Cooler Master Hyper 212 Plus/EVO Club - Overclock.net - An Overclocking Community
post #1 of 6668 (permalink) Old 12-22-2009, 08:18 AM - Thread Starter
Rep: 238 (Unique: 214)
Welcome to CM Hyper 212+/EVO Club!!
Support for CM Hyper 212+
Ask questions
Post comments
If you would like to be added please PM me
EDIT: You can also post in this thread to be added. Not sure if this is the official requirement, but I believe based on other posts that a picture of your cooler is needed, but if you have any questions or concerns about being added or about this thread, please don't hesitate to PM me about it.
You can now add yourself to the group!
Link is here! https://docs.google.com/spreadsheet/viewform?formkey=dFVfMEhJRkpLMWw5MHNtaDAxVm82NHc6MQ
Originally Posted by PapaSmurf View Post
What makes the Hyper 212+ so desirable?
One of the best things about the 212+ (aside from the price) is that you you don't need to buy anything extra to get excellent cooling. The BladeMaster fan that comes with it is one of the best you can get for it. Anything that will actually cool better is louder and would only give about a 1C lower temp anyway. You can always pick up a second BladeMaster (not an R4) to run in a push/pull setup. The next step up would be High Speed Yate Loon fans, but the difference isn't worth the additional sound level as far as I'm concerned. A pair of the Medium Speed Yate Loon fans would be quieter, but even in a Push/Pull configuration wouldn't be able to provide as much cooling capacity as the single BladeMaster that comes with the 212+. The regular R4's from Coolermaster don't have as much static pressure and are louder so they aren't as good for this as the stock BladeMaster's or even the High Speed Yate's are, although they would be about as loud.
A pair of BladeMaster's running in Push/Pull compared to a single BladeMaster would probably only be about 1 to 2C difference in temps. Unless you are doing some extreme overclocking or your computer is in a very hot climate it probably isn't enough to worry about. I only do it since I am running the [email protected] SMP client on my systems
which means they run at 100% cpu load 24/7/365. If I wasn't doing that I would only be using a single BladeMaster
on mine.
What fan comes with the Hyper 212+?
This is the actual BladeMaster fan that comes with the 212+. There are other places that carry it though.
What if my motherboard doesn't have enough PWM fan headers to run a pair of fans in PWM mode?
This is a 12" 4-Pin PWM Fan Y-Adapter Power Cable to allow you to run a pair of BladeMasters off of the same PWM fan header on a motherboard so they stay in sync if you use PWM. Even if your mobo does have enough headers, this is still a great way to make sure that they work together in an optimal fashion.
EDIT: The current CM hyper 212+ seems to come with something different than the Thermal Fustion 400 and is of a lesser quality than the Thermal Fusion 400
Do I need to buy a different Thermal Interface Material (TIM)?
The ThermalFusion400 TIM that comes with the Hyper 212+ is excellent as well. It's better than anything Arctic Silver makes and within 1C of Arctic Cooling MX2 or MX3 or IC Diamond 7. The difference between MX-2, MX-3, MX-4, IC Diamond 7, or any of the other top TIM is about 1C when properly applied. For the most part it has more to do with how one applies the TIM than it does what TIM they use. The problem with Arctic Silver is that it has such a long break in period. It takes 2 weeks for it to properly break in and give optimum results. During that time it requires several periods of the system running for app. 2 hours, then off for 2 hours per day every day for 2 weeks or it never really cures. To top that off it needs to be cleaned off and re-applied every 10 to 12 months. Having to re-apply it wouldn't be so bad if it didn't have that long drawn out break in process. The other TIMS I mentioned along with the CM TIM that comes with the 212+ have a break in period of less than an hour, with most being only a couple of minutes, and that is with continuous running. THAT is what makes Arctic Silver such a poor TIM. Back when Arctic Silver was first introduced it was the best that was available, but that was 10 years or more ago. In the past 5 years or so several other TIM's have easily met or exceeded it's performance with much less work involved rendering AS not worth the time or trouble to use anymore.
How should I apply the TIM?
The Hyper 212+ is a Heatpipe Direct Contact so the two or three line method is normally the best way to go. It depends on the number of heatpipes as to how many lines is required, but the 212+ has 4. See the bottom method on this guide. The single drop or line of TIM in the middle rarely works on them.
That said, I did some experimenting with my Hyper 212+'s and am having my best results using a credit card to cram a bit into the crevices then spreading a light coat over the entire surface of the heatsink base and not putting any directly on the cpu's IHS. Cramming some into the crevices between the heat pipes and the heatsink base surface is the key though. If you don't you tend to get air bubbles that prevent optimal heat transfer.
What about side panel fans with a Hyper 212+?
The chances of being able to mount a fan in the side panel of your case with a Hyper 212+ is somewhere between slim and none. The good news is you don't really need one. At best ll that side panel fan will do if you can mount it is bounce air off of the top of the heatsink (and the sides of the fan housings) which won't have any positive affect on your cpu temps. At the worst the airflow from that side panel fan will disrupt the natural airflow in the case causing the cpu temps to rise. In some cases (puns intended) a fan in the lower side panel position blowing on the graphics cards might help cool them, but that isn't a guarantee. Most of the time all the side panel fans do is make your computer louder. You are normally better off just leaving the fans out of the side panel openings (if they exist) and allow the natural airflow to draw in cool air or expel hot air as needed. It can be worth the time to test it out though if you have a fan to mount there, but I wouldn't go out and buy one just to test with though.
_.=Cooler Master Hyper 212+ Club=._
Orthographic Dimensions
both images from Cooler Master's product page for the Hyper 212 Plus
RallyMaster's 212+ with Push-pull Yate Loon D12SL-12s
***Reviews***
First Courtesy uf mav2000
Fan Orientation Testing by chinesethunda
***Members***
n00biE5200
calebchosen
headcase9
_Magic
xDuBz
draknir
MeatloafontheRadio
Boomer1979
jackkk1
rogueblade
BlackHoleSon
benyu
ryman546
Mapster
Heimsgard
mrmagoogt
test tube
Iggy0828
damocles
Danny Boy
usmankh10
damocles
mikhail00
jdazer
mumyoryu
RallyMaster
sportflyer
gd6noob
comawhite
SporkofdooM
N3C14R
jeesan485
terence52
TempestxPR
Ha-Nocri
gian84
jctpm
Turgin
reflex99
breakfromyou
Shooter116
Stealth Pyros
saint19
flashbulb
Crazy^^Red
hawaiian_geek
Satans_Hell
gant2k1
JDMfanatic
YangerD
NicksTricks007
MM-K
namurt
jetpuck73
JD4DC5
EazyMango
Lee79
ffejrxx
PapaSmurf
Zeke311
pyro_dude
amunrah
RoflNinja42
Atmosphere
foX2delta777
Zardoz
kingsrule5
hyujmn
Meatsauce
Keymaster4225
ocman
gtsteviiee
thx1138
BassDX
H0ourg1ass
Eno75 (former)
stockleyrod
Pieiam
braindrain
Smoblikat
HAGNK
Ginkosu
nickt1862
BungalowJunkie
oedstlych
Siegfried262
NguyenAdam
Seventh Badger
jach11
chinesethunda
abu46
Schwarz
Airrick10
wanako
glh00goh
victorzamora
suicideidiot321
blab8811
tori
donkrx
wongwarren
mrhiab
theSpacec0wboy
vitality
Xerof3ar
Fooliobass
jeffcox800
Jtmarch86
BearStyle
IXcrispyXI
Rebelord
vtecjunkie81
UCLAKoolman
modd1uk
Genome852
Sagman76
kayoh
kinonotabi
4LC4PON3
texas_nightowl
iXVappzz649Xi
Cee
Captain318
JonnyBigBoss
merwan
Neroh
hometoast
rdr09
RickyOG90
nowcontrol
Jaxlb
X-Country Dude96
ieatchairs
billcox0625
Metalcrack
Prpntblr95
Boyd
Geronimo25
RickyOG90
trumpet-205
stomii
jhsuperfast
iSpark
B0R1K
XReflection
Miz3r
*AcidBath*
iTzSenoko
Thanos1972
Nipaa~
consume
MGF Derp
pel
Junkboy
ishimura2446
Heazy
Epyon415
Rand Al'Thor
Matty8787
disturbed117
boogschd
nickt1862
afkingjay
Dad2David
chrisys93
Supper
Zeek
Pott
Xonipher
RushMore1205
konoii
jackblack644
Matt-Matt
DF is BUSY
MrWhiteRX7
kbrandon1
klewlis1
The Sandman
TheYonderGod
celticguardian1
Captain Mayhem
ranviper
TechT99
ivymaxwell
./Cy4n1d3\.
Blackout621
Xinoxide
Jaxis
crondable
breadcrums
Compunuts
kpreet1996
mrpurplehawk
Derko1
Knust
mkclan
MichaelZERO
Chubz
sandythedog
laser23
gr3nd3l
Stanfiem
Whitehair
Caustic Fox
am dew1
Methodical
nifatech2120
Marshmellow17
Boinz
itzhoovEr
RockThePylon
dipanzan
Pentium4 531 overclocker
the.grim.reaper
Maynard46
Uncle Dolans
Struzzin20
Fullmetalaj0
MKHunt
AlexNJ
thehybridkiwi
rainbrodash666
atarione
Faint
Akiei
Jolly Roger
General121
xnuw
Amhro
Riot
Wiffinberg
Turtley
ManiaKsLV
Sheyster
TheLombax
Wiffinberg
GeneO
Quantum Reality
Doc567
Ramsey77
Zantrill
liquidzoo
Segell
The Kurrk
NinjaToast
fbmowner
Alastair
Trunks
phillipjos
war6000
auroraborealis
PROBN4LYFE
Garabatos
dragonsamus
Nebacanezer
jdip
jordanecmusic
InsideJob
Heavy Mg
Nick84
VesperSAINT
I_Try_Pregame
Bombster
dr.evil
Infinite Jest
HelenKeller
PCSarge
Unlimate
Stinger5150
Lordred
Bonkers
StarvinMarvin
Nickc84
TheHarvman313
DizzlePro
Zettadox
47 Knucklehead
Hackcremo
zer0d3gree
FahrenheitGTI
Phenomanator53
KRAY-SLiCK
thescreensavers
Statius
Pheozero
dnnk
Bomster
8bitG33k
Lazlonius
kenmore81
Marioshi
phre0n
EliteReplay
mrtoyotaco
sherlock
williamdabastrd
steve210
rayzzr
stellamonstr7
keesgelder
lon5210
Crowe98
Khaled G
Gman200108
Radmanhs
Bobos Khedr
We now have a club signature, courtesy of PapaSmurf. Just copy the code below into your sig.
Sig Link
[center][url="https://www.overclock.net/t/632591/cooler-master-hyper-212-plus-club"][B][COLOR="Blue"]-=-Cooler Master Hyper 212+ Club-=-[/COLOR][/B][/url][/center]
chinesethunda is offline
post #2 of 6668 (permalink) Old 12-22-2009, 08:22 AM
shadow19935's Avatar
Rep: 141 (Unique: 116)
emm, pics? maby a review since its a club?
shadow19935 is offline
post #3 of 6668 (permalink) Old 12-22-2009, 08:25 AM
Rep: 487 (Unique: 399)
Originally Posted by n00biE5200 View Post
support for CM Hyper 212+
Ask questions
post comments
(I'm new at this)
Check out the Prolimatech Club for ideas on how your 1st post should look.
Do you have the Hyper 212+? You don't have it listed in your sig rig.
Shadowclock is offline
post #4 of 6668 (permalink) Old 12-22-2009, 08:29 AM
Rep: 12 (Unique: 12)
I have one, it would be cool to create a Cooler Master Hyper 212 Plus Club
go for it n00biE5200!
Core i7 4Ghz+ Club
LGA1156 club!
I7 860 @4.1 - http://valid.canardpc.com/show_oc.php?id=908040
calebchosen is offline
post #5 of 6668 (permalink) Old 12-22-2009, 08:38 AM
n00biE5200's Avatar
Rep: 9 (Unique: 9)
just bought it to day
Pros
-looks awesome
-Simple Install*
-2x120x120 fan support
-Huge
Cons
-Figuring out how to install
-Huge
*instructions are bad but once i figured it out it was easy
(Updated my sig rig)
Holly mother of god
The 1ghz Overclock ClubX2
Albert Einstein:
"If at first an idea does not sound absurd then there is no hope for it"
n00biE5200 is offline
post #6 of 6668 (permalink) Old 12-22-2009, 08:40 AM
it´s a great cooler, especially if you get the extra fan.
Core i7 4Ghz+ Club
LGA1156 club!
post #7 of 6668 (permalink) Old 12-22-2009, 08:43 AM
n00biE5200's Avatar
Rep: 9 (Unique: 9)
how does a 154 cfm delta fan sound?
Later ill test it with that fan on full
(the pins are funny so its all or nothing)
Holly mother of god
Albert Einstein:
post #8 of 6668 (permalink) Old 12-22-2009, 08:45 AM
Pros
-looks awesome
-Simple Install*
-Huge
Cons
-Huge
LOL you think the 212+ is huge? Look at the Mugen 2 or the new NH-D14, now those are huge. Come on now...clean up that 1st post if your going to make it a club
post #9 of 6668 (permalink) Old 12-22-2009, 08:47 AM
n00biE5200's Avatar
Rep: 9 (Unique: 9)
#1 this is my first heatsink i bought and it almost touches the 'door' of my case
#2 im working on it
#3 Thanks for the help
Holly mother of god
Albert Einstein:
post #10 of 6668 (permalink) Old 12-22-2009, 08:49 AM
Rep: 473 (Unique: 355)
I bought one for $15 at Fry's on Sunday.
Intel:MainRig i7 [email protected]/Gigabyte Z68X-UD3H/16GB [email protected]/2xHD6990
Intel:Secondary Xeon [email protected] 1.35v/X58A-UD3R/12GB [email protected]/3xHD6970
AMD:HTPC 2400-BE/A7GM-S 2.0/2GB [email protected]/HDMI
Server1ell R610 DualQuad/[email protected]
Server2:HP Proliant DL360 G5 DualQuad/[email protected]
rpm666 is offline
