMD Bliss
(16 items)
Phanteks P350X
ASUS VG245HE
Keyboard
Logitech G710+
Mouse
Logitech G502 Hero
Mouse
Mousepad
Audio
Asus Cerberus
post #9 of 17 (permalink) Old 07-16-2020, 02:48 AM
jonny27's Avatar
Rep: 4 (Unique: 4)
No, because I also use MX4. What temps do you get if you disable PBO?
jonny27 is offline
post #10 of 17 (permalink) Old 07-16-2020, 03:02 AM - Thread Starter
Rep: 0
[QUOTE=rares495;28539030]
There's your issue. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Wow... you were right about that.
My cinebench temp is now around 62.
Problem is that it won't boost over 3.9 ghz all core. I was getting around 4.2 before.
Single core is boosting about 100mhz higher. Close to 4.5
On cinebench, single core is about the same, multicore is WAY down... 300 points.
Is there a happy medium somewhere? I didnt have this issue with the 3600 with pbo enabled. For gaming (COD, Destiny, some other titles) what am I best off with? Temps were alot better even before turning pbo off.
Guizan33 is offline
