San Ace 9G1212H1011 review - Page 2 - Overclock.net - An Overclocking Community
post #11 of 34 (permalink) Old 09-05-2009, 04:36 PM - Thread Starter
It's still almost enough.
Chunky_Chimp's Avatar
Originally Posted by runeazn View Post
lol i know why it is a 24volt thing if you dind't know mostly those fan controller are 6-12volt so it won't work
Wrong, the second "12" in the model name indicates it's a 12 volt fan.
I have it working on the controller now, I just had a lapse of sanity when running the extensions is all.
EDIT: I have noticed a very high-pitched squealing sound that lasts for about 3 seconds when the fan first starts. It's inaudible unless you're a foot or closer from the fan. I have estimated its starting voltage to be between 4 and 4.5 volts. I will say though, that at full speed, even though only 100 RPM separates it from the Panaflo U1BX, it sounds MUCH smoother. I now know what Vapor was talking about in his roundups that included the 109R, the predecessor. It's great.
Beginning Prime run! Will post temps here. Previously with the U1BX, these are what my results were at 7 volts and 12 volts respectively:
2nd edit; still running Prime, as of now 14k length tests are starting. Temps have leveled off, these are the current numbers at 7 volts, and I gotta say, this is a bit peculiar:
Complete. 12v temps:
I can't explain what's going on, really, but I noticed a healthy 1-2 degree drop when I increased the Panaflo (which is now rear exhaust) from 7v to 9.5v, making this cooler quite suitable for push-pull setups. OP updated with a summary.
Also RawZ, I don't know if you saw it the last time I posted, but I gotta note again that you're going to kill that top exhaust fan with that much static pressure being directed right at it. Don't be surprised if that exhaust stops working soon.
Loooooong needed edit; Anyone looking at these results probably want to know the testing conditions, so: Sunbeam Rheobus (non-Extreme), stock-clocked Core i7 920, Blood Rage (original, unmodded), 72*F room temp for BOTH tests (verified and monitored by wall thermostat near this monitor, controlled/balanced by a gas fireplace if below 72*F, large fan near the window if above 72*F). Other specs have remained mostly the same from this testing to this edit.
Combined air and water cooling tips: Fan database | My San Ace 9G1212H1011 review | Don't mix metals or use premixes / dyes | Distilled vs. tap water | Good radiator brands | Water (almost) can't flow too fast | Which PT Nuke to use | Regarding thermal paste spreading
Deep Blood
(15 items)
Soft Sentinel
Intel Core i7 920 D0 (Batch # 3901A240)
Foxconn X58 Blood Rage (non-GTI)
Sapphire Vega 64 8GB
6GB Corsair Dominator 1.6GHz TR3X6G1600C8D Rev 3.2
Samsung SSD830 128GB / Seagate 640GB+2TB+2x4TB
Optical Drive
Samsung SH-S223Q 22X
Antec HCPP-850
XTTH | OCZ Freeze | 9G1212H1011
CaseLabs SM8
Operating System
Windows 7 Ultimate x64 SP1
Dell U2410f (rev. A02)
Keyboard
Code 104 w/O-rings + Vortex PBT/POM doubleshot keycaps
Mouse
Roccat Kone EMP w/Dechanic Mini pad
Audio
Asus Xonar DX / Klipsch RM-14s + Dayton DTA-120 / MXL Tempo
Other
Microsoft Lifecam Cinema
Intel Core 2 Duo E6320
Intel DP35DP
XFX GeForce 7600GT
2GB Mushkin DDR2 800 5-5-5-12
Seagate Barracuda 7200.10 320GB
Optical Drive
Asus 18x multi-burner
Enermax Liberty 400w modular
Rosewill R5604-TBK
Operating System
Windows XP Pro SP3 32-bit
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Logitech MX-518 (rev.2; 1800 DPI [no Teflon feet])
Mouse
Xtrac Pads Ripper
Chunky_Chimp is offline
post #12 of 34 (permalink) Old 09-06-2009, 09:52 AM
kevindd992002's Avatar
Rep: 85 (Unique: 67)
Hey, you got your San Ace I see. I'm still waiting for mine. So you got all disappointment?
My Rig
(14 items)
Intel® Core™ i7-8700K
ASUS ROG MAXIMUS X CODE
EVGA GeForce GTX 1080 Ti FTW3 GAMING
G.SKILL F4-3200C14D-16GTZKW TridentZ Series
Samsung 970 EVO NVMe (OS Drive)
Samsung 850 EVO
SeaSonic Platinum-760 (SS-760XP) Power Supply
Custom Watercooling Loop
Phanteks Enthoo Evolv ATX Glass
Operating System
Microsoft Windows 10 Enterprise
Dell S2716DG Gaming Monitor
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
kevindd992002 is offline
post #13 of 34 (permalink) Old 09-06-2009, 11:34 AM - Thread Starter
Not at all. Read the updated portion of the OP.
Deep Blood
(15 items)
Soft Sentinel
Optical Drive
Antec HCPP-850
CaseLabs SM8
Operating System
Keyboard
Mouse
Audio
Other
Intel DP35DP
XFX GeForce 7600GT
Optical Drive
Rosewill R5604-TBK
Operating System
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Mouse
Xtrac Pads Ripper
post #14 of 34 (permalink) Old 09-06-2009, 11:35 AM
Read about that. So what was the reason when initially you can't run it on your fan controller?
And did the squeak go away already?
Why would the Panaflo U1BX be better than this fan?
My Rig
(14 items)
Samsung 850 EVO
Operating System
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
post #15 of 34 (permalink) Old 09-06-2009, 11:38 AM - Thread Starter
I don't know why the Panaflo yielded better results, especially when my exhaust at the time was a low-pressure Cooler Master fan. But I can tell you that the San Ace undervolts much better and has a significantly lower starting voltage (4-4.5 volts compared to 6 volts), so overall, when you neglect the posted temps, the San Ace is better.
The squeak goes away once the motor completely starts. Like I said, it only lasts a few seconds.
I couldn't get it working at first because, like I said, I'd had a lapse of sanity running the fan extensions (and in the process embarrassingly sliced my leg on the male end of one of the extensions I'd disconnected).
Deep Blood
(15 items)
Soft Sentinel
Optical Drive
Antec HCPP-850
CaseLabs SM8
Operating System
Keyboard
Mouse
Audio
Other
Intel DP35DP
XFX GeForce 7600GT
Optical Drive
Rosewill R5604-TBK
Operating System
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Mouse
Xtrac Pads Ripper
post #16 of 34 (permalink) Old 09-06-2009, 11:43 AM
Ok
So the difference in performance is 1-2C right?
Do other people experience the same results with these fans?
My Rig
(14 items)
Samsung 850 EVO
Operating System
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
post #17 of 34 (permalink) Old 09-06-2009, 11:47 AM - Thread Starter
Yeah.
Couldn't tell you. It depends on the fans they're already using.
Deep Blood
(15 items)
Soft Sentinel
Optical Drive
Antec HCPP-850
CaseLabs SM8
Operating System
Keyboard
Mouse
Audio
Other
Intel DP35DP
XFX GeForce 7600GT
Optical Drive
Rosewill R5604-TBK
Operating System
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Mouse
Xtrac Pads Ripper
post #18 of 34 (permalink) Old 09-07-2009, 05:04 AM
shanbcn's Avatar
Rep: 3 (Unique: 3)
Will 2 San Ace 38mm fans working at lower speeds match up to 1 San ace at 2600rpm for Megahalems? I am asking this because 39dba is loud.
shanbcn is offline
post #19 of 34 (permalink) Old 09-07-2009, 10:18 AM
Rep: 505 (Unique: 416)
there's was a comparison made here @ OCN by someone that showed two San Aces spinning @ different speeds. I think the results were that spining @ a lower speed yielded a better result or something. I forgot where's the link to it, hope someone can post that.
Aristotle:
Whosoever is delighted in solitude is either a wild beast or a god.
Raiden911 is offline
post #20 of 34 (permalink) Old 09-07-2009, 02:42 PM
shanbcn's Avatar
Rep: 3 (Unique: 3)
So two San Aces spninning at lower speed will be better or match up to 1 san ace at full speed? Thats mean lower noise so i will buy two san aces in that case.
shanbcn is offline
