[Guide]Make Home made AC fan adapter - Overclock.net - An Overclocking Community
post #1 of 55 (permalink) Old 11-25-2009, 02:10 PM - Thread Starter
Rep: 157 (Unique: 145)
thought of sharing how to make this and let to see my finished product.
1. Get an ac adapter under 12v i used an old Motorola phone charger. How lesser volt how lesser sound, but do note lower voltage means lower CFM.
2. Get a fan splitter cable(to let it look professional and u can have more fans on a single adapter) and take the pins out it. the yellow one is not necessarily and i say dont try it!!! even your ac adapter has it piccy
3. rip off the head of the ac adapter and try to search the black an red one
4. rip the black and red cable and try to get those metal threads of the ac adapter
4.5. Use a multimeter how much it really Volts it gives.!
5. you see metal pins on your splitter cable after removing the pins photo how it need to look like :
I do not recommend to do yellow one .You need to bring the red with red and black with black.Wrap some over each on red and red wrap tape black and black wrap tape and then wrap once again
5.5 You could solder it but binding them together is fine I just bound them together but soldering it is more sturdy.
6. viola you have a working ac fan adapter
7. how more "Amperage" how more fans, voltage is not a matter cause it only says how hard your fan will blow.
finished product piccy's :
dont try to go over the amount of A
and this was only a example most fan worn spin up at 4.4V but my san aces does
try to go 5+V
runeazn is offline
post #2 of 55 (permalink) Old 11-25-2009, 06:47 PM
EnToxication's Avatar
Rep: 14 (Unique: 10)
Wow I'll tRy this
EnToxication is offline
post #3 of 55 (permalink) Old 11-26-2009, 06:31 AM
Volvo's Avatar
Rep: 395 (Unique: 323)
this is barely strong.. 4.4V, some fans won't even spin up with this voltage. plus, the amperage is at 1.1A only.. make sure you don't go past the limit.
Volvo is offline
post #4 of 55 (permalink) Old 11-26-2009, 06:35 AM
Senior Moderators
pioneerisloud's Avatar
I would have to agree with this 100%. I don't remember how much amperage a fan draws, but 1.1a is a VERY small amount. And most fans won't spin up until you reach at least 5v...most are at around 7v where they finally start to spin up though.
DisposalAreav4.0
(15 items)
BeigeBox
(16 items)
Intel Core i7 2600k @ 4.4GHz, 1.33v
Gigabyte Z68MA-D2H-B3
Asus RX580 8GB @ 1400 / 2150
Kingston HyperX (4x4GB) @ DDR3-1600, 8-9-8-24-1T
Crucial MX100 256GB + Sandisk Ultra 240GB RAID0
Toshiba 3TB 3.5"
PC Power & Cooling Silencer MKIII 950w
CoolerMaster 240mm
DIY PC Cuboid Blue mATX
Operating System
Windows 10 Pro x64
Hanns G 23" 1080p / 60Hz
Keyboard
Redragon 10 keyless
Mouse
Logitech Optical Mouse USB
Mousepad
Generic Onn Black
Audio
Diamond Edison 2.0
Intel Core i5 3570
MSI B75MA-E33
MSI RX550 4GB
8GB GSkill Sniper DDR3-1600 @ 667, 9-9-9-24
Intel 330 128GB SSD
Sandisk Ultra 120GB SSD
Western Digital Black 2.5" RAID0 1TB (500x2)
Antec VP450
No fans except GPU and PSU
Dell Beige Box (mATX)
Operating System
Windows 10 Pro x64
Philips 32" Roku TV
Keyboard
Logitech K400R
Mouse
Logitech K400R
Mousepad
Onn Mousepad
Audio
TV Speakers / Monoprice Headphones
pioneerisloud is offline
post #5 of 55 (permalink) Old 11-26-2009, 06:37 AM
Volvo's Avatar
true. most fans do spin up at 5V though, even my really 'hard' Nidec Beta-V's.
most regular fans won't draw above 1A, but there are powerful AVC's, Delta's and Nidec's that draw 1A and above, sometimes even exceeding 2.5A
EDIT:
I can see where this guy's going - he probably wants to make a personal cooler of some sort - but stringing 4 fans together at 4V is a great way to just waste electricity and not accomplish the goal of cooling yourself at the end of the day. Oh, probably blow up the adapter too.
P.S. thanks for rep
Volvo is offline
post #6 of 55 (permalink) Old 11-26-2009, 06:40 AM
Senior Moderators
EDIT:
P.S. thanks for rep
I want to say my Thunderblades would BARELY spin up at 7v. They would spin at 5v, but I would have to manually push them to start them. 7v was the spot they would start on their own. Each fan is different of course though.
DisposalAreav4.0
(15 items)
BeigeBox
(16 items)
Toshiba 3TB 3.5"
CoolerMaster 240mm
Operating System
Windows 10 Pro x64
Keyboard
Redragon 10 keyless
Mouse
Mousepad
Generic Onn Black
Audio
Diamond Edison 2.0
Intel Core i5 3570
MSI B75MA-E33
MSI RX550 4GB
Intel 330 128GB SSD
Antec VP450
Operating System
Windows 10 Pro x64
Philips 32" Roku TV
Keyboard
Logitech K400R
Mouse
Logitech K400R
Mousepad
Onn Mousepad
Audio
post #7 of 55 (permalink) Old 11-26-2009, 06:42 AM
Volvo's Avatar
true, true.
anyway, i'm still hunting for some 12V adapters. all the fans that i have spin up nicely at 5V - i'm trying to make a DIY laptop cooler here. but it seems like i've got a weird problem - the USB just isn't supplying enough power to start my fans up.. they jerk a bit and just die. i've tested them out with a 5V adapter and they spin up nicely with the adapter - they just don't do it with the USB port.
Volvo is offline
post #8 of 55 (permalink) Old 11-26-2009, 07:24 AM - Thread Starter
2 san aces does tehy instant spin up :d
runeazn is offline
post #9 of 55 (permalink) Old 11-26-2009, 08:01 AM - Thread Starter
EDIT:
P.S. thanks for rep
it are just 2 cooling fans and i do know i can't exceed 1a ...???
i only use 2 of them max but normally 1 and this was an test model ill get a stronger one
runeazn is offline
post #10 of 55 (permalink) Old 11-27-2009, 07:59 PM
Volvo's Avatar
Originally Posted by runeazn View Post
it are just 2 cooling fans and i do know i can't exceed 1a duhh???
drop the 'duh' attitude. we're just letting you know, or in this case, giving you a gentle reminder so you don't blow up the adapter, or worse - blow up your house.
in any case yes, they spin up, but is there enough wind to actually make this a purposeful invention? looking at fans spinning away but not actually pushing any air is yet another useless invention, just like lava lamps which die after a couple of years.
Volvo is offline
