San Ace 9G1212H1011 review - Overclock.net - An Overclocking Community
post #1 of 34 (permalink) Old 09-05-2009, 02:48 PM - Thread Starter
It's still almost enough.
Chunky_Chimp's Avatar
Got something in my mailbox today, and upon bringing it inside and opening it...
Ahh, but I tease. Here's the money shot.
キタ━━━━━━(゚∀゚)━━━━━━!!!!! (Kita!!!!!; It's here!!!!!)
As I said, I'll soon pit this deity of airflow against the Panaflo U1BX, which I've been using since I upgraded my system. This thing is slightly heavier and more solid than my Panaflo, and amusingly came in a box meant for a Swiftech MCP-655. The Royal Mail and US customs treated the package very well; if requested I'll upload the pics I took of the packaging.
Spinning the blades with my fingers, I can tell you this much; if you run it at full speed and stick your finger in, your finger will break before the blades. Also during my little twiddly-spinning (lol), I noticed that there's a nice little push of air. If only I had an anemometer, I could say what the CFM is at... however many volts runs along the nerve endings in your fingers. I won't bother reserving a post, I'll simply make another post with my temp comparisons during a small FFT Prime95 run, and link to that post in this one.
UPDATE: Results and testing conditions here. Panaflo wins, but I can't seem to figure out why for the time being. The San Ace undervolts better, it sounds better across all voltages, and it'll last a very long time. If I had to say, I'd still prefer the San Ace because, well, it's a San Ace! These fans are legends of air and water cooling alike, and I'll always recommend them if I see they're still available (and they still are at the time of this update). If they are unavailable, though, I'll recommend the U1BX hands-down. Why not the H1BX, which I also have? Well, because I have both models, I CAN say why; the U1BX is QUIETER at all voltages. I cannot explain this, either, nor do I have reason to.
Anyway, that's that. In short, this thing's a keeper, though I will need to find its predecessor and compare it to that to give you the full story.
Combined air and water cooling tips: Fan database | My San Ace 9G1212H1011 review | Don't mix metals or use premixes / dyes | Distilled vs. tap water | Good radiator brands | Water (almost) can't flow too fast | Which PT Nuke to use | Regarding thermal paste spreading
Deep Blood
(15 items)
Soft Sentinel
Intel Core i7 920 D0 (Batch # 3901A240)
Foxconn X58 Blood Rage (non-GTI)
Sapphire Vega 64 8GB
6GB Corsair Dominator 1.6GHz TR3X6G1600C8D Rev 3.2
Samsung SSD830 128GB / Seagate 640GB+2TB+2x4TB
Optical Drive
Samsung SH-S223Q 22X
Antec HCPP-850
XTTH | OCZ Freeze | 9G1212H1011
CaseLabs SM8
Operating System
Windows 7 Ultimate x64 SP1
Dell U2410f (rev. A02)
Keyboard
Code 104 w/O-rings + Vortex PBT/POM doubleshot keycaps
Mouse
Roccat Kone EMP w/Dechanic Mini pad
Audio
Asus Xonar DX / Klipsch RM-14s + Dayton DTA-120 / MXL Tempo
Other
Microsoft Lifecam Cinema
Intel Core 2 Duo E6320
Intel DP35DP
XFX GeForce 7600GT
2GB Mushkin DDR2 800 5-5-5-12
Seagate Barracuda 7200.10 320GB
Optical Drive
Asus 18x multi-burner
Enermax Liberty 400w modular
Rosewill R5604-TBK
Operating System
Windows XP Pro SP3 32-bit
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Logitech MX-518 (rev.2; 1800 DPI [no Teflon feet])
Mouse
Xtrac Pads Ripper
Chunky_Chimp is offline
post #2 of 34 (permalink) Old 09-05-2009, 03:38 PM
Rep: 189 (Unique: 161)
WarlordOne is offline
post #3 of 34 (permalink) Old 09-05-2009, 04:52 PM - Thread Starter
Disappointment is in the air. The fan is not starting. Cabling and power were double-checked, everything is connected as it should be, I even checked the Rheobus itself and that's not the problem. Any ideas? I'm going to power off and reconnect the San Ace to a molex connection and see if it'll start.
Deep Blood
(15 items)
Soft Sentinel
Optical Drive
Antec HCPP-850
CaseLabs SM8
Operating System
Keyboard
Mouse
Audio
Other
Intel DP35DP
XFX GeForce 7600GT
Optical Drive
Rosewill R5604-TBK
Operating System
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Mouse
Xtrac Pads Ripper
post #4 of 34 (permalink) Old 09-05-2009, 05:00 PM
gymenii's Avatar
Rep: 402 (Unique: 336)
wow, all that excitement in your OP and it doesn't work
You know you are living in 2012 when... Every commercial on television has a web site at the bottom of the screen.
gymenii is offline
post #5 of 34 (permalink) Old 09-05-2009, 05:02 PM
Freeflushots
TheCh3F's Avatar
Rep: 335 (Unique: 276)
check the 3 pin connection and see if it was wired on correctly
[CPU Loop: XSPC Rasa Black :: GTX360 :: H1011's :: 655v] [Bartx DICE/LN2] [SS Phase]
[Q6600 G0 4.1GHz] :: [i7 920 C0 4GHz] :: [955 BE C2 4GHz] :: [i7 920 D0 5GHz HT ON] :: [1090T 1012 4.3GHz AIR]
boot to the fruit. heck yes
TheCh3F is offline
post #6 of 34 (permalink) Old 09-05-2009, 05:04 PM - Thread Starter
Update! It does work on direct molex, and it's quite loud. The tone of the fan is pleasant but it fills the whole damn room. I really can't figure this one out right now, I'll check the 3-pin extension.
Deep Blood
(15 items)
Soft Sentinel
Optical Drive
Antec HCPP-850
CaseLabs SM8
Operating System
Keyboard
Mouse
Audio
Other
Intel DP35DP
XFX GeForce 7600GT
Optical Drive
Rosewill R5604-TBK
Operating System
Samsung LN-S2351W
Keyboard
Ideazon MERC
Mouse
Mouse
Xtrac Pads Ripper
post #7 of 34 (permalink) Old 09-05-2009, 05:11 PM
Rep: 157 (Unique: 145)
lol i know why it is a 24volt thing if you dind't know mostly those fan controller are 6-12volt so it won't work
runeazn is offline
post #8 of 34 (permalink) Old 09-05-2009, 05:16 PM
gymenii's Avatar
no, it's 12v .38 amps.
CC, check the 3pin connector. One of the wires may be lose or about to break.
gymenii is offline
post #9 of 34 (permalink) Old 09-05-2009, 05:22 PM
RawZ's Avatar
Rep: 77 (Unique: 65)
I have the same fan on my TRUE. Got 2..
RawZ is offline
post #10 of 34 (permalink) Old 09-05-2009, 05:31 PM
Lol, 2nd time i've seen this picture and still makes me smile.
jshay is offline
