OCZ Vendetta 2/AC Freezer7 Bolt Thru Mods(UPDATED) - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 01-15-2009, 10:52 AM - Thread Starter
Jolly-Swagman's Avatar
Rep: 131 (Unique: 79)
Another Jolly Swagman Mod
OCZ Vendetta 2 / AC Freezer 7 Pro Cooler Bolt Thru Mods
Today I am going to Share with you how I have made my own Custom Bolt Thru Kit Mods for Both the OCZ Vendetta 2 and the AC Freezer 7 Pro CPU HSF Coolers.
First off I already had AC Freezer 7 Pro's on both mine and the Wife's Main Rigs and since now I have a Quad Q6600 in my main Rig, I thought Hey better order myself a better cooler, and Bolt Thru kit seeing that the Temps weren't to bad with the AC7 with a E6550 OC'd @ 3.2Ghz[and fair with the Q6600 @ 3.2Ghz, but could be better with a OCZ Vendetta 2.
So after much Frustration on Ordering the parts, HSF was no problem, but try getting a Bolt thru kit, was so frustrating as no one had any stock and could'nt give me a ETA when they would be in stock
So hence the Idea was to Fabricate My own Bolt Thru Kit myself, and below are the Results of How I Fabricated My own
Tools Used :- Jigsaw , Files , Dril and Bits,
Materials Used :- Old Broken TV Lap Tray( for the Plastic Mounting Plate)
:- 8 x 5/32 Metal Thread Screws
:- 16 x 5/32 Nuts
:- 16 x 5/32 Washers
:- 8 x 5/32 Spring Washers
:- 8 x 3/16 Fibre Washers
:- 8 x Small Rubber Hobby box Case Feet
:- Soft Rubber Stick on Weather Strip
Made a Template for the Mounting Holes of the LGA775 CPU HSF Mount and worked out a Design similar to that of the Xigmatek Crossbow Back plate,
Fabricated Bolt Thru Rear Plate
Drilled and Tapped 5/32 for Metal Tread Screws
Applied the Rubber Weather Strip to the X area of Plate for extra Protection to Motherboard Rear
Screwed the 5/32 Metal Thread Screws into position
Aligned into the Rear of Motherboard LGA775 Mounting Holes and Positioned
( next to the Back plate you can also see the Mounting Screws for the HR-05-IFX North bridge Cooler that was installed at the same time)
Then placed a Fibre Washer onto each of the Mounting Screws and 5/32 Nut to Bolt the Bracket into place
Then I Re-did the AS5 TIM on CPU and Positioned AC-Frezzer 7 on the Bolt Tru Mount and the on each Mounting Screw, Placed 1 Small Rubber Hobby box Case Feet, then the 5/32 washer,,spring washer,,and nut and Diagonally tightened Down
Then Cleaned the Old Residue of TIM from the North Bridge Chip and installed a Bigger NB Heat Sink and 40mmx25mm Fan
Then the Same process for the OCZ-Vendetta 2 HSF and also the HR-05-IFX NB Cooler.
Pictured with 120mm OCZ Vendetta 2 Fan attached and the HR-05-IFX North Bridge Heat Sink with a 70mm x 15mm Intel CPU-HSF from and Old skt370 M/B. ( ahh the wonders of recycling Old Useful parts)
Then just Reinstalled the Motherboard and GPU back into case
Here is a Core Temp Screeny of the Quad [email protected] Stock 2.4Ghz (9x266.67) and 100% Loaded with Running 1xGPU-FAH 2x SMP-FAH
Room Ambient Temp Today was Hot @ 34C Outside was 42C so thats why its not OC'd at the Moment, this week has been on average around 38-42C not good for OC'ing or running [email protected], [email protected]
And here (before someone asks are some PICS) of my New Palit GF9800GT Super +1GB Sonic GPU and it has an Awesome Heat sink set-up too that also cools the Rear Rear of the Ram chips too, Temps when loaded with GPU-FAH client are 44C and 40% fan speed,
Rear Cooling GPU
Here are Some Screanshots of the Q6600 on the GA-G31-S2L M/B and Cooled by the AC-Freezer 7 Pro CPU OC @ 3.0Ghz
The Q6600 is Now proudly in my Main Rig in Sig Below and will post up some OC'd Temp results, when this Summer Heat Cools down a bit, should be cooler in next few days
Some OC Results now that the Weather cooled down just a little @ around 28C
CPU-z Q6600 @ 3.2Ghz (8x400)
CoreTemp @ 100% Load
Hope this has been Informative for you all,, and thanks for looking.
All comments welcomed
Jolly Swagman
Jolly-Swagman is offline
post #2 of 15 (permalink) Old 01-15-2009, 10:59 AM
heathmcabee's Avatar
Rep: 126 (Unique: 109)
Nice work. +rep
90% of statistics are made up, and 50% of them aren't true.
heathmcabee is offline
post #3 of 15 (permalink) Old 01-15-2009, 10:59 AM
damn thats nice!
PepsiCan is offline
post #4 of 15 (permalink) Old 01-15-2009, 12:03 PM - Thread Starter
Originally Posted by heathmcabee View Post
Nice work. +rep
Originally Posted by PepsiCan View Post
damn thats nice!
Thanks for the comments and the +Rep, glad you both liked the Mod
post #5 of 15 (permalink) Old 01-15-2009, 12:33 PM
Rep: 109 (Unique: 83)
masbuskado is offline
post #6 of 15 (permalink) Old 01-15-2009, 02:39 PM
gtz
gtz's Avatar
Rep: 64 (Unique: 57)
Nicely done, your homemade bolt thru kit looks really good.
I know this is of topic but is it fairly easy to get the q6600 to 3.0 on the gigabyte G31 board?
Thanks
Ultra Instinct
(14 items)
AMD RYZEN 9 3900X
GIGABYTE X570 GAMING X
ZOTAC AMP NVIDIA RTX2080TI
32GB (4X8GB) CORSAIR LPX @ 3466 CL16
WESTERN DIGITAL BLACK 500GB NVME (OS)
SANDISK PLUS 960GB SSD SATA III (STORAGE)
CRUCIAL MX500 750GB SSD SATA III (IMPORTANT BACK UP)
EVGA SUPERNOVA G2 850W
ABATAP 6 PIPE COOLER
RAIJINTEK ASTERION EATX CASE
Operating System
WINDOWS 10 PRO
SCEPTRE 4K 27"
Keyboard
AZIO MECHANICAL BROWN
Mouse
AZIO
gtz is offline
post #7 of 15 (permalink) Old 01-15-2009, 03:43 PM - Thread Starter
Originally Posted by masbuskado View Post
Nicely done...!!! +rep
Thanks for the Comments and +Rep
Thanks
Also Thanks for the comments / Interest and +Rep
Yes as easy as just setting the FSB to 333 x9 with the Ram set to x2.4 if you are using 800spd Ram
post #8 of 15 (permalink) Old 01-16-2009, 11:39 AM
gtz
gtz's Avatar
Thanks for the information Jolly-Swagmon. +REP
I might pick up a G31 Gigabyte motherboard since I will need a cheap but good micro atx motherboard with onboard video that will at least push my future Q6600 (should come in the mail on Tuesday) to 3.0.
So thanks again.
Ultra Instinct
(14 items)
AMD RYZEN 9 3900X
Operating System
WINDOWS 10 PRO
SCEPTRE 4K 27"
Keyboard
Mouse
AZIO
gtz is offline
post #9 of 15 (permalink) Old 01-17-2009, 01:32 AM - Thread Starter
So thanks again.
Your Welcome!
Thread UPDATED Post with some screenshots of CPU-z Q6600 @ 3.2Ghz (8x400) & CoreTemp @ 100% Load
post #10 of 15 (permalink) Old 01-17-2009, 01:39 AM
Nelson2011's Avatar
Rep: 165 (Unique: 149)
Nice just need one for my ac 7. Could you build these for a price
Nelson2011 is offline
