Cooler Master Hyper 212 Plus/EVO Club - Page 628 - Overclock.net - An Overclocking Community
post #6271 of 6667 (permalink) Old 09-18-2014, 10:49 AM
CM Felinni's Avatar
Rep: 13 (Unique: 10)
Hyper 212 EVO + JetFlo 120 Myth BUSTER
We heard you like our JetFlo's with our Hyper 212 EVO.
Mount the JetFlo 120 Fan and included screws onto the Hyper 212 EVO fan bracket.
Remember to remove the anti-vibration pads, otherwise you won't be able to mount it to the heat-sink.
Give it a little elbow grease and the magical happens!
JetFlo 120 Push | Pull Amaaaazing!
Felinni M.
CMUSA Support
Cooler Master USA
CM Felinni is offline
post #6272 of 6667 (permalink) Old 09-19-2014, 11:34 AM
CM-Patrick's Avatar
Rep: 12 (Unique: 11)
CM-Patrick is offline
post #6273 of 6667 (permalink) Old 09-19-2014, 12:35 PM
Stock
hyp36rmax's Avatar
Rep: 144 (Unique: 122)
hyp36rmax is offline
post #6274 of 6667 (permalink) Old 09-23-2014, 07:24 AM
Typo Elemental
Simmons572's Avatar
I just found this thread this morning so I figured I'd join! I own x3 212 Evos.
x1 in my Kirito build, stock fan only (the other fan was removed because it raised my temps)
And x2 in my C1100 Case Swap!
AMD Threadripper 1900x
Asus Prime X399-A
EVGA 1080 Classified
Samsung 960 Evo
Intel 750 Series 400GB U.2
Samsung 850 Pro 512 GB
Seasonic 1050w 80+ Gold
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Asus Z170i Pro Gaming
Sapphire R9 Nano
Kingston FURY 16GB (2 x 8GB) DDR4-2400
Samsung 950 Pro 512 GB
Athena AP-MFATX40 400W Flex-ATX
be quiet! ​PURE ROCK ​SLIM
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
MK Disco RGB TKL (KBT Brown)
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Beyerdynam​ic DT 770 ​Pro 80 ohm
Audio
Antlion Audio ModMic 4 w/ Mute
Audio
Schiit Fulla 2
Other
Noctua NF-A9x14 (x2)
Other
Fractal Design FD-FAN-SSR2-92
Other
Fractal Design FD-FAN-SSR2-60 (x2)
Other
Fractal Design GP12-WT
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Kingston - FURY 8GB (2 x 4GB) DDR4-2400
ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2400
SanDisk - SSD PLUS 240GB
Kingston - SSDNow V200
Corsair HX850i
be quiet! - PURE ROCK
Thermaltake Core V21
Operating System
Windows 10 Pro
Simmons572 is offline
post #6275 of 6667 (permalink) Old 09-27-2014, 01:05 PM
ace101's Avatar
Rep: 1 (Unique: 1)
Hi! Is it normal to reach 94C using prime 95? Tried a blend test and it always reaches 94C with this cooler.
ace101 is offline
post #6276 of 6667 (permalink) Old 09-27-2014, 02:23 PM
DiaSin's Avatar
Rep: 58 (Unique: 54)
Depends on the chip and clockspeeds, I would hit that regularly at 4.4ghz with my 3570k under the H212 Evo. You should add your rig to your sig.
DiaSin is offline
post #6277 of 6667 (permalink) Old 09-27-2014, 08:44 PM
ace101's Avatar
Rep: 1 (Unique: 1)
CPU is 4770K at 3.9ghz. Not overclocked.
ace101 is offline
post #6278 of 6667 (permalink) Old 09-27-2014, 09:02 PM
DiaSin's Avatar
That seems awfully high for stock. Have you checked your voltages to make sure they are stable.
DiaSin is offline
post #6279 of 6667 (permalink) Old 09-28-2014, 12:10 AM
ace101's Avatar
Rep: 1 (Unique: 1)
Not yet. What value should I expect given that everything is stock?
ace101 is offline
post #6280 of 6667 (permalink) Old 09-28-2014, 07:59 AM
ace101's Avatar
Rep: 1 (Unique: 1)
Badly need your help fellow ocn.
Just tried running prime95 again. Before my maximum temp reaches 94C. But after trying it today, It reached a 100C!!! What could be the problem?
ace101 is offline
