Macbook Air locked out after multiple attempts of wrong pin (icloud) - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 05-03-2015, 01:01 PM - Thread Starter
Zcypot's Avatar
Rep: 39 (Unique: 39)
Hello all,
I was playing a prank on my wife and decided to lock her out of the laptop via iCloud. She went crazy trying different pin numbers. Now all I see is a 60 minute timer and when that expires I can NOT type the pin, the boxes dont even show up.
Message on screen is "Your computer is disabled. Try again in 60 minutes"
Zcypot is offline
post #2 of 12 (permalink) Old 05-06-2015, 08:25 AM
KyleMart06's Avatar
Rep: 67 (Unique: 33)
Try this out and see what happens:
http://apple.stackexchange.com/questions/132478/macbook-pro-locked-with-find-my-mac-and-wont-let-me-boot
Looks like if you do a parameter ram reset it may help?? PRAM reset is hold CMD+Alt+P+R for two boot chimes and let it boot. Let us know if you figure it out.
DD-WRT Firmware Club
Home Chilly Hack
(20 items)
Freelance Book
Intel Core i5 2500K
GIGABYTE GA-Z68XP-UD3
Sapphire 11265-05-20G Radeon PULSE RX 580 8GB
Corsair Vengeance 8 GB DDR3 1600 MHz (PC3 12800)
Kingston SSDNow V300 Series SV300S37A/120G 2.5" 120GB SATA III
SanDisk Ultra Plus SDSSDHP-128G-G25 2.5" 128GB SATA III MLC
Western Digital Black (3.5") 1TB
Western Digital Black (2.5") 750GB
Optical Drive
CD/DVDRW (+LightScribe...woohoo)
550 Watt Corsair VX550
Cooler Master Hyper212 EVO
CM 692A
Operating System
Windows 10 Pro
Operating System
Mac OSX 10.12.6
ASUS VS248H-P 24" Widescreen
Dell P2414H 24" Widescreen
Keyboard
Used Apple Aluminum Wired
Mouse
SteelSeries Sensei Laser Gaming Mouse [RAW]
Other
ICY DOCK FLEX-FIT Trio MB343SP 2 x 2.5” HDD/SSD to 5.25” Adapter/Bracket with 1 x 3.5” Device/Drive Bay
Intel 2675QM
Apple Board
Radeon HD 6750M (512 MB)
Intel HD 3000
16 GB - Crucial 1333Mhz
SanDisk Ultra II 480GB
Optical Drive
MATSHITA DVD-RAM (UJ8A8)
85 Watt Brick
Pure Aluminum
Operating System
Mac OSX 10.12.4
15" (1440x900)
Keyboard
Apple Integrated
Audio
Hear Stuff
KyleMart06 is offline
post #3 of 12 (permalink) Old 05-06-2015, 08:33 AM
rdr09's Avatar
Rep: 894 (Unique: 644)
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #4 of 12 (permalink) Old 06-17-2015, 07:02 AM
Vembutech's Avatar
Rep: 16 (Unique: 16)
Well try this ;
Do some kind of Internet Recovery by starting iMac with Cmd-Alt-R. Then you may face lock screen (EFI pin lock) and enter your iCloud pin there. After that recovery process should begin and then your iMac should be booting normally.
Vembutech is offline
post #5 of 12 (permalink) Old 08-03-2015, 12:47 PM - Thread Starter
Zcypot's Avatar
Originally Posted by Vembutech View Post
Well try this ;
I forgot I made a thread here, necro update for anyone with same question in the future.
This is a feature on all recent apple devices that APPLE has to fix for you, mandatory visit to the store with receipt for device to prove ownership, lost it? well GL with that. Luckily I keep boxes of the stuff I buy and the receipt was there. I did not buy the laptop in the apple store, worstbuy(bestbuy) and I think I could of gotten the recipt from my worstbuy credit card account.
Hopefully this makes it into the google results because I did not find anything about this.
Zcypot is offline
post #6 of 12 (permalink) Old 08-12-2015, 10:14 AM
Radeon915's Avatar
Rep: 49 (Unique: 47)
Interesting! Kind of wondered what would happen myself.. Luckily I resisted the temptation.
MS is probing around checking how big of a gerbil they can ram up desktop user butt before he notices he's being royally screwed.
Radeon915 is offline
post #7 of 12 (permalink) Old 05-02-2016, 10:22 AM
pvida's Avatar
Rep: 0
I stumbled over this message when I was searching as I had the same problem:
1. My MacBook Air was lost/stolen and I locked it with a pin from my iPad.
2. After more than a week I got the message that the MacBook was locked. Unfortunately you get not information on where the Mac has been online.
3. After another week the MacBook showed up, someone returned it.
4. I tried to unlock and got the message "This Mac has been locked, Try again in 60, 59, 58 minutes". After this I got the message "Wring Passcode. Try again".
5. But, there is no field to type in the passcode.
6. Finally the solution was: Open findmyiphone on the iPad. select the MacBook. It says "locked... will play sound when online". On the right hand corner of the screen, there is a command to click on "remove". Hitting this the Mac is removed from the list and removed from the "lost"-status. Immediately after this the fields for entering the passcode showed up on the Mac. I assume it is also important, that your found mac is on a location where it remembers the net code to go online. Its hidden, there is no sign that the mac went online.
7. after entering the right passcode the mac reboots and looks like has never been away or abused...
8. I also asked apple-support. they send me an information, but the steps described there lead to the same solution but the screen and commands there where different. So maybe an old version of the helpfile.
Hope this helps fellow users. Robert.
pvida is offline
post #8 of 12 (permalink) Old 01-09-2018, 12:30 AM
jeroeningen's Avatar
Rep: 0
Well try this ;
For me this works, BUT I needed to be logged in on icloud.com/find using different computer at the same time in case to see the fields to enter the PIN.
As long as I wasn't logged in on icloud.com/find using a different computer at the same time, I was not able to view the field to enter the code.
jeroeningen is offline
post #9 of 12 (permalink) Old 01-09-2018, 03:30 AM
Data Recovery Engineer
Lord Xeb's Avatar
Rep: 1343 (Unique: 999)
So it got resolved?
Well either way less learned.
Only fools do not BACKUP their DATA!
"Everyone is an expert in something. Knowledge is acquired not earned. Always be humble and wise. Never look down on others ignorant in your ream of expertise."
Hsvkinyodh
(15 items)
3770k @ 4.5 1.384v
Asus Z77 Sabertooth
GTX 1070 Gaming 2126/2249 w/ Hybrid cooler
TridentX 16GB 2400MHz
Samsung 850 Pro 1TB
Seagate 2TB
Seasonic X 760W
H105
CM 690 II Adv
Operating System
Windows 10
Asus MG279Q - 24" 144Hz 1080p
Keyboard
Filco Majestic II w/ Cherry Reds
Audio
AKG A701
Audio
JDS Labs Objective 2
Audio
JDS Labs ODAC
Lord Xeb is offline
post #10 of 12 (permalink) Old 05-09-2018, 12:54 PM
Linux Lobbyist
Rep: 0
Apple support team will help you in this case..
Thanks
Mikeethestud is offline
