Can i lap my Xigmatek HDT-s1283? - Overclock.net - An Overclocking Community
post #1 of 47 (permalink) Old 09-06-2008, 08:27 PM - Thread Starter
Hey OCN,
Id like to know if i can LAP the new Xigmatek? Ive lapped the AMD 6000+ its it getting 60C under load (3.5Ghz @ 1.66v) It was 63C load before laping so it was pretty good but i think it can be better with the Xigmatek lapped to!
CorryBasler is offline
post #2 of 47 (permalink) Old 09-06-2008, 08:33 PM
CudaBoy71's Avatar
Rep: 129 (Unique: 121)
CudaBoy71 is offline
post #3 of 47 (permalink) Old 09-06-2008, 08:39 PM
XxBeNigNxX's Avatar
Rep: 151 (Unique: 122)
Lap away corey..... Looks can be very deceiving
On My Enzotech Extreme-X ( which has one of ,if not the best finish on the market (Mirror) it looked and felt flat.. Little did I know it was not untill I lapped th thing...temps dropped more and all was well.
So get to it Corey lap that thing
XxBeNigNxX is offline
post #4 of 47 (permalink) Old 09-06-2008, 08:43 PM
Rep: 114 (Unique: 107)
I would lap id the heat pipes n aluminum next them are uneven to get the even.
mr.derp is offline
post #5 of 47 (permalink) Old 09-06-2008, 08:47 PM
The Master Chief's Avatar
Rep: 929 (Unique: 730)
What? lol.
You should be able to unless your bore through the heat pipes.
The Master Chief is offline
post #6 of 47 (permalink) Old 09-06-2008, 11:25 PM
Originally Posted by The Master Chief View Post
What? lol.
lol.. yes and no, all depends on ur xig tho if its flat or not flat.. Most xigmateks come with a real flat surface dude, test to see if its flat with a razor, if it aint then lap away! heres some good kits if u dont already know! www.easypckits.com
Monst3r is offline
post #7 of 47 (permalink) Old 09-06-2008, 11:28 PM - Thread Starter
Did you happen to fail english class?
post #8 of 47 (permalink) Old 09-06-2008, 11:32 PM - Thread Starter
The metal between the heatpipes is taller then the pipes so i neeed to sand them down level! I have lapped the CPU to a mirro with the 2000 Grit paper!
post #9 of 47 (permalink) Old 09-06-2008, 11:38 PM
Nice dude howd it end up?
Monst3r is offline
post #10 of 47 (permalink) Old 09-07-2008, 01:48 AM - Thread Starter
Ive lapped the Xig and the AMD to a mirror finsh and its not geting any better temps! im thinking they are worse! AC id up a litle higher though!
