Where to get liquid helium and is it expensive? - Overclock.net - An Overclocking Community
Closed Thread
post #1 of 34 (permalink) Old 04-29-2011, 09:41 AM - Thread Starter
badatgames18's Avatar
Rep: 209 (Unique: 180)
title basically says it all... i am assuming i can use my regular ln2 stuff just with helium switched?
thanks
badatgames18 is offline
post #2 of 34 (permalink) Old 04-29-2011, 09:44 AM
Retired Staff
Rep: 4426 (Unique: 2045)
Try a welding or scientific supply store/catalog.
However, it is very dangerous so tread with caution.
To answer most of your questions: (1) a fridge cannot cool a PC (2) 64-bit OS for over 3.4GB (3) If a PCIe card fits, it should work (4) Resolution, not screen size (5) Report, not respond to Spam (6) Single-Rail/Non-Modular PSUs are not always better than Multi-Rail/Modular (7) Sequential does not matter as much as random for OS drives (8) Requirements come before hardware for servers
DuckieHo is offline
post #3 of 34 (permalink) Old 04-29-2011, 09:44 AM
galaxyy's Avatar
Rep: 45 (Unique: 39)
He(l) is held at like 4K. That's REALLY cold...-269C. I don't know how much it would cost, but the equipment to keep it that cold surely would be expensive.
Check out my build-log including time-lapse movies of installation.
galaxyy is offline
post #4 of 34 (permalink) Old 04-29-2011, 09:45 AM
Retired Staff
Klue22's Avatar
Rep: 268 (Unique: 230)
You probably have to order it. Also it is extremely dangerous. It boils so fast at room temperature that you could suffocate yourself before you even know what hit you. Another thing is that it has such extreme surface tension that it will literally climb vertical surfaces (ie it must be contained). Needless to say you can't just poor it in a pot like LN2. The third danger is that its so cold that it would instantly burn you if you came into contact with it. Sorry to be a buzzkill frown.gif
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="tinyurl.com/3ea24jm"><img alt="cool.gif" src="http://files.overclock.net/images/smilies/cool.gif"><span><b><span style="font-size: 12px;">The 24/7 Folders Club</span></b></span><img alt="cool.gif" src="http://files.overclock.net/images/smilies/cool.gif"></a><br><a href="https://www.overclock.net/t/1616021/forum-folding-war-2017-the-lanyards/0_30"><span><b><span><span style="font-size: 12px;">The Lanyards! - Forum Folding War Team</span></span></b></span></a><br><span>Steam Username=[OCN] Klue22</span><br><span>My computer is so fast it can calculate an infinite loop in 9.392 seconds.</span></div></div></div>
Klue22 is offline
post #5 of 34 (permalink) Old 04-29-2011, 09:48 AM - Thread Starter
wow... i didn't know it would be that dangerous... i thought it would just be colder than LN2...
maybe it will come with a containment unit that i can somehow use? any one use helium before?
EDIT:[ame="http://www.youtube.com/watch?v=2Z6UJbwxBZI"]http://www.youtube.com/watch?v=2Z6UJbwxBZI[/ame]
I am going to head to my chemistry department and ask for it? hopefully i can video tape what ever i do with it if i get my hands on it
post #6 of 34 (permalink) Old 04-29-2011, 09:52 AM
notNOTmbudden
Rep: 690 (Unique: 508)
I highly doubt any person can just buy it, not to mention it boils far too quickly.
Flick of the wrist.
mbudden is offline
post #7 of 34 (permalink) Old 04-29-2011, 09:52 AM
Rep: 233 (Unique: 164)
Your going to need some serious gear for this. You will undoubtedly hit a cold bug. Not to mention you will need some serious containment gear to stop it from killing you. The best place to do this would be in a university lab environment with a protective suit, overhead ducts, and other proper safety precautions.
If I were you, I would not mess with it. Overclocking is not worth killing yourself over.
HTPC: Intel i3 550 | ZOTAC H55ITX-C-E | G.Skill Ripjaws 1600 | Vertex 30GB | ATI 4650 | Antec 650w | Antec P180 Mini
Audio: Asus Xonar Essence STX | Woo Audio 3 | Sennheiser HD800 | Audio-Technica ATH-A700 | M-Audio BX5a Studiophile Monitors
Moltar is offline
post #8 of 34 (permalink) Old 04-29-2011, 09:52 AM
Scorpii's Avatar
Rep: 57 (Unique: 52)
You'd have to get it with a dewer, you couldn't just store it in a fridge wink.gif
But it's so much colder than LN2, that most motherboards break when using it (even if you try insulating them).
Also, it boils very very quickly, I've seen a general idea that 250 litres gives you 90 minutes of benching time (250 litres is one of those big dewers full).
For where to get it, universities will have it (not sure if they'll sell it to you), or specialist engineering or laboratory suppliers will have it
However, as others have said, I'd advise against using it... Unless you are actually going for world records (and think you can achieve them), and are experienced at handling and working with liquid He4, then just stick to LN2
Scorpii is offline
post #9 of 34 (permalink) Old 04-29-2011, 09:54 AM
Rep: 41 (Unique: 37)
I've never used it for cooling but I've worked with it in a chem lab. My advice is to stay away. As people have said, it is very dangerous, especially at home without the safety precautions of a lab. Just use LN2. It is plenty cold. If you do work with helium, under no circumstances should you do it alone. Make sure you have someone there to help you and call an ambulance if something goes wrong.
omnius19 is offline
post #10 of 34 (permalink) Old 04-29-2011, 09:56 AM
Old School OCn
Blaze051806's Avatar
Rep: 57 (Unique: 55)
id say overkill lol, just get some LN2.. not like it wont do the trick lol
Poweeeeerrrrr
Blaze051806 is offline
Closed Thread
