Overclock.net - An Overclocking Community - View Single Post - Software for R9 285 bios edit
View Single Post
post #1078 of (permalink) Old 11-23-2017, 04:14 PM
chris89
chris89's Avatar
Rep: 84 (Unique: 62)
Originally Posted by BLUuuE View Post
So I decided to swap out the stock fan with CM JetFlo 120mm fans.
The core temperatures are 5°C lower, but that might be because I swapped out the thermal paste. VRM temperatures are still the same (80-90°C at 1.15v VDDC), so most likely the stock thermal pads on the VRMs aren't that great. I'm considering getting some better thermal pads, particularly these FujiPoly ones. Maybe that will reduce the VRM temperatures a fair bit.
https://www.ebay.com/itm/NEW-Thermagon-thermal-gap-filler-pad-T-PLI-2200-A1-12mm-x-12mm-x-5mm-49-per-pack/182814014721?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Dell Precision T7500 : Dual Xeon X5675 @ 3.536Ghz X 24 Threads : 48 Gigabytes : Cinebench R15 : 1505 : AMD R9 390X 8GB @ 1173Mhz 1350mv 57599 Power Limit @ 1250Mhz memory error free on tight timings / since 1500mhz+ had errors galore
chris89 is offline
