Cleanup for lower temps, quieter operation. UPDATED (56k warning) - Overclock.net - An Overclocking Community
post #1 of 77 (permalink) Old 10-03-2010, 03:44 PM - Thread Starter
Retired Reviewer
ehume's Avatar
Rep: 1373 (Unique: 856)
Update here (cleaned another rig).
Also: Metro Vacuum DataVac Club
My daughter's computer has been getting quite noisy. Often it is the only thing you can hear in a smallish room with three computers going.
The computer is built in an Antec NSK 4480II that I bought a year ago for my first build, when I knew nothing about computers and I had to replace my dead Dell in a big hurry. I feel completely betrayed that this steel box was sold to me, and is still being sold:
You can't really see the dust on the side of the case - most of it was wiped off. But you can see the dust in the holes between the faceplate and the front bezel. Here's a closeup:
See any place for a filter? That's right: no place for a filter on this case that was designed for negative pressure.
Exploded view:
The prominent yellow cable that feeds 12 Volts to the vidcard actually hugs the left panel when the case is closed, so it is out of the airpath. There is no room behind the motherboard tray for any cable, so all of the extra cabling is stuffed at the top between the psu and the optical drive. Note that the HD is in a foam cradle at the bottom of the case. It didn't get any more air where it was, and the case transmitted vibration despite rubber bushings.
You will note that the San Ace 9S1212L401 is the only fan in the case. See item 2. in my sig for why a heatsink fan can act as a case exhaust fan. Suffice to say, when a steel "grill" (sidewall with holes cut in it) is removed it is much easier to move air through it. The fan itself is a 120x25mm seven-bladed fan that runs about 1500 rpm. Yet sitting in the middle of the case and pushing all its output through a Prolimatech Megahalems, this little fan sucked enough air in that dust accumulated despite the six unused PCI slots being empty.
A second note: the 9S1212L401(Low speed) is one of the San Ace Silent series fans. Similar fans, but as M (medium speed) and F (fast) are found in Seasonic X-series psu's and psu's made by Seasonic for other brands.
Note the dust on the fan. You can see it better here:
You can see much of the front intake grill here. Too bad it's behind a faceplate that restricts airflow.
Dust:
We are fostering an African Grey parrot, which sheds particles of down from the tips of its feathers. Cockatoos and cockatiels are worse.
A closeup of dust on the fan blades:
Then I hit it with
(Metro Vacuum DataVac - it's really a blower, despite its name). I used the medium nozzle. Because it's just a pump pushing air I didn't have to economize, as you would if you had a can of air. I put the nozzle on that back grate and blew it straight forward, reversing the normal airflow. The fan spun up quite nicely. I blew the whole thing clean. When I hit the noisy psu fan dust shot out the forward mesh of the psu. I felt like cackling with glee. Death to Dust!!!
The result:
All clean. And now the crappy little 80mm psu fan doesn't make so much noise either: it was probably unbalanced by the dust.
A parting view:
For all of its weaknesses, this case will hold a Megahalems. But I would heartily disrecommend it to anyone considering it.
Highly recommended:
San Ace Fans 9S and 9G fans.
Prolimatech Megahalems heatsinks.
and Periodic dusting.
UPDATE
Moved the computer to a new case a while back. Thought I might open it up to see if it needed cleaning. It did.
Check out: Clean up the Lian Li rig.
ehume is offline
post #2 of 77 (permalink) Old 10-03-2010, 05:53 PM
wongster's Avatar
Rep: 6 (Unique: 6)
I'm glad you took pictures of this whole thing.You're absolutely right about being economical with cans of compressed air, I may have to consider that duster. Great cleanup job!
Future Upgrades/Wanted List
SSD: Crucial M4
GPU: 6950 or 560 TI
Monitor: U2311 or U2412M
wongster is offline
post #3 of 77 (permalink) Old 10-04-2010, 07:51 PM
Linux Lobbyist
SecrtAgentMan's Avatar
Rep: 179 (Unique: 152)
Ah I need to get this, but I can't justify spending $50 just yet on it, I'll be using a hair dryer for the time being
SecrtAgentMan is offline
post #4 of 77 (permalink) Old 10-04-2010, 08:31 PM - Thread Starter
Retired Reviewer
ehume's Avatar
It's $43-something with free shipping just now. Oh how I love it.
ehume is offline
post #5 of 77 (permalink) Old 10-04-2010, 08:52 PM
Linux Lobbyist
The only thing I have now is a hair dryer to push it out and a 3HP shop-vac to suck anything out.
Is it bad if I put something like the shop vac's hose near anything?
By that I mean will static be made or will anything be short circuited?
post #6 of 77 (permalink) Old 10-04-2010, 09:17 PM - Thread Starter
Retired Reviewer
ehume's Avatar
That's an excellent question. I have no clue.
ehume is offline
post #7 of 77 (permalink) Old 10-04-2010, 09:28 PM
Linux Lobbyist
Haha damn it
post #8 of 77 (permalink) Old 10-15-2010, 04:56 PM
Drakenxile's Avatar
Rep: 28 (Unique: 23)
I've tried compressed co2 shooters and it works pretty baddly
i actualy used a shop vac once on reverse function made the nozzle on it fairly small and just shot all the dust out of my case was a lot of fun
Ryzen 4.0Ghz
(17 items)
Wife's Computer
My HTPC Comp
(11 items)
Ryzen 7 1700 @4.0ghz
MSI B350 Tomahawk
MSI GTX 1080 Gaming X
Team Nighthawk 2x8gb DDR4 3200
Kingston M2sata 500gb
Corsair RM650x
Custom Liquid Loop from leftovers
Phatneks Enthoo Evolv ATX
Operating System
Windows 10 64bit
27" Crossover 2560x1440
Keyboard
BlackWidow Ultimate
Mouse
Mionix Naos QG
Mouse
Rosewill Extended Mat
Audio
Corsair SP2500
Audio
Sennheiser HD598c
Audio
Audio-Technica 2020 Micorphone
Audio
Onboard ; ;
Intel I5-4670
Gigabyte Z97-UD3H
Powercolor 7950
Patriot 1866MHZ 2x8GB
Corsair Force 3 180GB SSD
750GB Seagate
Cooler Master 450w Gold
U2-UFO Mountain Mods
Operating System
Win 8
Asus VE247h 23.6"
Keyboard
Logitech G105
Mouse
Razer Deathadder
Mouse
Razer Goliath
Intel I3 4130
MSI H97M-G43
Power Color 7950
Crucial Ballistix 2x4GB ddr3 1333mhz
Corsaird Force 3 240gb SSD
Seagate 4TB SSHD
Antec BP 550w
Freezer 7 PRO Rev. 2
BitFenix Phenom MATX
BenQ W770ST
Audio
Crative Sound Blaster Titanium
Drakenxile is offline
post #9 of 77 (permalink) Old 10-15-2010, 08:14 PM
homestyle's Avatar
Rep: 89 (Unique: 81)
How much air does it shoot?
So compressed air can is 100%. Percentage-wise, how much air does it push?
homestyle is offline
post #10 of 77 (permalink) Old 11-08-2010, 09:22 PM
NguyenAdam's Avatar
Rep: 52 (Unique: 47)
I will definitely be getting this in a few weeks. My heatsink +psu are in need of MAJOR cleaning.
NguyenAdam is offline
