Paracord Mice Cable - made by CeeSA - Page 132 - Overclock.net - An Overclocking Community
post #1311 of 1355 (permalink) Old 05-26-2019, 07:00 AM
SnookAU's Avatar
Rep: 0
This is so true, the ascend cord is garbage really its so heavy.
SnookAU is offline
post #1312 of 1355 (permalink) Old 05-30-2019, 03:50 PM
xxmrtwizyxx's Avatar
Rep: 0
Left the stress relief heat shrink in the the mouse for now being how close it is to the scroll wheel. Honestly feels better this way tho heat shrinked the first one by the connector so the cable doesn't move hopefully it doesn't mess it up with out the stress relief part
xxmrtwizyxx is offline
post #1313 of 1355 (permalink) Old 05-31-2019, 06:23 AM
Zammin's Avatar
Rep: 9 (Unique: 4)
That looks really good. Do you happen to know if there are any guides on taking apart the Model O to install a cable? Or disassembly pics/videos?
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #1314 of 1355 (permalink) Old 05-31-2019, 06:46 AM
Rep: 0
Just remove the 2 back feet and the scews are there after that it comes apart fairly easily just make sure you don't just pull it up and break the ribin cables for the rgb strips I can take some pics when I get home if you need me to
post #1315 of 1355 (permalink) Old 05-31-2019, 08:06 AM
Rep: 0
Excuse my messy mouspad, but the new cable looks and feels absolutely amazing on the Rival 310,
thank you CeeSA!
tizz0r is offline
post #1316 of 1355 (permalink) Old 05-31-2019, 08:48 AM
Zammin's Avatar
Rep: 9 (Unique: 4)
Thanks for the advice! If you've got pictures from disassembly already that would be awesome but no need to take it apart again just for pictures. I found a couple on TPU of the shell removed but I haven't seen how the cable is run underneath the PCB, but that's all good I think with the instructions you've just mentioned I should be okay.
Zammin is offline
post #1317 of 1355 (permalink) Old 05-31-2019, 09:05 AM
Rep: 0
It actually doesn't run under the pcb can't do to how the bottom of the shell is designed you'll see when you take it apart it runs along the side and has little pins of a sort to hold the wire along the pcb
post #1318 of 1355 (permalink) Old 05-31-2019, 09:13 AM
Zammin's Avatar
Rep: 9 (Unique: 4)
Ah okay that's good to know, thanks. When you removed the rear feet, did they stick back on okay afterward or did you need to replace them?
Zammin is offline
post #1319 of 1355 (permalink) Old 05-31-2019, 09:33 AM
Rep: 0
I just use something thin to pry it off would not use a Razer blade tho cause you could easily cut your self something like a really small flat head would work. I don't have experience using a hair dryer so couldnt tell you how that is but the way I did it stuck back good for me
post #1320 of 1355 (permalink) Old 05-31-2019, 10:35 AM
Rep: 0
thank you CeeSA!
Dont worry my pad is dirtier 😂 just made it dark and to hide it a bit
