Any Reason This Wouldn't Work? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 01-08-2012, 09:42 AM
insulated mobo's do not get hot.. especially with temp colder than -160c on the CPU...for that matter i run fully insulated mobo's for my daily user.. over 90% of the entire PCB is covered.. its temps are just fine.
 I really suggest you do some more reading up on subzero cooling.. you must understand how preposterous your conceptual idea really is. rolleyes.gif
CL3P20 is offline
post #12 of 15 (permalink) Old 01-08-2012, 02:19 PM - Thread Starter
Blast's Avatar
Rep: 28 (Unique: 15)
That is very interesting. I didn't know that motherboards don't get particularly hot. Are the heat sinks just for show?
Is there any forum or article you would suggest to me?
Blast is offline
post #13 of 15 (permalink) Old 01-08-2012, 02:29 PM
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDMQFjAA&url=http%3A%2F%2Fwww.xtremesystems.org%2Fforums%2Fshowthread.php%3F160872-Goliath-Triple-Cooling-System&ei=pgkKT83BGYWbiALKpum2CQ&usg=AFQjCNEZ291hMU5Eko0M6AXLvAqskLA2zQ&sig2=edoKtnunbgwmCQnYFed2ug
 Thats a particularly good one..
*as for my mobo.. heres a pic of what it looks like: insulated with a wax based modeling clay:
 I run a 930 on air @ 3.8ghz / 3.6qpi and 3.6NB for daily use on this now.. never bothered to remove the insulation as it will eventually have its time on -0 again.
CL3P20 is offline
post #14 of 15 (permalink) Old 01-09-2012, 04:26 AM
335is
NoGuru's Avatar
Rep: 769 (Unique: 312)
I run the same way, with all my boards fully insulated even if I am running 24/7 on air.
NoGuru is offline
post #15 of 15 (permalink) Old 01-09-2012, 06:28 AM
Retired Staff
el gappo's Avatar
Rep: 389 (Unique: 261)
So do I. Forgot I had the back lubed up tho, all got warm and dripped into the PSU. Didn't do any damage just looks like sombody... "accidently" All over the PSU.
Twitter @el_gappo @Overclocknet
Redhat: "The datasheet is clear so its pretty hard to read without an overhead projector"
el gappo is offline
